Question about Brookstone Slim Profile CD System CD Player
I can't operate the auxillary output option on my SLCDv2.0. How do I do this?
Auxillary button but no outlet
is this a RADIO question?
he dash glove box, operators guide ? lost?
Feb 20, 2015 | 2005 Suzuki XL-7
HOW CAN I CONNECT A MIXER TO A TECHNICS SA-DX940 AV
I used the manual downloaded from http://www.manuals365.com/technics/sadx940.html
Try using the final stereo output of the mixer as the input to the CD or Tape or VCR inputs.and use the switches on the fromt of the DX940 as necessary.
The specificatios state input sensitivity is 27 mY so your mixer needs a low output..
No reason it shouldn't work.
Sep 18, 2014 | Technics SA-DX940
HI-i have a coleman heat pump- on defrost it gives cold air- not normal. thanks
Do you have electric heat strips for auxillary or backup heat? When the heatpump goes into defrost, the electric heat strips or whatever your source of auxillary heat is, should come on to keep you from feeling the cold air. When the heat pump is in defrost it is essentially operating in the A/C mode, that is why you will feel cold air if the auxillary heat isn't working. You need find out why the auxillary heat isn't coming on if it isn't. It could be do to a bad seqencer or a burnt out element.
Mar 11, 2011 | Heating & Cooling
I have a remote start for my car (2005 Cadillac CTS). It has a picture of the car. How can I unlock the trunk from the outside of the car.
The APS 997A has two outputs for trunk release. The output and function button depends upon which wire the installer used. If he used the dedicated trunk release wire; press and hold (approximately 4 seconds) the green button that has a picture of the trunk and a key on the button. If the installer used the auxillary wire; press and release (1 second) the option button on the remote.
Oct 11, 2010 | Car APS997A Two-Way Remote Start and...
How do I enable the Auxillary option on my KDC-MP232 so I can play my MP3 player. I hooked it up using the aux. jacks in the back but it just played over the radio or cd player I do not know how to isolate...
when your car is on, turn the stereo off. you should be able to access a menu somehow when the stereo is off. in that menu, you should have the option to toggle the aux source on or off. simply switch it to on, then turn the sterreo back on, and hit the source button. it should now be ready to go.
Sep 10, 2009 | Kenwood KDC-MP232 CD Player
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
Overheating radiator
some bmw's have a electrical thermostat
May 07, 2009 | 1995 BMW 3 Series
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
Playing itunes through receiver
On the back of your tower you should have auxillary outputs that will go into your receiver. Get a connection going between the two ports and you should have perfect sound. The sound that comes out of your headphone output will not really have the amount of power that your receiver needs. Hope this helps.
Sep 14, 2006 | Marantz SR-5600 Receiver
216 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
