Question about Pool & Spa
My dreamaker spa is leaking. The water level has gone down about 8 inches in a couple of days. It has been running, so the temp is about 101. Any ideas, I already checked the jet fittings, they are tight.
My lazy spa pump unit has water coming out of the vents in bottom of unit any ideas please
Posted on Apr 18, 2011
  • 310 Answers
It is most likely the shaft seal on the pump itself. Costs about $115 to have replaced, labor included.
Posted on Dec 31, 2010
  • Anonymous Dec 31, 2010
    how do I go about getting it fixed? The weather here in st louis is going to turn cold again, can it be repaired when it is below freezing?
  • adam hudson
    adam hudson Jan 03, 2011
    This repair can be done in any weather. I would recommend finding a reputable service tech in the area to replace the seal. If you are interested in doing it yourself next time, you can watch him/her so that next time you will know how. This seal will fail every couple of years typically, and if not replaced, will cause alot more damage.
I have a leak in my hot tub spa and i don't know where the leak is. How do i fix a water leak if I am not sure where it is?
It's a pain, but try this to locate the leak. Empty out all the water. Then put back a couple of inches of water and watch it to see if goes down. Use a black crayon to mark the level. If it doesn't go down add some more, mark the level and watch for a change in level. Keep doing this a bit at a time until you notice a loss of water. This will give you a better idea of where to look for a crack especially if the back side of the tub is covered with foam.
Sep 07, 2017 | Pool & Spa
Spa light will turn on and I can turn the temp up, but I can't turn temp down. Anyone else have this issue and were you able to fix it?
sounds like you have a bad keypad. turn the breaker off for a few mins and back ON and set to the desired temp.
Dreamaker is back up and running and has a great parts dept. they are just down the street from my shop.
http://dreammakerspas.com/product-category/parts-accessories
Jun 07, 2017 | Pool & Spa
How do I stop my swimming pool from leaking water?
id look 4 a leak someplace in the suction side of things when pump runs it draws air in hole so No leak but when pump shuts off No draw just water and it leaks out
look for hairline cracks in skimmer bottom and bottom suction lines , Might require scuwba equipent to see ?
Nov 03, 2014 | Pool & Spa
I have a dreamaker 8003 xspa that has worked perfectly over the many years that I have had it. The other day I noticed that the water had lowered 6 inches overnight an the water was coming out of the
1. Check equipment like pump, heater, blower, light fixture, for leaks.
2. Remove side panels closest to the are the leak is showing and inspect jets, plumbing in that area for leaks. If insulation is foam, remove any water saturated foam and follow it to the source of leak.
3. If the leak is in plumbing and is very slow, sometimes it can be resolved with "stop leak" products.
Aug 07, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
My pool is losing water when a Polaris 380 is running off a booser pump
plug both sides of Polaris hoses one at wall and one at Polaris if stops leak in Polaris line
Jun 08, 2012 | Polaris 380 In Ground Pool Cleaner
Spa kicks off in a cycle. needs to be reset
Dean,
Thank you for asking me to help you with your problem. However, this is either not within my level of expertise or the question is unclear or there is not enough information and I cannot help you at ths time.
Nov 25, 2011 | Jacuzzi Pool & Spa
I have a leak in my Dreamaker Eclipse hot tub. Within a few days, the water level drops to the bottom of the lower water jets then stops. We didn't use the tub last winter but I completely drained it...
Thats the problem with Dreammaker tubs, access can be a pain and theres no easy way of getting to the pipes.
I would usually gain acces from the underside which ensures that any holes that need to be made to gain access wont be visible in the future.
Good luck locating the leak.
Kind Regards,
Ian.
http://hottub.synthasite.com
Jun 11, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
When you first plug your dreamaker spa in the outlet,does the pump run all the time until the temp reaches 100 degree's? my jet button will not shut off the unit.
TURN THE BREAKER OFF FOR 20 SEC THEN TURN BACK ON AND FAST TURN ON ALL PUMP FOR 30 SEC THIS WILL BLEED ANY AIR TRAP INSIDE THE SPA
Nov 17, 2009 | Dream Maker Spas Pool & Spa
Pool & Spa Logo
625 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
