Question about ViewSonic N4785p 47 in. LCD TV
Input window is continuouosly on - ViewSonic N4785p 47 in. LCD TV
    Master:
  • 362 Answers
Usually this is cleared and restored with a display button on the remote or within the display menu on the set
Posted on Dec 30, 2010
I have an Xmax 125 13 The oil light is flashing continuouosly and my mechanic says it must be a loose sensor. Any ideas? Steve
Replace the sensor is all that I can suggest if you are sure the oil pressure is ok and the problem is the sensor.
Oct 28, 2016 | Cars & Trucks
I need the driver for this product for Windows 7. Where can I get it?
Generally, any video capabilities of your computer will allow this 'monitor' to work with your computer. You just have to make sure you're input is set to the same input you're using. Example: Computer uses HDMI, set TV input to HDMI you plug it into. HDMI 1 or HDMI 2; if your PC uses PCI, your TV must have one, and input source must be set to same. DCI, the same. You must set the TV input to the same input that you plugged your computer into on the TV.
#2, Drivers; the Windows 7 generic video out should get it to work. But, if you want driver to have more access to the TV's functions, so you can set size, ratio, brightness etc. You will have to get one from the manufacturer. They will let you know what driver you need.
If they list a Windows 7 driver, and tell you what the name of the driver is, go to Microsoft, and or Google, and search for that driver. Make sure the site you get the driver from is one you trust.
Aug 23, 2015 | Sylvania LC225SSX LCD TV
Www helpouts google com
Try resetting your graphic to default and reset the monitor to factory default.
May 04, 2014 | Televison & Video
Analog audio signal applied to "line input" jack on audio card produces no audio out (Dell 8300)
Ok, i'm not sure what version of windows you are running but on my windows xp machine I right click on my volume icon (little speaker) on the right side of the start bar on bottom of screen. Then click 'open volume control' , This will open up 'play control' window. In this window you now want to click 'options' in the upper left corner and select properties from the drop down menu. This will open up a second window titled 'Properties', near the top of this windows there is a section titled 'Adjust volume for', under this select the 'Recording' option. This will change the list of volume controls to your computers audio inputs. Make sure the input you are trying to use has a check mark next to it then click 'OK' on the bottom right of the 'Properties' window. The 'Properties' windows will close and the Play control window will now have the title 'Record control'. Make sure any inputs you want to use are turned up and there is a check mark next to the 'Selected' check box under the volume bar for each input. This should fix it for you. If you are using a different version of windows let me know what Windows you're using and i'll post a followup for you with the correct instructions. Good luck!
Dec 30, 2013 | Dell XPS 8300 Desktop
How can i switch the keyboard from us to german
(assuming this is for windows 7)
Search for 'Region and Language' using the search bar.
Click on Keyboards and languages Tab in the window that appears.
Click on 'Change keyboards'. A new Window of 'Text services and Input languages' shall appear.
On the general tab, click on 'Add' ans select German on the list that appears. Now that German is now available in the list, select German as the default input language in the text services and input languages window. Click OK in all windows.
Done.
Dec 04, 2013 | Rapoo WIRELESS KEYBOARD E1050 BLACK
When i install application or games on my sony ericsson aino it display operation failed, how can i fix this?
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 4410
Jul 10, 2013 | Audio Players & Recorders
How to turn on the front and back input plugs?
If there is a 'Menu" button on the front panel of your TV, you can enter its Menu options, surf through, come to input selection window, and select the input you want to. If there is no Menu button on the front panel of your TV, there is no other way to get into this window and select the input option, without a remote control.
Jun 22, 2012 | Televison & Video
How can I type Japanese o keybord?
Hai ! This is possible : )
Type in Chinese, Japanese, and other character-based languages
To type text on your computer in character-based languages, such as Chinese and Japanese, follow these steps:
[Source: http://windows.microsoft.com/en-us/windows-vista/Type-in-Chinese-Japanese-and-other-character-based-languages]
  1. Add the language as an input language. If you want to use an input method editor (IME), make sure you select it when you add the input language. For more information, see Add an input language.
    You can edit documents in multiple languages by changing the language (the input language) in which you type. Input languages are included with Windows, but you need to add them to your list of languages before you can use them.
    1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
    2. Click the Keyboards and Languages tab, and then click Change keyboards.
    3. Under Installed services, click Add.
    4. Double-click the language you want to add, double-click the text services you want to add, select the text services options you want to add, and then click OK.
  1. Change your input language to the language you installed. For more information, see Change your input language.
The input language is a setting in Windows that controls the language you use to type information on your computer. Before you can change an input language, you need to add that language to Windows. For more information, see Add an input language.
To change the input language
Click the Input language button on the Language bar, and then click the input language you want to use.
93d5c617-b1ec-4138-a1ff-973e71de80fe.pngLanguage bar gl_ico.png Note
If you don't see the Language bar, right-click the taskbar, point to Toolbars, and then click Language bar.
  1. Change your keyboard layout to the desired layout. For more information, see Change your keyboard layout.
You can customize your keyboard for a specific language or format by changing the keyboard layout. The layout controls which characters appear on the screen when you press the keys on your keyboard. Some input languages have several keyboard layouts; others have only one. For example, you can change your keyboard layout from the English QWERTY format to the English Dvorak format. After you change the layout, the characters on your screen might not correspond to the characters on your keyboard keys.
Before you can change the keyboard layout, you must add the input language and keyboard layout that you want to use to Windows. For more information, see Add an input language.
Hide all expcol_imgs.png To change the keyboard layout
  1. On the Language bar, click the Input language button, and then select an input language.
  2. Click the Keyboard layout button, and then select a keyboard layout.
gl_ico.png Note
expcol_imgs.png To change the keyboard layout on the Welcome screen
On the Welcome screen, click the Keyboard layout button 0c181420-8a93-48b6-82b1-b2dc25fc01b5.png, and then select a keyboard layout.
TIP:
After you are done you can switch between Japanese and English very easily by manually pressing the on screen buttons or using keyboard commands like SHIFT+ALT to switch between Japanese (???) and the Alphabet.
May 04, 2011 | Compaq Keyboard
Not accepting product key input copied from my computer and alternative key as well for my windows vista ultimate .
The key on your computer works with the original restore cd's (dvd).
Google it & you'll find how to do (search for dell).
Oct 10, 2008 | Acer Aspire 5100 Notebook
How to set a static IP address in Windows behind a WRT55AG Router
Windows 2000/XP 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window appears, input control ncpa.cpl into the ?Open? field. 3. After the ?Network and Dial up Connections? or ?Network Connections? window opens, right click on the Local Area Connection or Wireless Network Connection which controls the connection to the router. 4. After the ?Local Area Connection Properties? or the ?Windows Network Connection Properties? window appears, click on Internet Protocol (TCP/IP) then click on the Properties button. 5. Once the ?Internet Protocol (TCP/IP) Properties? window opens, change the option from ?Obtain an IP address automatically? to Use the following IP address. Set the options under ?Use the following IP address? and ?Use the following DNS server addresses? to the following: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 * Default Gateway: 192.168.1.1 * Preferred DNS server: 192.168.1.1 6. Click OK then OK or Close. Windows 98/ME 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window opens, input control netcpl.cpl into the ?Open? field, then click on the OK button. 3. When the ?Network? window opens, locate the TCP/IP for the Wireless or Ethernet adapter in the PC, and click on it. Once it?s highlighted, click on the Properties button. 4. Change option from Obtain Automatically to Specify and input: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 5. Click on the Gateway tab, and input 192.168.1.1 into the ?Default Gateway? field and click the Add button. 6. Click on the DNS Configuration tab, then go to the ?Host Name? field and input Computer, then go to the ?DNS Server Search Order? field and input 192.168.1.1 then click the Add button. 7. Click OK then OK once more, then windows will prompt for a restart.
Feb 16, 2006 | Linksys WRT55AG Router
ViewSonic N4785p 47 in. LCD TV Logo
115 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
