Question about Bosch HMV9305 Microwave Oven
I have a Bosch Microwave, model # HMV9305/01 that turns on by itself. Does anyone know what the problem is?
  • boschmicrowa Dec 30, 2010
    Thanks, but it wasn't just the turntable and light. The microwave actually activates and cooks. Thoughts?
    Brigadier General:
  • 8,909 Answers
If one of the door interlock switches is not switching properly, that can cause the turntable/light to come on eventhough the "Starts" button has not been depressed due to the wiring of the switches.
Check for faulty door switches and/or contaminated actuators.
I hope that helps.
Posted on Dec 30, 2010
Bosch hmt9666 microwave plate stopped spinning while being used? Can't seem to find replacement part. Help needed
Try www.bosch.com contact customer support and the technical department, also check www.ebay.com type make and model of the microwave oven and scroll through the list.
Jun 15, 2012 | Bosch Microwave Ovens
Hi I have a BOSCH Innowave microwave only about 1.5 years old not sure of model number.... but the turntable has a massive chip out of it. Can I get the turntable replaced?
Yes! try Bosch online, they may provide a phone number or dealer close to your location, also! ebay is a great source for microwave parts, check out your local appliance repair man, and some TV repair shops.
Mar 19, 2012 | Bosch Microwave Ovens
Brand new microwave never used turns on for 2 seconds then shuts off. Model hmt5750. Callers customer support, they have no idea. Before I call a repairman does anyone have an idea I may try.
Take it back to the place of purchase and demand a replacement, you are covered under warranty. The problem could be caused by a faulty magnetron.
Mar 13, 2012 | Bosch HMT5750 Microwave Oven
Ge microwave OTR model HVM1750SM1SS turns itself on
There is a Web site dedicated to this issue. I am aware of a suit involving other older models.
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
That rule is even more important in this case.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It's actually a pretty easy do it yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
The part number to order is WB07X11056 and you can get it here for $130.51 plus shipping. (That compares to $189.75 direct form GE)
You can also find helpful exploded view diagrams at that link.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 31, 2010 | GE HVM1750SMSS Microwave Oven
Bosch HBC84K520B Combination Microwave Oven
If you google search bosch gourmet the second item down titled "bosch household appliances" you can download a manual from there
Jun 27, 2009 | Bosch HMB402 Microwave Oven
Whirlpool Microwave Hood combination Model MH6150XM turned itself on without anyone touching it. The oven and the fan went on. It continued to operate when the microwave door was opened. We unplugged...
Direct spraying of cleaners on the keypad and steam from the cooktop can short the keypad.
Luckily, it dried out. Sometimes it doesn't, and the keypad has to be replaced.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
Jun 22, 2009 | Microwave Ovens
Power out on Whirlpool over-the-stove microwave
Yes, There are fuses inside the keyboard panel. I would have to take a look at the manual for the specific model you have to identify the easiest way to check the fuse.
Before you go that far check above the hood and see if you can locate the plug end of the microwave. Most installations have a dedicated receptacle above the exhaust vent and microwave. It is usually a space too small for good storage so most housewives store small items and cookbooks in this space. It is usually the culprit for a microwave suddenly going out without someone placing metal inside the oven and heating it.
Heating a metal object or operating a microwave for an extended time will usually blow the fuse.
r_craig@basicisp.net
Jan 06, 2009 | Bosch HMT9626GB Microwave Oven
Bosch Microwave HMT8625 range - Microwave not working
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Jul 24, 2008 | Bosch HMT8625GB Microwave Oven
Microwave turntable is loud and clunky sounding.
If the unit is brand new as you say then it is covered under the warranty and the 800# for Bosch is in your paperwork that came with it.
It sounds like the glass platen (turntable) hub is either binding or else the drive mechanism itself either has a bad tooth on the main gear or tooth wheel. Some may still use a chain type drive mechanism as well.
If you call that 800 number - the customer service dept there will advise you as to what needs to happen next. It's possible they will either replace or repair at their expense.
Who installed the unit?
Let me know?
Best regards,
Frank
Mar 07, 2008 | Microwave Ovens
Bosch HMV9305 Microwave Oven Logo
151 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
