Question about Hitachi NR90GR Cordless Round Head Gas Framing Nailer
Hitachi nr90gr..... I cleaned the gun and the fired another 500 nails and it suddenly stopped working(the fan) full fuel and battery...took back off and noticed I had pinched the fan wires and they severed. I soldered back.. but nothing works now
  • 3 Answers
SOURCE: Hitachi Framing Gun Not Firing - Bad Battery?
Does the fan run and the light blink ont he nailer? I have one that I just bought. I put in the wrong type of nails and got one stuck. I had to take the front apart to clear it and now the damm thing wont fire. The green light blinks and the gas cartridge is basically full, even the fan does run after I release the push lever, but no fire???
I wonder if yours is the same as mine did fire for a couple nails first just fine then got jammed...
I will try to charge the battery more.... MAybe like yours it needs a strong charge for the spark...
Russ
Posted on Oct 05, 2008
  • 23 Answers
SOURCE: My nail gun hitachi nr83a2 only fires a nail half way
the blade assemblies for the A and A2 are the same.
the pison bumper should not be attached to the driver, if the bumper is moving around inside the gun i suggest checking to make sure it was properly seated when the gun was reassembled. if it was, i suggest ordering a new bumper.
a cracked bumper will usually cause a broken driver.
Posted on Nov 17, 2008
  • 1383 Answers
SOURCE: Hitachi NR83A air leak
Most all Hitachi nailers that use the plunger style of firing/safety mech will leak air past plunger (part #877-339) when firing, however should not leak when connected to air or resting. If air is leaking past plunger when connnected to air check following:
Remove head to reveal cylinder plate (part#877-318). Remove plate and check outer oring for nicks or broken. If nicked or broken, replace and problem solved. If in good condition, remove cylinder guide (part #877-310) and check two outer orings for nick /cut. Use caution when removing/installing cylinder guide. It is easy to pinch orings when installing causing air leak at plunger. If orings are in good shape then problem is warped body of gun not allowing outer orings to seal. To check for warped body, use the cylinder plate as a guage by lowering it into the area where the cylinder guide rests. Good Luck with your repair.
Posted on Mar 12, 2009
  • 131 Answers
SOURCE: Sparks when shooting a nail
It is common to see sparks. It is metal striking metal. Although, if it sparks alot. It could be a chipped driver blade and the nail would not drive all the way. Does your sink `em?
Posted on Aug 26, 2009
  • 885 Answers
SOURCE: hitachi nail gun,piston/nail push rod
You have one or more worn o-rings in the head of the gun. They direct the air to the proper parts of the gun to first drive the nail then to return the driver to the top of the gun for the next nail. Depending on the manufacturer and your model number, some companies make kits to replace the o-rings (always replace all of them). For some companies you have to get a breakdown of the gun and order each o-ring seperately.
Posted on Oct 25, 2010
I've got a hitachi 2nd fix nail gun and for some
First thing is , when did You clean it last?
Sep 30, 2014 | Tools & Hardware - Others
Looking for the nearest repair shop for paslode nail gun in Northren Va
Have all the nails been cleared out of the tool where they were jammed? If not take the fuel cell out of the tool, and remove the battery before working on it. If still persists come back to this website for further help.
Sep 19, 2014 | Omega Paslode 901000 Impulse Cordless...
Hitachi nail gun
If gun firing but nails not being driven could be one of two basic problems:
1. Nail jammed in magazine not allowing nails to move up.
Empty magazine, does follower move to top of magazine. Push gun against work piece, does fan motor start? Yes - jam in magazine or lock out bar not operating. (this would allow nail un to fire when out of nails)
2. Piston/driver not returning fully after firing, hence driver blade on top of next nail instead of behind it. This could again be caused by a jammed nail or just a nail head. Another case of not returning is the combustion chamber not making a good seal, check O rings on framer (they are steel rings on bradders) it may just need a good clean it is surprising how dirty they can get and if not cleaned a build up of dirt could break a seal. If not been cleaned for a long time worth checking piston rings, worst case scenario dirt builds up around the rings and stick fully in requiring new piston if the rings will not come out.
Nail guns work on the principle that an explosion pushes the piston driver forcing a nail into the work piece, after the explosion a vacuum is created and it is this that 'sucks' the piston/driver back up the cylinder.
Mar 27, 2014 | Tools & Hardware - Others
Nail not firing, battery charged, fuel cell good,
When you took it apart to clean it, you may have piched off the large brown o-ring on the head valve. To check this, take the orange head valve cover off and push the gun downard onto a piece of wood as if firing it. Watch the o-ring to see if it clears all the metal fingers around the fan.
Dec 20, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode shoots a few nails and quits
try a new battery m8 when they have been used fir a while they wear out at the catch and when u fire the nail gun the battery works its way out enuf to stop it making a good contact. Hope this helps.
Aug 11, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Russ
Sep 28, 2008 | Hitachi NR90GR Cordless Round Head Gas...
Hitachi NR90GR Cordless Round Head Gas Framing Nailer Logo
51 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
