Question about Reebok 8050 ES Treadmill
The belt to run on the treadmill doesnt work. What can be done to get it fixed?
  • 77 Answers
Look for a repair person in your area. Se Treadmill Repair Directory
Posted on Jan 03, 2011
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
Why is the treadmill slowing down when you walk on it. It slows down when someone get on the machine.Is there a way to adjust the belts or anything that can be done to rectify the problem.
You have adjust the running belt of the treadmill. If you check the bellow added link you can find out how to adjust the running belt of treadmill. Almost all treadmill follow the same procedure. So if your brand mode is not listed you can follow the procedure of listed treadmill.
http://electro-medical.blogspot.com/
Sep 27, 2016 | Sportcraft TX 400 Walking Belt
Treadmill doesnt seem very fast
Run the software calibration for easy diagnose, and fix it.
However LUBE the deck belt with silicones or was. Read your owner manual, for to see what lubrication is your machine.
God bless you
Jun 04, 2013 | Weslo Cadence TS 310 Treadmill Motor...
Belt doesnt run
see the video how to lube the deck belt.
2) LUBE the rollers bearing too
3) Test the drive belt motor,
4) Test the input voltage motor, if there are the motor need repair see my personal TIPS for troubleshooting help
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram
God bless you
Nov 30, 2012 | Weslo Cadence G 5.9 Treadmill
Incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
May 08, 2012 | Exercise & Fitness
I have a horizon t73. Best treadmill ever but it now wont start. It turns on, electrical works, sounds like it going to run but the belt doesnt move. any ideas?
Dear Sir:
1) Tight the deck belt see the diagram 2) Lube the deck belt in according with the instruction manual maintenance. 3) Test the drive belt and replace it 4) Measure the input voltage for the main motor if there are the motor need repair or replace 5) Test the output voltage from the main motor board if there are NOT the board is faulty.
Apr 29, 2012 | Horizon Fitness T73 Treadmill - $1,299...
My T81 treadmill quit working. All of the lights and bells and whistles all work but the belt doesnt move and the incline doesnt move. Ive only had it for about 2 years. It was working fine before I moved...
you need to check voltage going to the motors. no power ,the contoller board is not working. check the connections on the boardmake sure they are in all the way,also the power connections
Mar 17, 2011 | Horizon T91 Treadmill
Belt doesnt work when I hit the start button
Sounds like the motor control board. Everything will work properly but belt want move. Clock will even start to count down.
Nov 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
Reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
May 28, 2009 | Reebok Vista Treadmill - RBTL13305
Belt slipping
Here are two solutions one is to get the belt centered on the treadmill and the other is to tighten the belt.
There should be two bolts in the rear of the treadmill, one on each side. These bolts adjust the rear roller of the treadmill. The walking belt will always go to the side that is looser. To get the belt back on track, (if you can start the treadmill so the belt is running) tighten the bolt on the side that the belt has slipped to. Tighten the bolt a little bit at a time. If you tighten the bolt too much, then the belt will go to the other side.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Mar 12, 2009 | Exercise & Fitness
Reebok 8050 ES Treadmill Logo
140 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
