Question about Goodman CLQ36AR49 Air Conditioner
Condensation Leaking through unit
I have condensation leaking down through unit. This just started this year I replaced the fan motor this winter did I forget to replace something? I can see the condensation accumaliting in the tray but it never gets high enough to run through the pvc pipe. I am concened that the water will end up damaging the furnace parts under the coils.
  • Anonymous Jul 19, 2008
    I have the same problem
    Champion:
  • 254 Answers
This may be caused by an un level unit, or the A-coil itself may be un level did you move it when you replaced the fan motor? The second thing to check is the fitting at the condensate drain pan to make sure the weld has not broken or the fitting has not been stressed or bent and have a small crack.
Hope this helps Ya
please rate me
Posted on Jul 19, 2008
I have a problem with a Rheem Power Vent Water Heater shutting down due to condensation build up.
if it,s condensation....let it sit out side in sun to dry out well then bring it in start it and with a flash light look for leaks
Aug 13, 2016 | Rheem Water Heaters
I have a Kenmore Portable ac unit and its leaking from the back in the middle of the vent. I drained the unit,but it starts leaking again within minutes. Is there something wrong or could it just be too...
All portables, alllll, you have to put unit in
window with a slight tilt, as the unit runs
it creates condensation that condensation
is the water leaking out the back it's supposed
to do that, I have seen people hook a hose up
an let it drain in a bucket.
even your car a/c leaks water
Jun 03, 2014 | Heating & Cooling
Hi, I have an air conditioner Frigidaire which is leaking in the front. The unit is in a window, in a 4th Floor and I don't have access to the back, how can I unclog the unit??. I am desperate!!!!
if it's just condensation leaking out the front of the unit it could be that the unit is not level in the window. If it's tilted too far into the room it will leak condensation into the room. Try to tilt it back just a hair so that the condensation leaks out the back of the unit.
Sep 02, 2013 | Frigidaire Heating & Cooling
Does a A/C Condenser Fan Motor for a 99 oldsmobile Intrigue leak?
Condensation from the airconditioning system is supposed to leak out from the drain hose which runs from the interior, down to the exterior of the bulkhead can become trapped if that drainage hose has become blocked, or if it has become dislodged.
So the fan unit won't produce condensation, but condensation if not flowing out correctly can accumulate there on some models.
Nov 03, 2012 | 1999 Oldsmobile Intrigue
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
Leaking from inside box for few days , plumber said condensation built up to use fan to dry out.
If the water is coming down over the fan motor, you probably have a heat exchanger leak. If the heat exchanger is leaking, it needs to be replaced. The heat exchanger is the large copper box on top of the heater.
Oct 15, 2010 | Noritz Water Heaters
Water was leaking inside on passengers side, now
HVAC drain tube was blocked and condensation could not drain to the outside of the vehicle
as a result the water pooled inside the HVAC case leaking on the inside and killing your blower motor and probably blower motor resistor
clear the drain, replace the blower and resistor and you'll be back in business
Jun 08, 2010 | 2001 Oldsmobile Aurora
A/C condensation leaking into passenger side floor. 2005 cobalt
the condensate drain is plugged, pull the blower motor out and clean the drain, u will find it full of leaves.
Oct 06, 2009 | 2005 Chevrolet Cobalt
Condensation leaking out of unit
if it is the indoor unit leaking, make sure that all your drain lines are clear.... if you're talking about the outdoor unit leaking water in the heat cycle...that is normal.
May 16, 2009 | Intertherm P3RA-048K Air Conditioner
Ice build up out side hitting fan
pop out drain plug heat up pan with heat gun to melt ice
Nov 24, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Goodman CLQ36AR49 Air Conditioner Logo
122 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
