Philips TV 27PT543S37A
The tv trys too turn on but wont and if you keep turning it off and on the pitcher starts too come on with the sound also then goes off but the power button light stays on but no sound or pitcher. any help would be great.
  • 2 more comments
  • gooman666 Jul 10, 2008
    it won't turn on When plugged in you hear a high frequeny beeping
  • prc413 Oct 12, 2008
    Original problem was that power would have to be turned on and off a few times before picture/sound would come up. Eventually it would not turn on at all. No humming or buzzing noises occur. Not before it stopped working or now. The green power light is the only thing that comes on. We think it may have to do with High voltage Power source but where it is located or it's part # we have no idea
  • Anonymous Nov 01, 2008
    gaaa i need this tv for movies
  • ctgardengirl Dec 06, 2008
    takes many tries to get the tv to stay on. First 2 or 3 times, there's alot of clicking noises, like it's trying to click on, but can't. No pic or noise, finally after 10 or 12 more tries, we get a a white flash in top center of screen, then off. So the next 3 or 4 tries, (at about 10 second intervals) we finally get a pic, but wiggly, overlapping letters, finally the next try or 2, the screen straightens itself out properly, but (my) right side of screen is waving a bit, not clear to edge - that straightens out eventually too. Always the same side, never the other. Seems to take even longer to turn on if the room is colder. Would love to have some help here, before junking it and never buying a Philips again...
I'm having the same problem with the tv going on and then after a few minutes it goes off but then when I try to turn it on I hear a few clicking sounds and then it goes on for a few seconds. how come?
Posted on Aug 21, 2009
Ctgarden girl, my set does the EXACT same thing! I too wondered if a cold room was an issue. The set is only 4 years old, and I didn't have this problem in my old place where the room was a lot warmer.
Can someone please help?!?!?!?
Posted on Dec 07, 2008
Element tv model elgfw551 how to fix pitcher keeps going out
If you wish to get some details; check the site linked here. Pull up older posts.
Feb 18, 2016 | Element Televison & Video
My phylips tv screen is zoomed after some time now it is not showing pitcher and turn of
The main digital processor board has the fault. In rare occasions, a software update might make this right. Contact the nearest authorized service center for Philips. Check this link too.
Sep 29, 2012 | Philips 6000 Series 32PFL6606 32-inch...
I have an TV Phillips L01-1UAC-7638, the issue is, when I turn on the TV, after 15 or 20 seconds the TV turns itself off, but if I change the chanels the TV does not turn off, I mean if the TV is showing...
Hi, you don't mention the full model number, there should be a number on the back of the TV something like this 27PT543S37A, the problem you have seems to be fairly common and if this is your model number you could try this, on philips model 27pt543s37a will not power-up without changing channels for 5 minutes, transistor number 7461 is leaky between collector and base - needs to be replaced, and a capacitor rated 47 uf (microfared) at 25 volts, should be upgraded to a 47 uf at 63 volts, with a temperature rating of 105 degrees vs 85 degrees.
Hope this helps, I am assuming that you are able to use a soldering iron etc.
If you have no experience in electronics/soldering or how and where to get parts please consult a TV technician, dangerous voltages can lurk about in a tv even when not plugged in so please be careful and if at all unsure leave it to the people that know!
Feb 09, 2011 | Televison & Video
#27PT543S37A philips tv model-the tv video channel is not working
In short your tv has a problem on the AV connection, RF using coaxial cable is working okay.
get the tv to the w/shop, let him check the AV panel and AV processing IC.
Apr 30, 2009 | Philips Televison & Video
Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
if you have back ground of tv repair, remove back cover but you need tools and tester, check heater line from crt ckt board going to horizontal section.
Apr 03, 2009 | Philips Magnavox TP3285C 32" TV
The tv wont turn on
no high voltage take to tv shop
Apr 02, 2009 | Sony KV-36XBR400 36" TV
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0081 1149 1154 0288 0456 0003 0008 0068 0075 0086 0087 0141
Feb 12, 2009 | RCA Universal Remote Control
TV randomely turns off
it may just be a static buildup from the dust.
open the tv and blow it out with a air compressor.
if that doest not work then the circuit may be overloading.
remember it stores a charge for days.
Feb 17, 2008 | Philips 30PW9817 30" TV
Philips TV model number 27PT543S37A
TV turns on but doesn't stay on goes in and out then blank screen. LED light stays on during the entire time your problem is called hunting you can check power supply of your tv .It common problem in Philips T.V. Thanks
Sep 11, 2007 | Panasonic CT-32SX12 32" TV
Televison & Video Logo
349 people viewed this question
Top Televison & Video Experts
