Question about Sakar Crayola 32070 Flash Media Camcorder
When we turn on the camera, the screen is completely white. You cannot view any previous footage or pictures. Sound works fine and the batteries are new.
White Screen. When I turn my camera on, it has power but, the display is white and you cannot see anything through the view finder.
hi,
did you check the picture through the view finder ? if it is clear, then there may be snag in the monitor, normally the connecting cable to the motherboard become break, if so should replace it.
if the picture is visible when you turn the monitor to either side, then you can confirm the fault of the cable.
Feb 26, 2016 | Canon Elura 100 Mini DV Digital Camcorder
My camera turns on but won't show a picture
If your camera is a "SLR" camera, the screen does not show "live", but only after you take a picture...
Jan 19, 2015 | Pix Cameras
White out LCD screen
Try a manual reset. Remove the card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on.
Oct 05, 2009 | Kodak EasyShare C713 Digital Camera
Still images have white overcast when viewing pictures.
CCD going bad call sony for repairs FREE they will do it dont worry pls rate me WELL !
Jun 05, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
MY Hvx 200 Is totally Black when I turn it on. the display and playback of my old footage works fine but the picture is totally black. any Ideas When I switch the camera on, the view finder is totally...
You should go into the menu, camera settings and set the evf to on. EVF stands for electronic view finder. This can be set to be on when the lcd is open or closed. CAreful, if the evf is set to on and you point the viewfinder towards the sun, it will burn white marks into the viewfinder and ruin it.
May 09, 2009 | Panasonic AG-HVX200 Mini DV Digital...
Canon S2 IS - LCD screen is white after taking an outside picture
the image is all white or has lines through it.Definitely sounds like a repair issue, and has been a previous problem with the camera in the past. There is a defect in the sensor of the camera, and happens quite frequently in this model. I would try and contact Canon about it, and see if they'll repair it for free. If not, its probably going to cost more than the camera is worth to repair it.
Mar 24, 2009 | Canon PowerShot S2 IS Digital Camera
Power??
my computer will not take my pics off anymore
Apr 20, 2008 | Canon PowerShot A510 Digital Camera
Canon A75 No startup sound & display on LCD, rest of things works fine
Think it might be your batteries. 700mah batteries are pretty weak by today's standards (most are at least 2,500 mah these days). I'm guessing your batteries are several years old? If so, they're really only meant to have a usable shelf life of a few years, whether they are used or not. Recommend trying a new set of rechargeable batteries.
Mar 20, 2008 | Canon PowerShot A75 Digital Camera
Black screen
whats up with blackscreen?
Oct 08, 2007 | Fuji FinePix F460 Digital Camera
Sakar Crayola 32070 Flash Media Camcorder Logo
27 people viewed this question
Top Sakar Video Cameras Experts
 Mikey
Mikey
Mark Schmit
Mark Schmit
Are you a Sakar Video Camera Expert? Answer questions, earn points and help others
