Question about Gaggenau ED 220/221 Electric Single Oven
Gaggenau oven shows a F-40 code with the key symbol flashing What are the commands that would normally remove the key lock??
3 Suggested Answers
milten1
  • 1304 Answers
SOURCE: door lock symbol flashes all the time
this may not be very helpful Gaggenau can be really tricky
ive seen this once before a long time ago but its worth a shot
the connection from the lock sensor might be loose
you should be able to unscrew the control and roll it up
right behind it you will see the lock and connections
jiggle em
like i said a long time but i believe the connection on the control board is green
Posted on Oct 08, 2009
  • 8 Answers
SOURCE: My Gaggenau oven shows a
I have the same problem and the technician came out and took the oven out. He couldn't figure out was wrong and will need to contact the manufacturer technician to help him with the diagnosis of the problem. In the meantime, he says it looks like my modem is not working and may not be responding to the commands that would normally remove the key lock after a power outage.
Sorry, can't be reset - you'll need to pay the big bucks to have a technician out to assess, make sure you tell him your model number so that he can do his homework prior to coming out, that way you're not paying alot of money that I had to for this tech to figure things out. He took one hour and charged me $120 with no fix and will have to come back anyway.
Posted on Nov 25, 2009
Won't start key symbol flashing
So do you need a manual for operating it ?
Oct 06, 2008 | Gaggenau EB290 Electric Single Oven
Why is it showing a key symbol, an error code f10 and the door is locked?
usually a key symbol means that the appliance is safety locked. usually by holding down a button for 3-5 seconds to lock and holding down the same button to unlock. a child lock safety feature.
Jul 20, 2015 | Gaggenau EB 270/271 Electric Single Oven
Bottom oven stopped working there is a key symbol showing on the panel what is wrong ?
There are a few reasons for this. One is the most obvious and that is the child lock switch needs to be engaged to unlock.Some models call it panel lock.
Turning the panel lock on and off:
To turn the panel lock on, press and hold the Panel Lock key for four seconds. The Panel Lock symbol will appear in the display.
To turn the panel lock off, press and hold the Panel Lock key for four seconds. The message in the display will disappear.
Oct 04, 2014 | Bosch HBL 5056 Electric Double Oven
My Gaggenau oven shows a F-40 code with the key symbol flashing. Can this be reset in any manner?
Nov 16, 2009 | Gaggenau ED 220/221 Electric Single Oven
Gaggenau EB290 built in oven - F10 code
If you really cannot find in manual, contact the manufacturer for guidance.
Aug 27, 2017 | Gaggenau EB290/291 Oven
Door lock symbol flashes all the time
jiggle em
Oct 07, 2009 | Ovens
Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Aug 21, 2008 | Gaggenau EB 270/271 Electric Single Oven
Gaggenau Ed 220/221 Error Code F 70
I had the same fault F70. Poured several liters boiling water no result. I decided to take the oven out the kitchen and put on the table. Be carefull, its edges are sharp. You need to disconnect water supply, first close the tap, then remove the water pipe from the oven by hand. Remove also the drain pipe from the sewage connection. You cannot detach it from the oven. Unplug power supply. Then start unscrewing the top panel. Once removed you can unscrew also the side panel left side (by looking at the oven from the front door side) and finally remove the back panel. You will need a special screw driver as the screws are star type.
I found out that there was some little water on the bottom panel of the oven. There is a safety sensor which is in contact with the bottom panel on the left side of the oven near the electronic board.
If this get wet, the faul code F70 appears.
Also some water was in the hole of the level sensor in the pump chamber next to the other sensor (white plastic box)
So dry all the water with the help of kitchen paper and finally with hair dryer.
Put back all teh parts and voila', it works again.
Feb 20, 2008 | Gaggenau ED 220/221 Electric Single Oven
Door locked after power surge/failure
The question here is how long did you leave the breaker off? Gaggenau ovens have a memory and I always advise turn the oven off for 5 mins before turning the breaker back on. Give that a try. The first thing the oven does when the power is reapplied is go thru a test phase which included locking and unlocking the door. The key symbol will go on and off during this. Sometimes you have to also can run a self clean then cancel it to reset the lock. This works as well.
Jan 06, 2008 | Gaggenau EB270 Electric Single Oven
Gaggenau ED 220/221 Electric Single Oven Logo
173 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
Oloyede Monsuru
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
