Question about Blue Flame Charmglow 30K BTU NG Vent Free Space Heater
Charmglow CGL300TQ Keep shutting off after a minute???
Not too familiar with this product, but it looks like a vent free heater. ALL vent free heaters are required to have an ODS pilot light. These pilots monitor the oxygen level in the room and if it detects a low oxygen level, it shuts down the whole heater. This is what I think is really happening. And the solution is simple. Near the rear of the metal tube where the pilot light flame comes out, you will find two very small holes. If these holes get even a little plugged up with dust you will have this problem. Just get a can of air or use an air compressor and blow air through these holes. I bet that this will solve your problem. It is also a good idea to keep the area around your heater clean and free of dust. I have a free standing gas log heater and at the start of each season I take the logs out and vacuum everything, inside and out, and also underneath the unit. Then I use my air compressor to blow out any remaining dust, especially around the pilot light, and of course, I then blow air through the two tiny holes in the pilot light tube. Since I started doing this, I have not had any problems with my heater.
Posted on Nov 17, 2012
2 Suggested Answers
  • 10 Answers
SOURCE: charmglow model cgl300tq. cannot seem to get
You will need a manometer to determine your gas pressure, the amount required is posted on your appliance. Take both a static and dynamic reading on the inlet side of the gas valve. If it is not high enough consult a plumber. If it is take a reading on the manifold side. If the gas pressure is too low again consult a plumber. If it is within spec check orifaces and burner tubes if any for debris and spiders.
Posted on Mar 07, 2010
I have a Charmglow CGL300TQ gas heater and it will not stay lit over night. How do you figure it out and where can I buy parts for it.
Contact Charm glo thru their website and ask tech support .I do not recommend DIY for gas appliances as 1 mistake is deadly
Dec 02, 2016 | Heating & Cooling
Charmglow ventless lp gas fireplace model CGL300TQ pilot light wont stay lit, how do i know if its thermocouple or regulator?
if the therocouple has packed up pilot light will not light thermocouple has long small diameter pipe leading to a larger end this needs to be above the pilot flame also for safety have a small bowl of soapy water with a brush wet the nut with soapy water in no bubbles appear then try lighting heater thermocouples don't last that long
Jan 26, 2013 | Rheem 36" Water Heater Thermocouple Kit
I have a Charmglow propane heater model CGL300TQ with a bad fan. Where can I find parts for this stove and does Charmglow have a website for parts?
Depends what is actually wrong with fan, if tis the blower barrel part you can by replacements but if its the fan and you van't find manufacturer try an commercial or indutrial fan place to match the one you have be careful to make sure that it is electrically compatible and that it will connect to heater safely and do as old fan did as fan speeds on heaters can be important
Nov 17, 2010 | Stoves Heating & Cooling
Charmglow model cgl300tq. cannot seem to get enough gas to make ignition! i keep pilot inlet tube clean. how can i tell if it is the regulator. it is definitely a gas flow problem!
Mar 06, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
Charmglow electric fireplace bad remote control
Here is the home site for Charmglow - you could try to call them and see what they say. I would hope they want to keep their customers:
Charmglow Products 3701 Charlotte St, Pittsburgh, PA 15201-3201 (412) 683-6434 .aBtnGetDir { display:inline-block; width:107px; height:22px; text-decoration:none; vertical-align:bottom; cursor:pointer; } .aBtnGetDirLeft { float:left; height:22px; width:92px; overflow:hidden; font-size:0.85em; background:transparent url('http://sp.ask.com/sh/i/a11/shared_sprite_06.png') no-repeat -99px -401px; color:white; font-weight:bold; text-align:right; vertical-align:middle; line-height:22px; } .aBtnGetDirRight { float:left; height:22px; width:15px; overflow:hidden; background:transparent url('http://sp.ask.com/sh/i/a11/shared_sprite_06.png') no-repeat -301px -401px; }
Dec 12, 2009 | Kitchen Appliances - Others
Missing instruction manual for Charmglow Electric Turkey Fryer
Fry turkey 3 minutes per pound, then add 5 minutes to total cooking time
Nov 26, 2009 | Kitchen Appliances - Others
Burner on Charmglow patio heater will not stay on.
believe it or not, the propane tank may be too full. The vapor space is taken up and you have very little vapor. Run some warm water over the tank. The garden hose may be enough but if you get no frost line the water will need to be warmer. The warm water causes the liquid fuel to turn into vapor. Do not use boiling hot water. Another thing is oening the valve. Most propane tanks have safety valves. If the gas escapes faster than a normal rate, the valve closes. Open the valve slowlyand lt it burn for about 10 minutes before opening the valve further. It will get better as the fuel is used up and the vapor space in the tank increases. In real cold climates a heater blanket, sleeve is used tho keep the bottle warm. The vapor also creates the the needed pressure to move the gas through the system to the burners. Good Luck-Ned_
Sep 15, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Charmglow gas grill is not generating as much heat as it used to
potatoes should take about 30 minutes. if your grill is not hot enough un hook the tank and hook it back up again as you have a safety valve partially closed
Jun 07, 2009 | Brinkmann Charmglow 810-7400-S Propane...
Patio heater keeps shutting off
Returned it to Home Depot, paid $50 for upgrade to "better" unit.
Sep 28, 2008 | Coleman (5040B750) Patio Heater
Blue Flame Charmglow 30K BTU NG Vent Free  Space Heater Logo
794 people viewed this question
Top Blue Flame Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Blue Flame Pool and Spa Expert? Answer questions, earn points and help others
