SOURCE: LOCKED displays when attempting to eject disk from SA-HT670
i have a panasonic SA-HT720 and it displayed locked anytime i wanted to eject discs so i found out that dad27's solution was the best and holding down the stop and power buttons also locks the system as well as unlocking it. God richly bless u dad27 u really helped me out
SOURCE: green tint?
you have a bad video cable and its only allowing green and not red and blue, if changing the cable does not do the trick the you video controler in the dvd player or stereo has go bad, might try pluging dvd player into tv directly. that will help you determine if its the player or stereo. good luck
SOURCE: cd tray won't open
get it serviced as it happens due to the old band or ring kinda thing in the tray which aids in opening of it.
SOURCE: Panasonic SW-9571-CYY Ejects DVD RAM Cartridge.
Hi, I don't know if you ever solved this problem - but I had the same thing on my SW9571CYY. The solution is to replace the small drive belt inside the drive ( It is very thin and doesn't seem up to the job it has to do). Just remove the two screws on the rear, then the seven screws holding the plastic cover with the springs on it (don't worry - everything stays in place). Lift the disk tray out and the little belt is towards the front. I used an old belt from a broken LG GSA-5163D that was lying around. I think it would be difficult to find the correct spare so some people have even used a "O" ring with a slightly smaller diameter than the original belt.
Hope this helps Dwane4444
SOURCE: Panasonic PV-D4743S combo DVD/VCR player won't eject DVD
I was having the same problem a few months ago. I had another vcr on top of the unit. My son told me nothing should be on to and sure unough when I took the weight off it worked just fine. Hope it works for you.
