Question about Watches
How do I get the back off to put a new battery in? What type battery does it use?
How do i remove the back of my nautica wrist watch to replace its battery
You don't, you take it to your local jeweller who will remove the back and put in a new battery for between $8 and $15 depending on the type of battery, silver oxide or lithium. All done whilst you wait or shop.
Dec 13, 2017 | Nautica Watches
How do i change a battery in a quick silver watch (Viper YO15DV )
  • Remove back
  • Find battery mounting. Note mounting arrangement and polarity for future.
  • Identify battery type.
  • Obtain new battery
  • Remove old battery. Install new.
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your watch to a jeweler who, for a reasonable sum, will replace the battery
Take your watch to
Nov 29, 2016 | Watches
Battery size for emporio armani ceramic ladies watch
  • To determine battery type: open back
  • Locate battery holder and identify type. Note battery mounting
  • Place opened watch in plastic bag to keep it dust-free while you obtain a replacement battery
  • Remove watch from plastic bag and install new battery
  • Check operation
  • Install back
Finally, reset watch as necessary
Aug 28, 2016 | Emporio Armani Watches
How to replace battery in Skagen 585XLTMXB watch ?
  • Remove back
  • Find battery and identify type. Note mounting arrangement
  • Obtain replacement of correct type
  • Remove old battery. Install new battery
  • Check operation
  • Install back
Aug 09, 2016 | Skagen Watches
What size battery does a Gucci 6800L use?
  • Remove back
  • Identify battery type and note installation
  • Install new battery correctly
  • Check operation
  • Reinstall back
Aug 07, 2016 | Gucci 6800 068510 Wrist Watch
How to change battery on disney accutime watch and what type of battery is needed. Thanks!
You won't know what battery it takes until you pop the back off and see what battery is in there. I've opened two identical watches and on the inside they had different movements that required two completely different size batteries. The trickiest part with Disney watches I've done is if it's musical, getting that to reset. Be careful, a lot of people don't realize how easy it is to mess up those tiny little parts, get dust in there, put the back back on wrong etc...
Feb 04, 2014 | Watches
I bought a watch and we can't get it to work. We think the battery needs to be changed.
If you take a look at the back of the watch, look for screws holding on the back plate. If there are screws (usually, if they are there there is one in each corner -- unscrew them. If there are no screws in the back of the watch, look VERY carefully at where the backing for the watch connects to the front piece of the watch. There should be a small indentation somewhere along the rim -- use a knife or a small screwdriver in that groove and pop the watch backing off.
Once you have the back of the watch off, you will see the battery right there. Sometimes they just pop out (held in by the watch back) ... sometimes there is a small piece of metal holding it in (in which case you should try to rotate the metal piece off the battery -- don't bend it).
Once the battery is out, take it to a store that sells watch batteries and match the battery type exactly (a lot of watch batteries look the same, but you need an exact match). Put the new battery in, cover it with the metal tab (if there was one) by rotating the tab back over the battery like you found it. Put the watch backing back on (and replace the screws if there were any).
Hopefully, that will kick start your watch for you, and you should be all set :-)
May 24, 2011 | Cars & Co Disney Pixar Cars Mcqueen Analog...
Hello i'm trying to get the back off to put a new battrey in i have ian daniels with a braclet type band ladies
Check out directions here:<br /> <a href="http://www.watch-batteries.com/Changing_a_battery.htm">http://www.watch-batteries.com/Changing_a_battery.htm</a><br /> Best regards.<br /> Jewel
Aug 30, 2010 | Watches
Casio g-shock protection model blank face after new battery installed by a jeweler
What kind of battery did they put in it?? G shocks are powered by a rechargeable solar battery!!! Should not have been replaced unless it was the same type of battery. I would be going back to jeweler and asking them to send your watch to Casio and they pay for the new solar battery. Let me know what happens.
Aug 19, 2010 | Casio G-Shock 800D 7V watch
POD watch battery replacement. No problem removing back of the watch - (waterproof / 4 small screws), however the battery is held in place under a ''cage'' type of cover and not the usual single spring...
Unscrew the screws holding that contact. Memorize where each screw was - they can be different in length. Fit new battery, put contact back in place and screw all screws back exactly where they were. After that you may need to shortcut battery's+ and AC point (marked on movement) for resetting your watch. Use tweezers to do that. Rate me, plz.
Feb 02, 2010 | Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
