Question about Cabela's Cabelas Pine Ridge 3 X 9 X 40 Rifle Scope
I have a Pine Ridge 2-7x32 (3x9 Variable) Rifle scope that I purchased From Cabela's a few years ago. I am haveing a problem with the Rear Locking ring for the Focus optical. It will NOT lock, it just keeps spinning. What do I do to have it Repaired ? I can be reached at Albert.Calcaterra@Gmail.com THankyou in advance for your attention into this matter, I have and still am a long time customer of Cabela's.
  • 5 Answers
SOURCE: Remounting a rifle scope, Luepold 3X9 with Luepold rings
hey jerry when ya renount a scope ya just want to tighten all the screws evenly when ya do this ya want to start with right front then left rear then left front right rear you do this till its as tight as you can make them without striping screws when your done you should have even space at all the rings good luck and i hope this helped ya
Posted on Mar 02, 2009
  • 2418 Answers
SOURCE: i have a redfield 3x9 rifle scope and looking for tips on sightin
Yes thats about all there is to it, adjust in small steps and tap on the barrel of the scope with a screw driver handle (light taps) after each adjustment before firing the gun.
Posted on Nov 15, 2009
  • 44 Answers
SOURCE: I have a Redfield 'LO-PRO' rifle scope, 3X9
It doesn't sound like anything's broken, it sounds like the scope has shifted in the rings, as you said "they are not straight up and down anymore", which won't effect your accuracy at short ranges, but if there's long ranges (more than 100 yards) you're going to be off some.
You can loosen the ring screws until the scope will turn, either 2 or 4 screws that hold the two halves of the ring together. There are numerous tools to help you align the crosshairs, but when I do this job I just square-up the reticle (crosshairs) by looking at the center of the reticles and let your eye follow the bottom crosshair down and make sure it is centered on the back of the bolt or receiver. If you need help doing this job, take it to your local gunsmith, he'll be able to square these up for you and boresight it.
Hope this helps, Mark the Gunsmith
Posted on Jan 03, 2010
agent91
  • 2100 Answers
SOURCE: I just purchased a savage .17 HMR with a cabelas
A quick and easy way to bore sight your rifle, if it is bolt action only, or an AR, mount the rifle in a cardboard box with cutouts so it will sit without tipping, remove the bolt and sight down the bore at a target 100 yards away, a mail box, or the corner of a building, make sure the rifle doesn't move, then peek through the scope, it should be seeing the same target your bore is seeing, if not, adjust your scope to it, if it won't travel that far, shim the front with pieces of 35 mm film. then check it again, if you can get it to stay there, it will put your bullet on paper at 100 yards.
Posted on Mar 09, 2010
agent91
  • 2100 Answers
SOURCE: Where can I get a sun shade for a Bushnell Banner
Check out this website. Hope it helps.
http://www.bushnell.com/products/scopes/riflescopes/instruction-manuals/
Posted on May 04, 2010
Have a pine ridge rimfire scope need to know what mounts i need to atttach to a marlin 60
1 inch dovetail mounts medium height if your marlin 60 has 11 mm dovetail rails . if not will need to get receiver drilled for rail mounting and mounts of your choice better to get a competent gunsmith to do it
Jan 18, 2014 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
I dont understand what the extra dial on my new 6-18x44 scope is for or how to use it.Or what range evry line and dot in the reticule should be ranged in at.
The third turret is for parallax and approximate range
And the lines on the reticule are round and velocity specific plus magnification comes into the distances between substension
On my scope 100 yard zero the next substension down is 176 yards at 10 magnification
The best way to use the reticule for ranging is to get a ballistics program and enter rifle round and scope stats and get a chart for that round and reticule
And the drop chart will change for different velocities and ballistic coefficients of rounds and temperatures a summer chart will be different to a winter chart due to denser air in the cold
Apr 14, 2011 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
I purchased a Fujinon 3.5-10X50 rifle scope a few years ago and mounted it on a Remington 7 MM Mag. I am unable to pull a group less than 12 inches at 200 yards and have not been able too since installing...
It is most likely the mounts not the scope. I would just install it on the new gun and check it there. Most times a scope that wanders is the mounts. One thing with big scope is they need to be tight or the recoil will move it in the mounts. Next due to being tight when the gun heats up it can and will tweak the scope in the mounts enough to move your center. Try it in your other gun, try 3 shot groups and let the gun cool. Recheck your center. If it is good with a cold gun all is well. If it moves from one day to the next it is the mounts. If you count the clicks to recenter, come back the next day and move it the same clicks, it is the mounts. If it is all over the place, day after day it is the scope.
Jan 21, 2011 | Fuji non 4-12x42mm Rifle Scope
Which knob you adjust for drop? What is the left knob for?
If you have 2 knobs, there should be no left knob. If you have a knob on the left, you have it mounted 90 degrees out of alignment. Loosen the rings and turn it 90 degrees clockwise. Once you do that, the knob on the top is the one you will use for elevation.
If you have 3 knobs, the left one is for parallax adjustment, focuses the scope for specific ranges. the top knob is the elevation adjustment in this case also.
Sep 20, 2010 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
I have a bushnell sportview 45 3.5-x10x45 WA brand new in a box what is the value
The scopes are fairly cheap, I think it retails for $140, that was a few years ago. But not much more than that. It is not a quality scope, more of a utility scope. Hope this helps.
Aug 13, 2010 | Bushnell 3-9x38 Sportview Rifle Scope...
I just purchased a savage .17 HMR with a cabelas pine ridge 3x9x40 tactical scope and I'm having problems siteing it in. It is shooting aout 4 inches low regadless of adjustments I try and make.
Mar 07, 2010 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
I have to use reading glasses to use a simmons blazer rifle scope.....othewise the image is blurry.
You can't see the cross hairs or the whole picture is blurry? I know that the rear ring on the scope will bring the cross hairs into focus, glasses or not, and the scope itself should be clear all the way down, I can't see a thing either without glasses and it has really hampered my shooting. It ain't no fun , it's frustrating. Try turning the rear eyepiece, see what happens, hope this helps.
Feb 27, 2010 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
Got moisture in scope and it is fogged up
take it into a camera shop, they will have the tool,, but if you undo the scope it will need to be regased again the "o"ring seals have worn out or broken and thats how water got into it,, it also let the nitrogen out of it,,,if its a cheepy scope buy a new one,,,
what i mean by a cheepy is less than £1000,,,,
Nov 16, 2009 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
Cabela's Cabelas Pine Ridge 3 X 9 X 40 Rifle Scope Logo
141 people viewed this question
Top Cabela's Optics Experts
james laughton
james laughton
ROBERT B KEELER
Level 1 Expert
Are you a Cabela's Optic Expert? Answer questions, earn points and help others
