Question about Maytag Washing Machines
Water is leeking from the machine and is getting the floor very wet.
    Genius:
  • 1,028 Answers
Could be pump or seal above transmission ..remove front by lifting lid (a clip just in from each corner 2 screws at top of front cover )look above transmissiom after runs a few min also ckd pump ..have seen holes in hose from tub to pump and on rare occasion hole wore in outer plastic tubs usually right rear just below top edge
Posted on Jul 08, 2008
Noisy spin cycle and stuck on high
Spin solenoid could have water leaking onto it and it stuck on , but noise is most likely caused by bearing getting water into them,dose it leek water on the floor?
Jul 19, 2014 | Maytag Bravos MTW6600T Top Load Washer
Water in car
I suggest taking a garden hose and have someone spray your car while you are inside finding the leek stop the leek first .Take a house fan and an extention cord out to car, let fan blow on wet area until dry. another idea is to use a hair dryer. If you dont stop leek you will have a mold problem in no time. If this was helpful please leave good feedback.
Jun 28, 2013 | Cars & Trucks
Wher is it leaking
slide a piece of paper under the unit when the floor is dry, fill some water and peer underneath the unit, when you notice water drops this location will indicate your leek location, lay unit on its side and track down the leek
Jan 10, 2012 | Maytag Washing Machines
Not picking up dirty water off floor.
NORMALLY SUCTION PROBLEMS ARE CAUSED BY A POOR SEALING PROBLEM OR AIR LEEK. CHECK ALL BLACK RUBBER SEALS TO BE SURE THEY ARE SEATED CORRECTLY, NOT WORN OUT OR TORN. BE SURE FILTER AND TOP TO FILTER ARE IN PLACE, AND YOU MIGHT WANT TO LUBRICATE SEALS AND CONNECTION WITH A LITTLE VASILINE OR CRISCO IF YOU ARE A MOM LIKE ME. MINE IS WORKING FINE NOW, HOPE THIS HELPS.
Feb 06, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Why machine was leeking and someone told me to turn it off now what will i do it is still full of water
If you can move the machine by a outside door and place the drain hose flat on the floor to outside and machine should drain out.
Jan 20, 2010 | Hotpoint WMA40 Front Load Washer
My washer leeks water from bottom even when its not running and just sitting there. Seems after a wash the water hasn't totally drained out and then slowly starts leeking, actually alot of water is on the...
Have you checked the clamp on the drain hose? It may need tightening. All washers keep a small reserve of water in the bottom of the basket tank. If your drain hose hook is too high from the top of the washer, that much more water will be held below.
Aug 13, 2009 | Westinghouse Washing Machines
Water leeks onto floor occasionally.
hello.
Welcome to Fixya.
  • nspect the water supply connections.
  • Inspect the drain hose.
  • Inspect the water pump.
  • Inspect outer tub for cracks or corrosion.
  • Inspect the tub seal.
  • Inspect the tub bearing.
Good Luck.
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dirty water comes out when I stop scrubbing. Floors remain wet.
Try one thing... the filter cover must be clicked into place. I thought it just sat on top, but it has to be pushed into place.
FWIW
Mar 22, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Water leeking on floor
most fridges and freezers have a small outlet hole at the very back of the inside make sure this is clear should have a small tub at the back of your appliance on the outside try this
Aug 15, 2007 | Kenmore 62232 / 62234 / 62239 Bottom...
Water leaking from wash machine
It is probably a seal that is on or near the bottom of the tub. Dirt and grim wears at this seal over time. The leak is slow so it is hard to visually see.
Dec 09, 2006 | Frigidaire MWS939Z Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
