Question about Remington S 1007 Tourmaline Straightener 1" Ceramic Ion
I have just brought a remington ceramic straight 230 s1005 straightner,,i live in spain so it has a spanish plug...i plugged it in and it tripped all the lights...now the the straightners will not turn on,,,i have tried another plug socket but they still wont work...
You just need to change the fuse in the plug - it's a little capsule inside the plug.
Posted on Dec 30, 2010
Why my straightener turn off while straightening?
According to the user manual, this unit is dual voltage. Maybe it is set to 120v and you are using it with 220v? There is a auto-resetting over-temp switch inside. Maybe the over-temp switch is defective?
http://www.remingtonproducts.com/womens/haircare/flatirons/style-red-1-multiheat-ceramic-straightener.aspx
Nov 04, 2014 | Health & Beauty
I don't know what converter to get to have my american mixer work in Spain
You will need a transformer to step the Spanish 230 volts down to your 110 volts.
Nov 24, 2012 | KitchenAid 32685 Mixer
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
How to take apart remington s1005 hair straighteners
Unfortunately, this piece of hardware is not very service-friendly, and you will probably break a part or two on your way in. It's all made of "snap-ins" that click when it's assembled and there's no nice way how to disassemble without prying it open. However...
First, you need to disassemble the hinge. Start with hinge on the side with the "unlock" icon. Try to pop up (with a screwdriver, probably) the ring that's around it. I broke one of the snap-ins on the ring myself and the other got severely damaged. Expect that as well. But after that it's quite easy an even if you break this part, nothing that serious happens. There is a screw under the "unlock" cap, so unscrew it and push through the shaft to the other end. That will require a little more force and the opposite ring will pop up as well. Now you can pull the shaft out and you got two separate parts just connected with a wire. From now on it's just a matter unscrewing few other screws and the thing is yours.
Oct 02, 2011 | Spectrum Remington Multi Heat Ceramic...
My avanti ultra hair straightner does not heat hotter than 230 deg..id there a reset button..help?
I have the same problem!! It switched from farenheit to celsius thats why its at 230 but i want it back in farenheit!
Sep 18, 2011 | Avanti Ultra Silicone and Ceramic Flat...
I lost my directions for my remington wet 2 straightner.
you should use towel then use it. Then you take the right position of your hair . This is do you some days after 1 week you get you target
Jun 27, 2011 | Remington S7100a Wet 2 Straight 1 Inch...
Is there a manual or step by step guide to take apart to re-wire a remington S1005 as my daughter has managed to split a wire by coiling it around the straightners when not in use...Everything works as...
dont take it apart just sauder the wires together and wrap with electrical tap should be good to go just make sure u sauder the same color wires together such as red to red and black to black etc
Oct 19, 2017 | Remington S6500 Sleek and Curl Ceramic...
Remington S 1007 Tourmaline Straightener 1" Ceramic Ion Logo
410 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
