Question about Car Audio & Video
How do i remove the stock radio from the dash? do you have a website address i could use to follow?
  • 4,861 Answers
Here is a video showing how to remove a standard radio from the dashboard.
A pair of extractors are required (available from Ebay etc ) but these can be made from 2 pieces of bent, wire
coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys
or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4
securing clips
http://www.youtube.com/watch?v=urC-4NbXvDQ
note: on some radios , these 4 holes are protected by 4 small screws. These
can be unscrewed using the appropriate size of Allen key.
Posted on Dec 30, 2010
Remove radio
pull the knobs off there will b 2 nuts holding the radio in place 1 on the volume knob 1 on the channel selector remove them if the radio does not pull out loosen the back brace at rear of radio unplug wiring harness and antenna and its out
May 25, 2014 | 1986 Ford F 350
Removing the radio.
You should be able to see two (2) small grooves on the face of your VW radio, one on each side of the radio. You will need to insert a small flat tool into both slots simultaneously to release the radio from it's cradle. A small flat head screwdriver might actually work.
Depending upon the radio being installed, it might actually fit into the existing cradle, or you may have to partially disassemble the dash in order to switch cradles.
Jun 02, 2010 | 1998 Volkswagen Golf
How do you get the stock radio deck out of a 1991 buick park avenue?
*It's a bit tricky but not difficult, if you know how the dash in the Park Avenue is put together. But before you do anything, safety first. *Disconnect the negative cable from the battery before doing any electrical work on a car. This prevents shorting out your cars electrical system.
*If you own the 90 -91 Park Avenue model, simply pull off the decorative trim away from the radio to expose the torq screws that hold the radio into the dash. You will need a torq screwdriver of the right size to remove the radio.
Available from your local autoparts store.
*If you own the 91-92 model, it's a whole different ball game. This since the dash is much more tightly compacted. It's a combination of a snap together assembly and Torq screws. The dash is held together in columns or sections.
*The torq screws on these models are hidden behind the heater vents in the upper dash. First pry the wooden trim (Which surrounds the climate control module) on the bottom of the dash off, gently but firmly until it comes free, exposing the Torq screws on the lower dash. Remove the heater vents (hiding the upper screws ) by popping them out with a straight blade screw driver. Then remove all Torq screws visible to the eye, only from the column that is holding is holding the radio in place.
*You will then be able to remove the black colored plastic off the dash to expose the radio. (Use care when removing the lower dash column as some climate control and airbag sensors might be embedded).
*Remove all Torq screws holding the radio in place, (and keep track of all screws) pull the radio out of the dash, and disconnect electrical connectors. If you'll be replacing the stock radio with a non factory radio, make sure all electrical connection watch up, since security feature in the radio are integrated into the radio. (some of these effect basic function on your vehicle like the headlights) If you will be reinstalling the stock radio, you will have to have it unlocked by the dealership. The DelcoLoc system will now think the radio is stolen, because of it's internal security features. Installation is the reverse of removal.
Hope this helps.
May 20, 2010 | 1991 Buick Park Avenue
How do you remove the stock radio from a 2007 accent hatchback
First, you have to remove the bezel that surrounds the radio. You have to find something thin and sturdy to slide in behind the bezel to carefully pry it away from the dash assembly. Something along the lines of a plastic spackling knife will prevent scratching the dash. There are no screws, only clips holding that bezel in place.
Once you remove the bezel, you will see four screws holding the stock radio in place. Remove those, then slide the radio out.
You will need to unplug the wiring and antenna from the rear of the unit for complete removal.
Apr 22, 2010 | 2007 Hyundai Accent GS Hatchback
1995 cadillac deville stock radio not working
Before you remove the dash, double check the fuse(s). There are TWO fuses to power the radio. One is "switched on" when you turn the key on, the other is "constant on" to run the clock and the radio presets when the car is turned off. The constant on circuit is usually the Cigar Lighter fuse. Check the owner's manual or a trip to the library to look at their repair manuals for fuse box locations.
I repaired Delco radios for years and never had to tear the dash apart to fix a radio....
Jan 24, 2010 | 1995 Cadillac Seville
Radio removal on a 2004 toyota prerunner.
  1. Remove all of the temperature control knobs, including the A/C button (95-00 models).Using a small hook or a flat-head screwdriver, carefully pull the control panel straight out. It will pop out with a slight tug.
  2. Remove two phillips head screws from behind temperature control panel.
  3. Remove ashtray and remove the phillips head screw on upper right side.
  4. Carefully remove center black dash molding. This can be easily done by grabbing the plastic between the vents and the temperature controls and pulling toward you and slightly down. It will pop out with a slight tug.
Follow steps 1-4 - once you get the black trim plate off, the stock radio is held in place by 4 nut/screws. - remove the nut/screws - pull the stock radio out - disconnect the harness - disconnect the antenna - disconnect any auxiliary input devices (i.e. cd changer) if you have them.
When you go to put your new deck in, just follow these steps in reverse.
If you want pictures for the above process go to the below link
http://customtacos.com/tech/index.php?article=77
Oct 21, 2009 | 2004 Toyota Tacoma
How to take out the stock radio in a ford escort 1994 we pretty much rip the dash board apart except unhooking the hv/ac controls help please
go to the parts store and but the radio removal tools- you dont have to take any part of the dash apart... the radio pulls right out with the special tool
Jun 24, 2009 | Ford Escort Cars & Trucks
Take out dash(tundra) for antenna installation
You could do an antenna installation without removing the dash. Take out the center assembly with the radio and hvac controls and the glove box. You'll have enough access to run the antenna wire from its stock location to the radio.
Mar 31, 2009 | 2004 Toyota Tundra
I need to know how to remove the stock radio from a 2003 ford taurus so i can install an ipod adaptor
Ebay has the tool for removal cost $1 plus shipping. this tool is for the 2 holes on left and right side of radio face fit tool in then push alittle out worad and pull. Follow aftermarket instructon on install.
Jun 15, 2008 | 2003 Ford Taurus
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
