How do I fit a fan belt on a JCB Mk 11? - Computers & Internet
    Scholar:
    New Friend:
  • 125 Answers
Undo the bolts on the front crank pulley and the drive shaft should slide forwards on the spline to give enough space to get the new on in. Whilst doing it put a second one in place and tie wrap it out of the way so you can fit it easily next time
Posted on Jul 24, 2013
Dodge Stratus R/T fan doesn't come on while car is running and car is getting hot.
FAN NOT WORKING
It can be issue with faulty motor or its faulty fan control relay.
Bother are to be inspected.
Test volt at fan relay and fan motor.
For more help, I suggest you to go through the troubleshooting links mentioned below:-----
Click the link below: ------
How to replace Cooling Fan on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cooling-fan-on-acura-car.html
OBD Code P1490 low speed fan relay ckt open-short
http://schematicsdiagram.blogspot.com/2012/11/obd-code-p1490-low-speed-fan-relay-ckt.html
Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works?
http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
Hyundai Sonata cooling fan not working
http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html
Fuel pump relay and cooling fan relay troubleshooting on 1997 ford thunderbird?
http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
Fan belt routing diagram for 2004 Volkswagen Jetta?
http://carbeltrouting.blogspot.com/2011/12/fan-belt-routing-diagram-for-2004.html
Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
A/C, heater, defroster fan, not working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Blower fan not running on Isuzu trooper?
http://technoanswers.blogspot.in/2012/02/blower-fan-not-running-on-isuzu-trooper.html
How to replace blower motor fan assembly on 2000 GMC Yukon?
http://repairhelpcenter.blogspot.com/2012/01/how-to-replace-blower-motor-fan.html
Heater AC or defroster fan not working on KIA?
http://technoanswers.blogspot.in/2012/02/heater-ac-or-defroster-fan-not-working.html
These will help.
Thanks.
Nov 27, 2012 | Cars & Trucks
Fan won't work
Bother are to be inspected.Test volt at fan relay and fan motor.-------------
For more help,i suggest you to go through the troubleshooting links mentioned below:-----Click the link below:------
------------These will help.Thanks.
Does the platter of the vestax PDX-2300 mk 2 fits on the vestax PDX-2300 mk 1?
Hi ezradf ,
i am afraid no it will not fit, the PDX-2300 mk 1 has a bigger fitting then the Mk 2.
Mar 19, 2011 | Vestax PDX-2300 Turntable
Printer is asking us to 'install MK 700' What
It is telling you that it needs a Maintenance Kit fitted.These are fitted every 500,000 A4 pages.
Nov 22, 2010 | Kyocera Mita FS 9100DN Laser Printer
Installing water pump in 97 cavalier 2.2
Hi. Here's the proceudere on how to replace the water pump of your 97 Chevy Cavalier.
•1
Drain the cooling system. Place a large oil drain container under the drain fitting located on the bottom of the radiator. Turn the drain fitting counterclockwise until fluid is draining from the radiator. Use a pair of pliers to turn the drain fitting if you cannot turn it by hand. Turn the fitting clockwise to tighten it after all of the fluid has drained from the radiator.
•2
Remove the cooling fan. Disconnect the electrical connection from the fan motor. Remove the bolts holding the fan assembly to the radiator support with a ratchet wrench. Pull the fan assembly up from the engine compartment and remove it.
•3
Remove the serpentine belt. Place a wrench over the belt tensioner and rotate the tensioner to release the tension on the belt. Pull the belt off the pulleys and remove it from the vehicle.
•4
Remove the water pump pulley. Place a screwdriver behind the pulley to lock it in place while removing the pulley mounting bolts with a ratchet wrench.
•5
Disconnect the coolant hoses running to the water pump.
•6
Remove the water pump mounting bolts with a ratchet wrench or wrench and remove the water pump from the vehicle.
•7
Clean the mating surfaces of the engine block and new water pump with a towel saturated with lacquer thinner.
•8
Apply a thin layer of RTV sealer to both sides of the new water pump gasket and place the gasket on the new water pump.
•9
Place the water pump against the engine block and finger tighten the water pump mounting bolts to hold the pump in place. Tighten the bolts with a torque wrench to 18 foot-pounds.
•10
Place the pulley on the water pump and install the water pump pulley mounting bolts with a ratchet wrench.
•11
Attach any hoses previously disconnected from the water pump.
•12
Install the serpentine belt. Route the belt over the pulleys according to the routing diagram in the engine compartment. Place a wrench over the belt tensioner and rotate the tensioner to tighten the tension on the belt.
•13
Install the cooling fan. Gently lower the cooling fan in position and install the mounting bolts attaching the fan assembly to the radiator support with a ratchet wrench. Attach the electrical connection to the fan motor.
•14
Refill the cooling system to the appropriate level, start the vehicle and check for leaks around the water pump.
All the best!
Nov 10, 2010 | 1997 Chevrolet Cavalier
How to replace a water pump on a 1995 bmw 318is
  1. Disconnect the negative battery cable. Drain the cooling system.
  2. Remove the distributor cap and rotor. Remove the rotor adapter, the dust shield and the distributor housing.
  3. Remove the fan. The fan must be held stationary with tool 11 5 030 or some sort of flat blade cut to fit over the hub and drilled to fit over 2 of the studs on the front of the pulley. Remove the fan coupling nut; left hand thread-turn clockwise to remove.
  4. Remove the belt and pulley.
  5. Remove the rubber guard and distributor and or upper timing belt cover.
  6. Compress the timing tensioner spring and clamp pin with the proper tool.
Observe the installed position of the tensioner spring pin on the water pump housing for reinstallation purposes.
  1. Remove the water hoses, remove the 3 water pump bolts and remove the pump.
To install:
  1. Clean the gasket surfaces and use a new gasket.
  2. Install the water pump in position. Note the position of the tensioner spring pin. Torque M8 bolts to 16-17 ft. lbs. (20-24 Nm) and M6 bolts to 6-7 ft. lbs. (8-10 Nm). Connect the hoses.
  3. Release the tensioner from the holding pin. Install the upper timing cover. Install the pulley and tighten the bolts to 6-7 ft. lbs. (8-10 Nm). Install the belt and tighten.
  4. Install the fan, distributor housing and dust shield. Tighten the rotor adapter to 39-47 ft. lbs. (55-65 Nm). Install the rotor, O-ring and cap.
  5. Add coolant and bleed
Dec 30, 2009 | BMW 318 Cars & Trucks
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
