Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Code "door" when setting CLEAN cycle.
  • 65 Answers
If it is OPEN IT IS RIGHT IF IT IS CLOSE IT IS WRONG
Posted on Dec 30, 2010
F9 error code appears within two hours of self clean cycle
F9 error code on GE ovens is usually caused by a problem in the door lock/latch system for the self clean. You state it happens about 2 hrs into the clean cycle. My guess is the the control is not sensing that the door is actually locked. Could be several reasons. Bad door lock motor, Bad switch that senses the door is latched, or is some cases the main control board could have a problem and is just not reading the door is locked. You need someone with the right knowledge to trouble shoot which part is actually bad since it could several different problems.
Mar 10, 2015 | GE JTP75 Electric Double Oven
We have a 24" wall
The problem is due to the door latch and specially one of the two micro switches is not contact properly that is why when you cracked little the oven can work little better. So all you need is check the latch at the back and if nessesary replace the latch
Also you can find a new latch at the links and here
Sep 19, 2011 | Kenmore Ovens
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
Frigidaire oven, set over to Clean and during the clean process had a power failure. LED has "LOC", cannot open oven. I have powered oven off and back on to no avail.
one thing you could try is to set the oven to clean and see if the clean cycle will turn on then push cancel/off and see if the door opens. IF that doesnt work the door latch failed and must be replaced. to open the door ya have to pry open the latch by usinga wire hanger and try to slip it between oven door and top and pull to the left side to open latch
Good luck,
Gene
Aug 06, 2011 | Ovens
Cannot find my manual and would like to know how to use the self-cleaning part. I held the button down for "lock", but the door did not lock, and where do I go from there?
Give this a try:
1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds. Momentarily (less than 5 sec.) press CANCEL key again to remove error code display. 2. Program and start the Clean mode. Observe to see if door locks. If it does not, inspect the locking mechanism from the solenoid to the latch pawl and door to find the cause of the problem. If the door is not locking, then 1 minute from the start of the Clean, the F5 E1 code will again be displayed. Press CANCEL key to remove error code display. 3. Once any mechanical problems with the latch mechanism have been corrected, program and start a Clean cycle (after, if necessary, clearing F5 E1 error code) to ensure proper operation of the door lock. Immediately cancel the Clean mode to observe proper operation of door unlock.
If this doesn't help try this link to locate the right model:
http://www.whirlpool.com/catalog/category.jsp?categoryId=76
Feb 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Oven is finished cleaning but the door says "locked". The panel just shows the time and "locked" in red, under it. Help
I have Jenn Air oven S136-C with a locking bar. After cleaning cycle wait for the oven to cool down and the lock light will go out (but the oven is not yet unlocked.)
Set SELECTOR knob to OFF
Set TEMPERATURE knob to CLEAN
Press CANCEL button (on right) twice.
Slide the locking bar to the left and the oven door will open
Jan 16, 2011 | Jenn-Air JJW8530C Expressions Collection...
40494 / 40495 / 40499 Electric Single Oven: have a kenmore self cleaning electric range it was...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Wife was trying to clean (self cleaning oven) and after setting timer the oven door will not lock and it will now not let us do anything now and it shows a f9 code and when i press bake control, dr shows...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%^&^%^%
Dec 14, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
