Question about Kenmore Dryers
I have the ele-2406028-cv54 kenmore dryer and it takes for ever to dry a normal load of cloths about 6 hours, even on the automoisture sensor cycle. I can feel alot of heat inside the dryer when I open it but it feels like the moisture isnt going anywhere could it be a clog of some sort, I took of the exhaust hose and can fell air but not sure if its alot or a little and the breakers are fine? any ideas?
  • Kenmore Master
  • 3,497 Answers
Hey Dj. Sounds like the exhaust system may be clogged...make sure the lint trap is clean and nothing is blocking the flow to and through there... now, UNPLUG the dryer.... dig into the back of the machine, where the hose connects, using a flashlight.. look in the back, then CAREFULLY feel in there and see if you can find anything that prevents the exhaust from escaping...sometimes this is where you find the infamous "missing sock"...
Posted on Jul 31, 2017
  • 1122 Answers
SOURCE: Dryer wont start just clicks.
could be start switch bad,main fuse bad,door switch bad,or a weak motor,you need to call an honest appliance repair shop(not sears$$$$$$$$$) I DON'T WANT YOU TO HURT YOURSELF,THE DRYER IS HIGH VOLTAGE(220)MIKE
Posted on Sep 13, 2008
  • 212 Answers
SOURCE: kenmore dryer model:11060832990
sounds like start switch on motor bad.
Posted on Jun 24, 2009
jsrock516
  • 5911 Answers
SOURCE: Dryer works but will not heat up, can I replace
To answer your question, "yes", replacing a heating element is a simple repair that you should be able to perform yourself. However, the problem may/may not be the heating element. There are several things that can cause a dryer no heat problem.
If the dryer runs, but does not heat, the first thing you need to check is the wall receptacle for the proper input voltage. A reading across the two hot leads (left and right slots) should read 220-240 VAC. If this reading is incorrect, check your breaker panel. Some homes have the dryer circuit on two breakers, vice one single 220 breaker. If the voltage at the receptacle is good, unplug the dryer and remove the cover on the terminal block in the back of the dryer. Plug the dryer back in and take the same voltage check at terminal block across the RED and BLACK wires. You should see 220-240 VAC if good. If the voltage is bad at the terminal block, but good at the wall receptacle, you have a bad power cord. If the voltage is good at the terminal block, then the problem is internal to the dryer.
NOTE: The reason a dryer will still run if the input voltage is incorrect is because the dryer drive motor only uses 110-120 VAC, while the heating circuits require the full 220 service. So, if you are missing a portion of your input voltage, the dryer may exhibit the symptoms you have.
If your problem is with the dryer heating circuits, the following link explains what to look for and how to troubleshoot:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. The number one cause of dryer heat related problems are caused by poorly installed, kinked, or clogged dryer ventilation. Your heating circuits are located on the lower right side of the dryer cabinet under the drum. You will need to remove the lower kick panel under the door to access. The elment is inside the heater box while the Thermal Cut-Out (TCO) and Hi-Limit Thermstat is located on the outside of the heater box to the left of the element. The TCO is located in the rear, while the Hi-Limit Thermostat is located near the heating element terminals. NOTE: Make sure the dryer is unplugged while taking any resistance checks. Make sure you disconnect any terminal wires before measuring to ensure accurate readings. If you have any questions, please let me know. I hope you find this information helpful.
Posted on Jul 13, 2009
jan mczeal
  • 632 Answers
SOURCE: dryer will not start...checked belt and is
If the lid switch is defective, the washer will not function or work at all. It is located inside the washer main housing near the door frame. When you close the door, the switch is activated by an actuator. You have to raise or open the top or front panel of the machine to reach the switch. Replace if found defective.
Posted on Sep 26, 2009
heatman101
  • 43501 Answers
SOURCE: our kenmore dryer 600 series,model
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Jan 18, 2011
My Sears Kenmore 90 Series takes too long to dry cloths
First you need to make sure that the lint trap is completely clean. I don't mean just taking the screen off and making sure there isn't lint on that. You need to take the cover off of the back of the dryer and remove the shute the lint screen slides into. That can be backed up and it's quite common. Also when that happens it tends to blow out the fuse that is located in the same general area. It's about an inch long, white, with two wires connected by plug on terminals. Make sure you unplug the dryer if you're going to check that. Remove the two wires and with an electrical tester check for continuity across the two terminals. If there isn't continuity you'll also need a new fuse, Hope that helps.
Mar 20, 2013 | Kenmore Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Have a Kenmore Elite Dryer that won't start. Mod 110.65962401 Ser MS0303258 Type DDOT-ELE-2406028-CV54
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2011 | Kenmore Elite HE4 Electric Dryer
I have a whirlpool Dryer type: D433-ELE-2406028-FM54, Model: LER463JQO. It takes atleast 2 cycles to dry the whole load completely, and I'm wondering what I can do to fix this problem?
You may have a clogged vent pipe. I would take it apart and clean it all out.If that doesn't help then you may have other problems.Could be thermostat or one bad element. Hope this helped.
May 05, 2011 | Kenmore 600 6965 Electric Dryer
My Whirpool dryer Mod. LEN 2000LWG, type DWSR-ELE-2406028-CV54, Imperial Series, was working fine, but after the second medium sized load it stopped drying the clothes. I finally noticed that the inside...
The Hum most commonly means that the drum belt on your dryer is probably broken
There is a simple way to test for this.
1 remove the clothes from the dryer.
2 put your hand inside the drum and turn it. If it is easy to turn, the belt is broken. If it is difficult to turn, the belt is good. You may be looking at motor problems.
Almost all of the time, it is a broken belt.
The link below has the full procedure for changing the belt.
Hope this helps,
Best Regards,
Mark
http://www.fixya.com/support/t6322596-get
Jan 19, 2011 | Whirlpool Dryers
Takes too long to dry or keeps running when clothes are dry
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
Sep 13, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
91 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
