How do i reseat the prv on a ferroli f24b boiler?
    President:
  • 1,515 Answers
Hi, any pressure relief valves i have ever worked on, can't be reset. They are there to release water pressure that builds to high. If they continue to leak if you have discharged it, you can tap on it to see if you can get it to seal, or just replace it if it continues to run or drip water.
Sincerely,
Shastalaker7
Posted on Dec 30, 2010
How do I set the heating timer on a Ferroli Modena 32C HE boiler?
I did a Yahoo search for "set heating timer on Ferroli Modena 32c HE boiler" and got this -
http://www.ferroli.co.uk/brochures/Timer-HE-013001X0-Instructions.pdf
If you can get to that site, it will let you download a PDF which seems to answer your question.
I copy/pasted the hyperlink, but you may have to enter is yourself. My last hyperlinks did not work.
Sep 12, 2017 | Heating & Cooling
Alpha cd28c boiler loosing water and pressure through pr valve when heating is on,and when then switched off needs repressuring to use heating again.no obvious leaks.new pr valve been fitted.pressure
I assume losing pressure through the PR means Pressure Relief Valve (PRV) or temperature pressure (TPR). Open in TPR may mean boiler is overheating/overpressurized. Open in PRV means the Pressure Reducer/Fill Valve in the fill line of the boiler is broken.
House Water Pressure in a home is 30/40 PSI min to 60-80+PSI max.
Boiler PRV/TPR are set at 30 PSI open (SYSTEM PRESSURE) so too high a house water pressure will open the PRV/TPR. Replace the reduction regulator on/in the fill valve assembly
Oct 20, 2014 | Water Heaters
Ferroli boiler optimax he 38 c.Powers up ok,no hot water,no error code.Think its an ignition problem.Heating flame not showing?????
Is there an error code? If not the flow sensor for the hot water could be faulty. Also if you've had a power cut depending which model of Optimax HE you have, you sometimes have to tell the boiler it's a Combi, as they have a generic Pcb fitted which is also used on the system only boilers.
Sep 26, 2013 | HQRP Universal A/C Remote Control...
The wifi connection from worcester boiler to room thermastat Honeywell Cm921 , boiler not receiving signal
Can't help you directly, but Honeywell will have user instructions on their website.
It's something like holding the 'stat within a metre of the boiler when the batteries are inserted. Best to RTFI.
Jan 27, 2013 | Heating & Cooling
Ferroli boiler 31 che will not light up when hot water switched on notice in windowe says no ca or no co
are you getting no ca or no co on the time clock? if so change the time clock
May 16, 2010 | Heating & Cooling
Ferroli otc settings
this sounds like the boiler is in comfort mode press the eco/comfort button once and eco will be dispalyed on LCD. also check terminal 3 and 4 have no wires on the terminal strip as this is were the OTC is connected to boiler.
May 02, 2010 | Heating & Cooling
Why does my Ferroli HE31C keep switching off code A3.
Here you go, page 30, sounds like it's overheating, possibly a problem with the boiler stat or lack of circulation in the system. http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Apr 06, 2010 | Water Heaters
Dirty injectors on a Saturday morning in an isolated village
WHEN YOU NEED CLEAN I NEJECTER YOU MAY BE CLEANA ONCE DRUM IN WATER+ HCL CIRCULET 15MIN
AFTER CIRCULATE CLEAN WATER
ALSO CIRCULAT WATER+ EDTA+ SMBS POWDER
YOUR INJECTER WILL 80 % PER CLEAN
Mar 06, 2010 | Water Heaters
Ferroli optimax 31c
Here is a link to the manual.It shows fault codes.
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
Ferroli DOM F24B Is leaking from the two 22mm pipes on the secondary heat exchanger
Yes, this is a common problem on the domi compact. unfortunately ferroli accept no responsibility if not in warranty period! can be a costly repair..
Apr 21, 2008 | Heating & Cooling
Heating & Cooling Logo
198 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
