Question about eMachines W4685 PC Desktop
I replaced my ram and now my monitor won't work. I took out the new ram, put the old back in and still no monitor. Everything I read mentions video card...where is that?
    Brigadier General:
  • 8,909 Answers
Being eMachines it is probably on board VGA. You can check by looking to see if the VGA lead to the monitor plugs into a VGA card or the motherboard.
Unfortunately it may be caused by static discharge when the RAM was replaced if you didn't observe anti static precautions.
Hope its a VGA board fault but if you install a VGA card and turn off the on board VGA that will work.
Hope that helps.
Posted on Dec 30, 2010
Dell inspiron 560 problems
chek your video card it my be going out
Apr 30, 2013 | Dell Inspiron 560 PC Desktop
Not getting any video from a msi 880gma-e55 integrated video motherboard
This may sound simple, but make sure the monitor is set to correct input. Many are auto detect, but you never really know.
You could also check BIOS for onboard video. Disable if you have an add-on video card. Enable if you don't
Reseat the video card if it an add-on.
Jan 08, 2013 | MSI Computers & Internet
I put new ram in my emachine 5210 why won't it work
If it was working before you put the ram in, then the ram you put in is the problem. Maybe you put in a ram that is not compatible or is bad.
Put the old ram back in to see if it works.
Go to 4 All Memory to make sure you get the memory that is for your computer.
Go to 4 All Memory at:
http://www.4allmemory.com
Jun 08, 2012 | Computers & Internet
I made some mods/upgrades for Gateway 835 GM (Started with RAM -2GB Sticks- , Video Cards, & Finally CPU because of the sudden not wanting to display anything on my screen! PLEASE READ & REVIE
Here is what I would do, depending on your board go to what the brand is and download the BIOS again flash it if you do not see the BIOS at the startup. If you do see the BIOS then you will need to install the drivers for these components you replaced. Depending on which operating system you are using. Win XP you will have to load drivers from the driver disks that came with the product replacement or search for one online. If you have Win 7 it should pick the drivers up through Windows Updates load them without them or a running BIOS your shot in the dark. Your computer has to have a BIOS and drivers to run the hardware you replaced. Just because you had them before does not mean it will operate. correctly. Make sure your components are the correct ones for your machine. Just because ram fits does not mean it is the correct ram. So get BIOS up again from there boot from C: reload Windows then re install the whole operating system and be sure to load drivers and updates. That is how I would proceed with this issue. John
Apr 08, 2012 | Gateway 835GM (835GH) PC Desktop
My fujitsu scaleo p tower won't display anything on the monitor! The monitor works fine with other devices.... everything spins and all LEDs light up just no output to the monitor :/ any...
Have you tried putting the Graphics card in a Different slot? If you have and it is still not working most-likely it means that your video card has gone bad and needs replacing.
Jul 11, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Installed upgraded RAM in my HP Pavilion a1030n. Now computer will not power on even with the old memory put back in. what's wrong? Everything was fine until I unplugged the computer. I took off the...
YES. The slots are for different kinds of memory. ONLY use the 2 new cards and insert them into the SAME colour slots. You should NOT mix memory types. Forget the old modules.
Feb 14, 2011 | HP Pavilion a1030n (PS585AA) PC Desktop
No Signal To my Monitor and no beep.
First refix the RAM and Pci graphic card.
Pull cmos cell from mother bord for 15 minutes then put again into its position then all settings are defaults.
Then if still face problem then check with other RAM.
Aug 13, 2009 | Computers & Internet
I have a Compaq Desktop computer. Model# DPS-250RB A. The computer was working fine the other day, Brought it to my house and tried hooking it up to a monitor and the monitor wont recieve signal. Not sure...
hey,,
try this,
1.) unplug the system
2.) remove the memory
3.) remove the mainboard battery(cmos battery)
4.) press the power button 5 times
5.) replace the battery
6.) replace the rams
7.) boot it up
8.) enter setup
9.) load defaults then save and exit
if that works then try putting back in the graphics cardm you may need to repeat steps 1 - 9 after installing the graphics card. and pls insure the monitor is connected to the graphics card.
Jul 22, 2008 | Compaq Computers & Internet
I put in some more ram now???
I've had this happen before, the RAM module you just put in is defective. Put the old one back in and see if it works. If so, take the RAM back and get a new one.
Aug 25, 2007 | Dell (E210882) Motherboard
eMachines W4685  PC Desktop Logo
134 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
