Question about Kettler Sport & Outdoor - Others
How can I change batteries for satura m ext? - Kettler Sport & Outdoor - Others
Waste ink pad in the printer is saturaed
Stick a tooth pick in it and remove it gently. Then run water over it and squeeze it like a sponge to get most of the ink out. Reinsert it and you're done.
Oct 05, 2014 | Office Equipment & Supplies
2005 kia sorento change ext fuse and it keep blowing
I have a 2004 Sorento EX and my EXT fuse along with the stop lamp fuse kept blowing. The ext would blow as soon as I turned the vehicle on. The stop lamp would blow after a couple pushes of the brake pedal causeing me to have no rear lights at all regarding brake and the lights that you turn on at night. After much reading online in forums such as this, I was led on a chase looking for grounding wires, broken wires, dirty battery terminals, faulty altinator, and for a drl module. I could not find a drl module as I now do not believe there is one in sorentos, or at least in mine. I then came to the brake switch that is located on the arm of the brake pedal. I disconnected it, put a couple of new fuses in, started my vehicle and checked my fuses, and at last they did not blow! I reconnected the brake switch and checked the fuses and they had blown. I have a hunch that I am dealing with a faulty brake switch. Hope this helps
Jan 05, 2014 | 2003 Kia Sedona
Kettler satura E
adjust the REED switch, see t86730046-485d-474a-8ceb-85d98fb7bb10.giffdaff7b0-6cc7-4df5-ae11-dc8fbfad6f74.gifhe diagram attached. Clean the switch, tight the connecator very well, and test for faulty.
God bless you
May 22, 2013 | Exercise & Fitness
2008 Cadillac EXT. Do I need to do anything special to change the battery?
Never had an ext come in the the dealer, but have changed batteries on cts, escalade, dts, sts, and never had a problem. Land rover is the only 1 I've heard of that has that problem.
Dec 31, 2012 | Cadillac Escalade Cars & Trucks
Power drainning from battery overnight, i change
if you take lead off battery touch to positive pole with everthing switced off should not get a spark as they touch .if you do then something drawing power have to find it could be an old system in car like phone or alarm causing it
Apr 18, 2011 | 2000 Nissan Pathfinder
Lines ring to a certain group and I need to change a phone from group 73 to group 72 - how can I do this?
From Ext 10 or 11>
Dial feature 00>
Hit the left intercom button twice>
The display will show "System Programming"
To remove the Ext. from group 73
Dial #502>
The display will show 'Group"
Dial 3 for group 73
The display will show "Extension"
Dial the Ext # of the phone that needs to changed
Dial 2 to un-assign the Ext from Group 73
To add the Ext. to group 72
Dial #502>
Dial 2 for group 72
Dial 1 to assign the Ext to Group 72
Dial Feature 00 to exit System Programming and save the changes
Be sure to ask me if you need more information
Mar 16, 2011 | AT&T Lucent MLS-12D Phone
I am looking for a manual for our lucent phone. It is flashing replace system battery w/ power on. I don't know where the battery is. Also I would like to change the time. Any online manuels available?
The system batteries are located on the main processor card of the telephone system. there is a door on the lower end. behind the slide door are 2 AAA batteries.Replace them with the power on.
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
press feature "00" to logout
And finally here's a link to a Partner ACS 3.0 manual: http://www.wedophones.com/Manuals/AT&T/Partner%20ACS%20R3-0%20Programming%20and%20Use.pdf
Jun 11, 2010 | Lucent PARTNER18 Corded Phone
Dies with no warning after it warms up
if the computer is located in the engine compartment it could be overheating. the solution to the computer overheating is a new computer. expensive. I have seen this happen on other vehicles as well.
Jun 15, 2009 | 2003 Cadillac Escalade Ext
2008 satura aura
The Saturn Aura introduced a new bolt pattern for Saturn (and GM), 5-110. The SKY is the only other Saturn with this pattern. If you look to the extended family, the Chevrolet Malibu (2004-up), Pontiac G6, Saab 9-3 (current generation), Pontiac Solstice, Chevrolet Cobalt, Pontiac G5 and Chevrolet HHR use this pattern as well. There is also a very large selection of aftermarket 5-110 bolt pattern wheels.
Nov 02, 2008 | 1992 Saturn SL1
Sport & Outdoor - Others Logo
103 people viewed this question
Top Kettler Sport & Outdoor - Others Experts
Are you a Kettler Sport and Outdoor - Other Expert? Answer questions, earn points and help others
