Question about HP PSC 2175 All-In-One InkJet Printer
Will my hp2175 work as a network printer off my bt hub, the hub reconnises the printer by name but the laptop and desk tops will not
  • HP Master
  • 1,679 Answers
Chances are your PC already has old software and drivers installed which you need to uninstall and reinstall. This happens if there is a conflict between the drivers already present in your PC and the one you are trying to install for your PC to detect the Printer on network.
Click on the link below and download the latest drivers for your printer by selecting the operating system.
Download the Full Feature Software and run the downloaded file for installation screen to appear.
Driver Download
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Posted on Dec 30, 2010
Trying to find out the name of my network
Go to your router, on the bottom of the router (usually printed somewhere on the router) it will tell you your network name and default password
BT Home Hub SSID network name and wireless key Help BT com Help
As an example see the link posted.
Mar 15, 2015 | Computers & Internet
Connecting my Home Hub to Netgear to have wireless setup
3ee198b3c15f6ca7320d6cda56a651c7.png Netgear DG834G 54 Mbps Wireless ADSL Firewall Router Set-up Guide _________________________________________________________________________________________________ _________________________________
Oct 05, 2008 | NetGear DG834G Router
What's my network's name?
As an example see the link posted. BT Home Hub SSID network name and wireless key Help BT com Help
How do I connect my new BT hub 4 wirelessly to my HP F4580 printer
Keep Pressing the BT hub button until the light continuously burn. Search your BT name in the printer bluetooth device. connect it using the PIN 0000.
Dec 28, 2014 | HP Open Box Deskjet F4580 All In One...
Bt infinity installed and now hp 8500A printer not seen
You need to get the engineer back in there and fix it.
Jun 26, 2012 | Computers & Internet
My printer has stopped communicating with our BT home hub It was OK and the security code is correct it just cannot establish a connection. I tried it with the previous Netgear wi fi and it connects just...
you can also change the BT home hub 2.0(black)encryption type to WEP type. all you need to do is follow the steps to change the type of encryption to WEP.
  • connect a computer using the ethernet cable to the hub(its the black cable with yellow leads).
  • open an internet explorer or anyother browser, in the address bar just type 192.168.1.254.
  • you will be getting the BT home hub manager page with please reset your password, asking for three credentials.
  • in the first bar enter the default admin password or the admin password which is found in the wireless card or at the back of the home hub in the label. in the second and third bars enter the password of your own, something like admin1.
  • you will be getting another page coming with four options at the top (home, services, settings and troubleshooting).
  • click on settings, and below troubleshooting in the blue bar itself , you will see advanced settings. click on it.
  • then click on continue to advanced settings, now below home in the blue bar itself, click on wireless.
  • after you do that, you will see two options called as configuration and security. click on security. there you will see the option to change the wireless encryption to WEP.after changing the type to WEP, type the same password again in the section for password and click on apply to save changes.
  • check whether your printer is connecting to your home hub after that,
I am a person who work for BT in the tech help desk dept. if you have any trouble in doing this please reply to this message
May 19, 2010 | Kodak ESP 5 Printer
Computer does not connect
NEW LAPTOP? Noticed a lot of post for same Laptop as same time.
If try to use wireless - you need to set-up wireless part of router and wireless part of laptop (Wireless Software).
Setup your network same it is on the PC.
Use Network setup wizard, if not know how in system manager, in the control panel.
Network Name is same on both, MYHOUSE is good.
The only thing different should be NAME, like SYS02,
PC would be SYS01, and IPaddress ( first 3 sections same as PC - Last section is indivual system - example follows:
PC = 192.168.1.40 then LT = 192.168.1.41
Suggest you hard wire laptop to router to verify network connection then work on wireless connection setup after you get connected thru hard line.
Mar 17, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
I have a BT 2-wire hub with networked printer.
First thing, Does your printer have a wireless facility built in? If not it has to be connected to the hub with ethernet.
Normally setting up a wireless printer involves using cables until the set-up is complete. It's nothing to do with the router but all to do with the printer.
Best thing is to go through the manual.
Oct 14, 2009 | 2wire (1000-400108-001) Router
Just installed a D-Link DFE 530TX network adadpter into Dell Dimension 5000 desk top. Runnng Windows XP SP3. BT Home Hub 2.0 router. Even though broadband connection is fine to the router. The network...
Sounds like an IP address problem. Your IP address on both the NIC card (DFE 530) and the router have to be in the same address range. You can do this 2 ways. 1... Have your router hand out addresses automatically. Make sure DHCP is enabled and that you have at least one address available for it to give out. ie. 192.168.0.2 through 192.168.0.3. The first three number must be the same as the router. The other option is to manually set your IP address on your nic card to match the router. If the router is lets say 192.168.0.1 then you can assign 192.23.34.2 to your computer NIC. If you haven't been able to access your router then check your router manual to find out the default IP address and use the same number for your NIC changing only the last number. The largest number you can use is 255. Hope this helps.
Jul 12, 2009 | D-Link DFE-530TX+ Fast Ethernet PCI...
Wireless G Desktop Card Connection to BTHome Wireless Router
uninstall the bt desk top help first then the bt wireless connection , if ur wireless card has an utility use it to configure . the connection might be due the conflict between the wireless software. checked if ur getting limited or no connectivty if so delte and recreate  the wireless profile, if ur using bt router like home hub or voyager go the router page with the ip for hub its 192.168.1.245 and navigate to advance and keep the wireless channel to 9 or 11  for voyager the its 193.168.1.1
Oct 21, 2008 | Belkin 802.11g Wireless Desktop Network...
HP PSC 2175 All-In-One InkJet Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
