Question about Toshiba Computers & Internet
How do i plug in my printer? - Toshiba Computers & Internet
    Guru:
  • 679 Answers
Plug it to any USB ports in your computer if its using a USB cable. If its using an Ethernet cable it should be connected to your router's Ethernet port at the back.
Posted on Dec 30, 2010
How to connect a Ricoh Aficio 3228c to my computer as a printer
There should be different input and out put plugs on the printer somehwere. Like a fire wire plug or ehternet plug. Once you find the plug and cable, youll need to download the driver for the printer. You could just search your printer name and then driver on google.com.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
Apr 19, 2012 | Ricoh Aficio Office Equipment & Supplies
Blinking lights
Power off printer, remove power plug from printer, remove usb cable from printer, pull out paper and check for jams, check toner cartridge, clean area underneath the toner cartridge head, uninstall printer from windows control panel, reboot computer, plug-in printer with a different working usb cable, plug in power to printer, power on printer, reinstall printer driver. All in those steps exactly. If that doesn't work I would say you have a bad printer on your hands.
Nov 16, 2011 | Dell 1110 Laser Printer
How i do when my printer is no power
First make sure that the outlet where you are plugging in the printer has electricity. Unplug the printer and plug in a lamp or something else to see if the outlet has electricity. If it does not, then that is your problem.
If you do have power in the outlet, then plug the printer back in and make sure the printer cord is plugged in properly to the back of the printer.
If this does not help, then please send in the model number of the printer (it is on the machine) and we can continue to try to help.
Good luck...........................Pete
Jul 20, 2011 | Epson Printer
Cannot turn on the printer even if connections are ok ?
The only thing that could stop you from turning the printer on other than a broke printer is the power/power cord is not connected. The printer should turn on without a USB or parallel printer cable attached.
If no lights are showing when you try to power the printer, check the power connection in the back of the printer to ensure it is plugged in, check the plug into the adapter is connected and that the power cord's plug is connected to the wall outlet - if you have a power strip make sure it is turned on and the circuit breaker is not popped. Make sure that there is power to the outlet by plugging in something else to show it has power. If all of those check out ok and you have a meter, check for voltage at the power connector at the printer (pull the plug out of the printer and check voltage from inside the plug to outside the plug. It should be 18 vac.
If all of this is ok, there is something wrong inside the printer. Probably time for a new one as cost to repair is probably too high.
Oct 11, 2010 | HP DeskJet 810c InkJet Printer
I have not printer software
IF IT'S A USB PLUG ON THE PRINTER THE PC SHOULD RECOGNISE THIS PRINTER(PLUG AND PLAY)WHEN YOU PLUG IN TO THE USB ON THE PC.I HOPE YOU KNOW WHAT A USB PLUG LOOKS LIKE,OTHERWISE IT'S GOING TO BE DIFFICULT EXPLAINING.IF THIS FAILS YOU NEED THE SOFTWARE DISC THAT COMES WITH THE PRINTER.YOU CAN DOWNLOAD THE PDF FILE FROM THE PRINTER MANUFACTORERS WEBSITE.RUN THIS DISC IN YOUR PC AND IT WILL THEN RECOGNISE YOUR PRINTER.JOB DONE..REMEMBER SOME OPERATING SYSTEMS WON'T RECOGNISE THE PRINTER..
Aug 07, 2010 | Brother DCP 165C Compact Color Inkjet...
My Lexmark x9350 only turns on and off if I plug and unplug...
This, probably, is a power issue on the printer. Unplug the printer from the computer. Unplug the power supply from the printer (it's the black box behind the printer where the power cord is attached). Try not to use any power strips or extensions for the power cord. If possible, plug the power cord straight to the wall outlet. With the power cord plugged in straight to the power outlet, plug the power supply back in the printer. That should refresh the printer. When everything's powered on, plug printer to computer. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 13, 2010 | Lexmark X9350 All-In-One InkJet Printer
Samsung ML 2010 black and white laser printer is not read by any computer after proper installation of the hardware. During software installation, a window asks to plug in the printer and turn it on but...
Some printers require the driver to be loaded before connecting the printer.
Uninstall the driver and unplug the printer.
Reinstall the drive first, then plug in the printer when it asks for it.
Dec 05, 2008 | Samsung Office Equipment & Supplies
Where does plug go ?
Need to known what plug it is to answer that if its a usb plug it goes to the usb port but if its the big printer plug you would have a slot on the back of you computer box that would take that either a printer port or com port
Sep 16, 2008 | HP Deskjet F335 All-In-One InkJet Printer
Printer install
Hi this should be easy to do get the printer and plug the lead into the slot on back of printer then plug the other end into your computer their should only be one place it will fit in back of computer plug the lead in their might be picture of printer on back of computer it will be small and near a printer port.
The port in back of your computer is about 2 inches long or about 5 or 6 cm then plug the lead coming from printer into the port.
Now plug printer in and swtch on then switch computer on.
Now once your computer has started up you might get message new hardware found or start hardware wizard if you have disk that came with printer put this in your comp and follow instructions if you dont have disk let me know then i will talk you through the process let me know if your having problems ill be glad to help ok speak soon good luck but you should have no problems as its all plug and play and should set itself up.
If your printer is using usb port and not printer port then it will need plugging into any usb port on either the front of computer or back if you are unsure then let me know ok ill gladly help you ok
Feb 20, 2008 | Office Equipment & Supplies
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
29 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
