Question about Pacific International Pacific Laser PLS180TOOL 180DEG Palm Laser - Self Level w/ Wall Bracket
We have a bunch of PLS180 units that are out of calibration. Is there any way to adjust these back to level. I have some concerns about opening up the unit after seeing the warning about laser radiation exposure if unit is opened.
    Scholar:
  • 87 Answers
Don't worry too much about the laser radiation. Avoid starring into the beam, and you'll be fine. However, PLS does not make their hand held lasers adjustable. They work or they don't. If they don't, you take them to a PLS retailer, and you can exchange them for a PLS-ETN unit, for free under warranty. Or for a prorated price, if outside warranty.
Posted on Sep 05, 2015
    Scholar:
  • 127 Answers
The manual describes the procedure for checking level and plumb for the PLS180 but if you have determined that your units are out of calibration you are right to be concerned about opening the unit yourself. Please contact PLS at 1-800-601-4500 to find an authorized service center for your lasers.
If you cannot locate your manuals to check level and/or plumb I an attaching a link to the PLS180 manual as the methods for confirming level and plumb are quite detailed and should be followed exactly as described.
http://plslaser.com/sites/default/files/PLS_180_Manual_2008_1.pdf
Have a great day.
Posted on Dec 30, 2010
No temperature control on hot plate elements. Is this fixable?
ADJUST OVEN FLAME LEVEL: Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat. The reason for my free advice is GOD is good!
Dec 16, 2016 | Ovens
DW079 CALIBRATION
Here is how you get your laser into adjustment modeY axis; Power and scan key at same time, unit then will tip from Y1 to Y2, then recenter. use up and down arrows to bring laser into adjustment. Let unit stabilize for 30 seconds, press scan key, you will get a continuos beep, now at same time press down arrow key. This will store your new calibration.To get X axis into adjustment mode power on and up arrow at same time, and for Z axis type laser onto Z axis and use adjustment procedure for Y axis. Saving your calibrations is the same as in Y axis. Hope this helps you
Jan 04, 2012 | Office Equipment & Supplies
Two different meters of the same make and model 93-172 do not correlate...same values in the exact same position. Sensors and meters are paired as original. How do I adjust internally agains a certified...
That unit has a limited lifetime warranty, so are you sure you want to open them both up and void that warranty? I would send them both back to Greenlee for calibration and specify that they don't agree in the write up, with a known light source. Since Greenlee doesn't make their wiring and circuitry available to the general public, adjusting pots randomly is not a good idea.
If accuracy is extremely important to you, then you might want to send them to a calibration lab for them to adjust them.
Jul 01, 2011 | Greenlee 93 172 Digital Light Meter
I just bought a PRO45series Fluidmaster to replace a fill valve. in a 1958 American Standard, builder installed, tank type flush toilet. There were no installation instructions in the package to...
The installation instructions are usually printed inside the package. Open the box fully (saves paper) Here is a link to the instructions: https://aruntx.com/conference/kit.pdf
When you say to calibrate the unit, I'm assuming you're referring to adjusting the water level? You can do this by either adjusting the height or the float water level adjustment or both. These are quality trouble free units, I've never had any problems with fluidmaster products. There is a large warning on using Chlorine cleaners (inside the tank) in the instructions. Chlorine cleaners in the bowl are no problem. I've used the tablet type in the tank though without any problem. There would be a problem if the toilet was not used regularly and the tablet continued to dissolve, causing the chlorine level to rise dramatically.
Jul 12, 2010 | Plumbing
Trying to locate electrical junction to test fuel level sensor
Fuel Level Indication System The fuel level indication system is a magnetic gauge system. It consists of a magnetic fuel gauge (9280) mounted in the instrument cluster (10849) and a sending unit located in the fuel tank (9002) with an instrument cluster gauge amplifier (10E849) in series between the two. No instrument voltage regulator is used with this system. Fuel Gauge
The magnetic gauge movement consists of three primary coils, one of which is wound at a 90-degree angle to the other two. The coils form a magnetic field which varies in direction according to the variable resistance of the sender unit which is connected between two of them. A primary magnet, to which a shaft and pointer are attached, rotates to align to this primary field, resulting in pointer position. The bobbin/coil assembly is pressed into a metal housing which has two holes for dial mounting. There is no adjustment, calibration or maintenance required for these gauges. The instrument cluster amplifier is calibrated to the fuel gauge. The instrument cluster amplifier and fuel gauge must be replaced as a system. Instrument Cluster Gauge Amplifier/Check Gauge Module
The instrument cluster gauge amplifier electrically averages fuel sender readings so the fuel gauge displays actual fuel level and not fluctuations due to sloshing in fuel tank. The instrument cluster gauge amplifier is a small printed circuit board which latches into a pocket on the back of the instrument cluster. The electrical connections for ignition, ground, input from fuel sender and output to fuel gauge are made through a spring-type connector on the instrument cluster gauge amplifier to the instrument cluster printed circuit (10K843) on the instrument cluster. There are no provisions for calibration or adjustment of the instrument cluster gauge amplifier.
Fuel Sending Unit
The fuel sending unit consists of a variable screened resistor made up of a ceramic substrate. It is controlled by the action of an attached float in the fuel tank. When the fuel level is low, resistance in the sending unit is low. When the fuel level is high, the resistance in the sending unit is high. As the float moves from empty to full, the resistance will gradually and continuously increase. f9e3b50.gif
Mar 10, 2010 | 1997 Ford Ranger SuperCab
Cant calibrate laser
You must place the unit 30' from a wall, level the unit with the level indicating vials, mark spot on wall or object, rotate laser 180 degrees and level with vials again, if it comes to the same spot your unit is calibarated. if not then you must do this process at least 2 times(1 for each directional level) and use the adjusting screw to move vial. it takes a while to get it right.
May 04, 2009 | Robotoolz RT-5250-2XPK ePlane XP High...
I need to calibrate rotary laser DW073
Sounds like you figured this out on your own. I calibrate my own DW073 regularly without any fancy gadgets. I use the calibration check procedure in which the unit is placed about midway between fixed objects 100' apart.
These have a front and back and sides, so first you mark where the laser hits facing front to back at your targets. Then turn it 180 deg. relevel and resite. If the difference between the new and old marks is not the same then I turn the adjuster to halve the inconsistency and once that is accomplished, tweek the adjusting screw at the end of the level vial. (Because if you have adjusted more than the tiniest bit, the bubble will no longer display as level. So having established level, or closer to it, the adjustment here is actually to bring the relevant bubble vial back to level rather than assume they are level and adjust the physical beam mechanism (unlike the old physical sight levels where you adjusted the actual optics -- a little more like adjusting a rifle scope). Then you repeat for the side to side vial.
Anyway sounds like you are set so I posted this for anyone who happens to find this thread and is looking to field calibrate their DW073, e.g. don't have time or money to get it done in some shop.
I also wanted to post an add on question. Did you figure out how to adjust the "cone error", i.e. the accuracy of alignment of the twin lasers. They appear to have allen set screws that lock their adjustment, and maybe they are then reaimed by using a slotted screwdriver on the brass ring surrounding the laser. Maybe these are made eccentrically or slightly beveled so turning the laser reaims.
So far, my cone has stayed within the specs of 3/32" at 25' in the manual. But I'm seeing two lines at maybe 150' out. Probably that is close enough for gvmt. work, and I may find the adjusment so sensitive that I can't really get it any closer. But I'd at least be interested to know the method for adjusting the cone error.
Thanks,
Brian
Feb 15, 2009 | Dewalt DW077KD T Self Leveling Rotary...
THE TEMPERATURE REQUIRES CALIBRATION
We're sorry to learn of your concern. The calibration is only on certain models with an electronic clock/timer. We recommend service for a proper diagnosis. If further assistance is needed, please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with the website you reached out to us on (fixya), brief description of your concern, your name, address, a phone number and best time to reach you along with your model and serial number.
Jan 15, 2018 | Whirlpool RF341BXKW Electric Kitchen Range
"No Disc"
Here are a couple solutions:
How To Recalibrate DVD Player
Summary:
For those that are having the skiping up and unreadable disk problems try the following calabration. I did it last night and now my DVD's are much clearer and I'm hoping the skiping problem is gone.
For those that have the lip sync problem Sony should cover this for no charge, you just need to push them a little. This is a firmware update, have a look at the other posts at this web site to find the firmware revision that you need.
HOW TO PERFORM THE CALIBRATION
Make sure that the DVD player is turned OFF and in the stand-by mode with the little red LED glowing above the on/off button.
To enter the service mode/test mode, press Title, Clear, and Power on the remote.
This will produce the following menu:
Test Mode Menu
0. Syscon Diagnosis
1. Drive Auto Adjustment
2. Drive Manual Operation
3. Mecha Aging
4. Emergency History
5. Version Information
6. Video Level Adjustment
Exit: POWER Key
What each item does;
Syscon Diagnosis = Leave this for service technicians.
Drive Auto Adjustment = Automatically calibrates DVDs and CDs.
Drive Manual Operation = Manually calibrates DVDs and CDs with prompts for permission to skip, execute and/or proceed after each adjustment is made or skipped. Offers a fascinating look at all of the many adjustments made, but this method is time consuming.
Mecha Aging = Allows auto repeat mode for testing purposes.
Emergency History = Shows the number of hours on your machine.
Version Information = Shows firmware version.
Video Level Adjustment = Test pattern.
Press #1 (Drive Auto Adjustment) on the remote and the following menu will appear:
0. All
1. DVD-SL
2. CD
3. DVD-DL
4. SACD
Exit: RETURN
Press #1 (DVD-SL) on the remote and insert a Single Layer DVD when the drawer opens.
Even though you may be interested in calibrating only a dual-layer DVD, do not skip the single-layer calibration procedure. For some reason, the player prefers to first calibrate a single-layer DVD before proceeding to a dual-layer disc. Error messages may result if the single-layer calibration procedure is not performed first.
Press the enter key and the machine will begin to calibrate all of the playback features. When calibration is completed, follow the onscreen instructions to return to the above menu.
When the Drive Auto Adjustment menu returns, press #3 (DVD-DL) on the remote and insert a Dual Layer DVD when the drawer opens. Follow the instructions as noted above.
When calibration is completed, follow the onscreen instructions to exit from the Test Mode Menu. Now you can turn the player back on and try your dual layer discs to see if the layer change has improved.
If you have any concerns about trying this service mode calibration, leave it for an authorized service facility
Other solutions:
1. To reach this test menu on a DAV-S300, press and hold the "STOP" and "Muting" button on your DVD Player (not remote) and turn the volume nob clockwise about 180 degrees. You will see a flicker. A blue test screen will appear, allowing you to calibrate your DVD. Please note that if you have no technical experience, messing around in this menu can cause serious damage to your DVD. The calibration option will be under: option 1, Disc Drive Auto Adjustment (or words to that effect). Be sure to calibrate a single-layer disc first, then dual layer -- you need to calibrate both types. Good luck.
In order for the STOP + MUTE + VOLUME sequence to work, your player must be ON, but have no disc present. You need to empty the tray, power off the S300 and power it back on. Wait until the INSERT DISC/NO DISC prompt appears. Then try the SMV sequence. And you must use the buttons on the unit, NOT on the remote, to enter the service menu. Once in the menu, use your remote to select the auto calibration menu and go from there.
2. This will fix the C 13:00 problem on any Sony DVD player.
With the machine turned off on standby, press the following 3 buttons
on the handset, in order: TITLE CLEAR POWER. The Diagnostic Start menu will come up on the TV. Select the appropriate button number for "auto adjust". The
machine basically does it all. It asks you to select either a single
layer or double layer disc (whatever your offending disc is.) Ejects
the tray, asks you to put your disc in and then calibrates it. (It's
over in about half a second... painless) Just follow the prompts on the screen
Aug 17, 2007 | Sony DAV-S300 System
Pacific International Pacific Laser PLS180TOOL 180DEG Palm Laser - Self Level w/ Wall Bracket Logo
1,074 people viewed this question
Top Pacific International Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Pacific International Measuring Tool and Sensor Expert? Answer questions, earn points and help others
