Question about Makita BO5010 5" Random Orbit Sander
Hi, my BO5010 spins like a grinder if it is not held tightly to the workpiece, can it be fixed? Thanks, Ope.
  • Makita Master
  • 885 Answers
Just under the sandpaper pad is a bearing that allows the pad to work as an orbital, that is it can turn freely, independently of the armature. If enough sawdust builds up around or inside this bearing the pad will spin like you describe and this is a fairly common problem with orbital sanders. You need Makita part number 211236-8 or a bearing #6002LL. It's fairly easy to replace; remove the screw in the center of the pad and remove it. Depending on which is tighter, the bearing will either be in the back of the pad or it will stay on the armature. Pry it off/out of the sander. Reassemble everything with the new bearing and you'll be back in business.
Posted on Dec 30, 2010
Testimonial: "A very good, to the point answer with good instructions. Thank you, Ope."
  • opie57 Jan 01, 2011
    Thank you very much , I took it apart and that bearing was froze up. I will order a new one and life will be good again, thanks, Ope.
When i changed the pad for the bo5010 the pad will tighten and the motor will stop. how do i fix this
You may be using the wrong size pad, especially if it's an after market pad. Get a OEM pad or see if there is any place on the sander to fine tune the tightness. Should be in the owners manual or get ahold of the manufacturer. It also sounds like it could be getting in a bind.
Nov 26, 2014 | Tools & Hardware - Others
How do i change a grinding wheel
Unplug the grinder. Remove the guard on the side you want to change. Grasp the wheel with one hand while you turn the nut with a wrench. Remove the nut and arbor washer from the arbor shaft, pull the wheel from the shaft and replace it with a new wheel - DO NOT remove the paper label! Put the arbor washer and nut back on, spin the nut down snug, grasp the new wheel with one hand while you tighten the nut with a wrench. DO NOT overtighten the nut.
It may help to grasp the SECOND wheel (which should still be tight) with one hand while you tighten the nut on the new wheel. It may also help to loosen & tighten & adjust the new wheel several times until it runs as straight as possible before you really tighten it.
After tightening down the nut, dress the wheel with a wheel dresser to get it to run as balanced as possible and give you a smooth round wheel so your workpieces don't bounce against the wheel and so it cuts freely. Repeat as necessary to keep the wheel cutting freely, and to keep the grinding surface flat.
Jul 21, 2014 | Hitachi GT15 BENCH GRINDER 150MM 6 INCH...
Can not remove the large spiral bevel gear
The large spiral gear is pressed tightly on the spindle then held in place by a wave washer and retaining ring. After removing the retaining ring and washer, you have to use a press to push the spindle out of the gear.
Feb 06, 2013 | Makita Grinder 115mm - 9554NB
I want to know the cost and the weight of 9-inch and 5-inch hand held grinder of 230volt single hase respcttively. thanks Kingsley A
I suggest you Google the Internet for these grinders. You can check the specs of the grinders from different manufacturers.
Dec 06, 2012 | Coffee Makers & Espresso Machines
Hi...I have a Black and Decker 4247 angle grinder that I haven't changed the disc on in YEARS...I can't remember if the clamp nut is right hand threaded or left...please help! Thanks lots!
Which ever way your grinder spins when turned on is the same direction the lock nut has to be turned to remove it. This makes sure it's self tightening when in use. More often than not they're right-tight, left-loose.
Nov 26, 2011 | Saws
I took my Starbucks Barista Conical Burr Grinder apart to clean it, and now I cannot seem to get the top burr back on. This is an old model, purchased in 2000, and has been running great. I used to manage...
I think when you fix the front burr then you need to loose the middle screw. Then it will fix easily.
But don't run it right away.gently tighten the screw and tight until you feel some tightness .Then start the grinder and tighten or loose it according to your grinding specification
thanks
please rate me
Apr 02, 2011 | Starbucks Barista Burr Grinder
Grinder not working
Hi, I had this same problem. Call Saeco and they will e-mail you detailed instructions on how to clean the grinder (2 page pdf file). The directions were great and it fixed our machine. Ours kept telling us to add beans, and the grinder continued to spin. It wouldn't load the beans into the grinder. once we cleaned it (completely) it worked fine.
Dec 27, 2010 | Saeco Magic Comfort Plus Espresso Machine
Need manual for craftsman bench grinder model # 257.191300. misplaced other one. hope you can help. mike
Mike
Not sure what was happening when the previous reply was created, but the owners manual is part number 211260001 $7.99 at SearsPartsDirect.com
That said, I'm staring at my own copy of the the owners manual and I can't really see why you would want to pay for one. The only really useful information is the parts diagram which is online at SearsPartsDirect.com. The rest is generic grinder information (support workpiece, select proper wheel, etc.) and CYA (always wear gloves and eye protection, don't remopve safety guards, don't use damaged wheels, don't stick your finger in the light socket, don't cross the steet in the middle of the block, etc.)
Jun 07, 2009 | Craftsman 6" Bench Grinder with Lamp
Trying to take apart a Kenmore Ultra Wash 665
normal threading on the screw, trick is totry to hold the impellar, while trying to loosenthe bolt, sometine placing a screwdriver in form the side, allows you to hold it
Mar 07, 2009 | Kenmore Dishwashers
Makita BO5010 5" Random Orbit Sander Logo
383 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
