Question about Project Audio Players & Recorders
Dear Sir I have a new Pro-ject 6 PerspeX TT. I have a problem with the seating of the motor in the plinth. When you attach the Sorbothane pad and its metal holder to the bottom of the motor and place it in the plinth the entire unit sits slightly too high. The result of this is that the square-cut drive belt rubs on the pulley flange and the belt vibrates badly and makes a rather loud grating noise. It also gives rise to a serious sound flutter. I have tried to fix this numerous times by putting the pad on and off the base of the motor but cannot solve it. This is all you can do actually. The only thing that makes the belt run true is if I push the power cable to one side out of its channel, which then has the effect of lifting the motor slightly thus curing the problem. The belt then runs true, silent and no flutter. However because after this so-called ?fix? the motor is not sitting absolutely securely and absolutely flat in the plinth. Switching it on and off makes it wobble a bit which is really not satisfactory for a precision instrument. Either the pulley has been assembled slightly too high on its spindle during manufacture or the pad underneath and its holder are not accurately formed. It is a pity there is no height adjustment on this pad and its metal holder to adjust the run of the drive belt. You are stuck with what you get in the box. Considering what an incredible precision set up the arm requires (hours with those cotton gloves, spirit level, Alignit tool and all that) it seems a really cavalier attitude of Project to the motor placing and fixing I thought. Really rough and ready. Not at all a precise design. The height of the pulley is absolutely critical to the true running of the drive belt which is a vital component of course. Anyway I don't think it should remain like this and am not happy about it. Not having the motor sitting dead flat as designed may put a strain on the bearings which may wear too quickly over time. Any ideas? Warranty? Have any of you ever encountered this problem before?
    Sergeant:
  • 432 Answers
Offcourse it's warranty , they deliver a defect unit, so don't wait and bring the whole buch to the store, and infact, if you noticed at the beginning when you just had the unit and called them, you have the right for moneyback. They deliver a broken unit. How long do you have it allready with the problems?.
Posted on Oct 22, 2014
djproaudio
  • 515 Answers
SOURCE: Loose / wobbly platter?
This is a common problem. If you have another 1200 turntable, switch out the platters and see if that fixes the problem. Usually, the problem does not carry over.
There is nothing to screw or tighten. You can install a new SPINDLE - and it should fix it. But might not be necessary if you just swap your platters out.
- OPTiC
DJ PRO LAB
Posted on Apr 21, 2008
djproaudio
  • 515 Answers
SOURCE: Leveling Turntable
Yes, shims are fine, but just remember, shims are prone to movement. Why don't you bring all the feet to their maximum setting, then adjust from there. Perhaps the table it is sitting on needs the shims?
- Davis
DIGITAL ANALOG THERAPY
Posted on Jul 02, 2008
  • 5 Answers
SOURCE: SL-1200 MK2 Tone Arm Oxidized and Height Adjust
EXCUSE ME! PLEASE FORGIVE YOURS TRULY!!. I mis stated something. Vinegar NOT mineral oil to clean the oxidation. You are correct in the type lubrication. A dry-teflon is best in this application. A minor adjustment in the balance of the arm may be needed. Any chemical used on electronic ckts other than the one that replaced the freon type could be harmfull but any lube used directly on the mechnanics is welcome. You may choose a syringe to apply the small amount in exactly the point of need. This is a well known procedure in the medical field on laboratory equipt.
Posted on Sep 18, 2008
  • 5 Answers
SOURCE: Optimus lab 1100 Turntable won't turn!
The mechanics in your arm postion is throwing the switch. A mechanical postion switch has sliped out of postion, a arm from the toner arm post has moved to an encorrect postion, or if your turntable has a multi-album play abilty your 'next to play record' post postion sensor switch is out of postion. Last or first is your belt could fool ya. Your belt may have a weak spot on it in turn no friction underload.
cdj repairs
  • 68 Answers
SOURCE: Tone arm skipping/not moving on especially at end of record
It sounds like you have a tone arm tracking problem, this may have to be re-aligned.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 13, 2008
I bought a Stanton T.52 turntable, but I need a belt. I've done some searches but can't seem to find anything. Where can I buy a belt?
Stanton is a hell when it comes to parts, just via a dealer is the best solution. But have you first tried to get the grease and dirt of this belt? and offcourse the poulies (round metal or plastic it spins on)degreasen. Do you use a clampweight or so..? Kind of waste of money and don't forget that the motor in this pricerange ain't a strong one is, which spins at a perfect 33, the st.150 is also cheap built and if you go for the music quality i recommened pro-ject or rega. Those have nice beginner hifi tables with a way better arm for 400 euro's new and pro-ject has the option to upgrade it , by give them the arm you use and buy the more expensive/better one for way less. And those sound way better then a stanton. The needledoctor.com sells a lot gear http://www.needledoctor.com/Pro-Ject-Debut-Carbon-in-Light-Grey?sc=2&category=352. but this table comes included 2mred , which i also have, but your records needs to be real clean, so i use them seldom:). And i have checked the side where i sometimes buy vestax gear, but yours wasn't between them. Just go to a dealer and they get one for you or check ebay.
But first try to clean it well, a little oil on it and your grip is gone.
Goodluck, greetings richard
Feb 08, 2014 | Stanton T52 Turntable
Driver seat will not move
HI Tracey, first thing to do is check the connector below the seat... make sure car is off and negative battery terminal is disconnected, the peak under the seat and check for any loose connections. If all is ok, reconnect battery and check fuses. Sounds too new for this to be a motor issue. Hope it helps.
Jan 27, 2014 | Audi Cars & Trucks
How do I replace a fuse on a pro-ject turntable
I have a question, who says which it's the fuse, since i've written the psu and the motor of your table and or it's placed it the motor or psu, but i can't find a thing a about fuses and it wouldn't suprise me, since it's a very cheap table... perfect valuable for value btw, but a replacable fuse.... Can you open the powersupply and watch if it's srewable, if not then it's a chinese cheap powersupply and have you contant you salesman for a new psu. Though i like them a lot , nice arm and the om5e souns oke also .. gr rich
Jan 12, 2014 | Project DEBUT III Turntable
TT-R 125 E leaks fuel out of the float bowl drain line.
Hi, Anonymous and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
TTR125 dirtbike leaking gas from carburator overflow tube AR15 COM
TTR 125 Fuel Overflow Problem
http://www.yamaha-motor.com/assets/service/manuals/2007/LIT-11626-20-01_ttr125all_1961.pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-tt-owners-manuals
Oct 17, 2013 | 2004 Yamaha TT-R 125 E
Mi Gemini TT 03 dejo de girar repentinamente , el motor al encender intenta correr pero no tiene la suficiente fuerza.
¡Hola
Su velocidad de motor de control de circuitos electr?nicos dentro se ha da?ado. Hay un control de velocidad de circuito regulador dentro de contro motor a diferentes velocidades. Hay transistores que se regula el voltaje que se suministra al motor. Cualquier transistor se da?a este tipo de falla ocurrir?. Apenas consiga que le den mantenimiento por cualquier technican servicio con experiencia. Si usted es el sonido en el servicio equipemt electr?nico que usted puede hacer por ti yoursef. El fallo se encuentra en su regualtor velocidad de circuito impreso hallen a bordo. Aceptar
Jun 29, 2011 | Philips gemini TT-03 Turntable
Pro-ject Debut III with USB turntable - produces high levels of distortion and static - why? (Has an internal pre-amp, so gets plugged into line level inputs. Is properly grounded. Line level input...
which pre-amp do you use, since the pre-amp and usb are cheap made components, especially pro-ject, i was amazed which low quality pre-amp i bought for 250 euro.
Dec 25, 2010 | Project DEBUT III Turntable
How do I reconnect hose?
1. Bend or put on back side the appliance and remove the three screws which secure the plinth to the lower part.
2. Remove the filter door
3. Remove two screws
4. Release the plinth
5. Turn it
6. Remove the plinth
6259706-vsmw15pk1kyieti0geqgsykn-3-0.png Dado
Oct 03, 2010 | AEG L76800 Front Load Washer
I have a pro-ject 1.2 turntable . i can feel the motor is running but the it does not turn the belt . the pully that is attached to the motor will not turn the belt . the subplatter turns freely when i...
First I assume you have replaced the belt and it didn't work! If not do so!! Next with the motor running, belt on etc, see if you can turn the turntable with your hand. If you can't, then the motor is working fine and the mechanism is jammed up. If you can the motor is faulty or not getting enough power. A check with a volt meter will tell you that.
Aug 28, 2010 | Project Audio Players & Recorders
My pro-ject turntable is playing very very slowly.....I have changed the belt but no change....is it likely to be a motor problem?
I'm unfamiliar with Pro-Ject turntables, but the following genral advice will still apply:-
With the drivebelt disconnected, does the platter rotate freely with little resistance?
If not then the problem is the spindle bearing (may just need cleaning and re-lubricating with light oil). Some turntables allow you to remove the platter and re-lube the spindle, others have a sealed-for-life bearing where the only option is to replace the bearing. If you have the latter type then take the bearing to a specialist bearing supplier as they'll provide an equivalent replacement for far less than an official manufacturer spare. It will likely be exactly the same part without the branded packaging anyway.
If the platter rotates freely and becomes very much more difficult with the drivebelt attached then you have a motor problem. Try a tiny drop of light oil at each of the spindle bearings: if this fixes it then the motor bearings may just have dried out or may be on their way out. If not then look to the motor brushes and either the motor commutator (if the DC motor has an AC supply) or slip rings (if the DC motor has a DC supply). These items wear over time and lubricating them can make things worse as the lube traps dust and bits of debris to become a conductive grinding paste. If you have a commutator then clean it thoroughly with a Q-tip (UK=cotton bud) moistened with a little white spirit or lighter fuel, and then use a cocktail stick to clean out any muck lodged in the gaps in the commutator. The motor brushes which contact the commutator/slip rings are usually made of graphite and on some motor designs they can be removed, inspected and if need be replaced, but on many small motors worn rings/brushes mean that the motor must be replaced as a complete unit.
If the motor used is an ultra-modern brushless design, then there will be no rings or brushes to cause faults but there will be a motor controller circuit which can go wrong. If so the controller needs either to be replaced or to be tested and repaired by an electronics technician. Note that brushless motors can still suffer with spindle bearing issues though.
I hope that my posting has been of some assistance and ask in return only that you take a moment to rate my answer.
Jan 24, 2010 | Maytag MMC5000 Microwave Oven
198 people viewed this question
Top Project Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Project Audio Player and Recorder Expert? Answer questions, earn points and help others
