Question about Philips Philishave Micro Action HQ 4806 Electric Shaver
Looking for new heads for philishave655 - Philips Philishave Micro Action HQ 4806 Electric Shaver
  • Philips Master
  • 1,600 Answers
You will find replacements for model HQ655 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-1917-hq2-type-replacement-heads-p-244.html
Posted on Dec 31, 2010
I have an 03 vw jetta 1.8 turbo. The timing belt has broken according to the mechanic. My question is this what is called a "contact motor" which requires a lot more work such as head work etc....
You have a contact or interference engine. This means that there is not enough room between the top of the piston when it is all the way up for the valves to be open. What happens is they get hit by the piston and they bend or break. You will have to take the head off and send it to an engine rebuilder. MAKE SURE they know Volkswagons or you will likely be taking the head off again and sending it back out. Normally valves and valve guides need to be replaced, you are looking at about $1200-$1500 for a proper job. Also you will need new head bolts, VW head bolts are not deisigned to be reusable. (Been there, done this).
You might be better off looking in a scrap yard for a replacement engine. , or a head.
Sep 10, 2013 | Cars & Trucks
How much would it cost to repair cracked heads(2) including labor an changing a timing chain an the heads are being shaved
The labor alone will come to over $1000. I know the reason I changed my own head gaskets was that the shop wanted $800 for labor, and that was the cheapest I could find. Your heads won't be cheap either, unless you cam buy them from a yard, in which case you are still looking at at least $100 each. IMO, you should really be looking into a complete engine from salvage, or shopping for a new car. It just isn't cost effective to repair your engine at this point.
May 07, 2011 | 1992 Lexus Es 300
How much does it cost to fix a bent valve on a suzuki ferenza 2004?
YOU'LL BE LOOKING AT REMOVING THE HEAD, TO GET TO THE VALVE! SO YOU'LL BE LOOKING AT NEW INTAKE, AND EXHAUST GASKETS, PLUS A NEW HEAD GASKET, AND THE VALVE! PARTS STORE CAN GIVE YOU THE COST OF THE PARTS! AND IF YOU CAN DO IT YOURSELF, YOU SAVE THE COST OF LABOR! IF NOT, IT CAN BE COSTLY, UNLESS YOU HAVE A GOOD FRIEND, THAT'S MECHANICALLY INCLINED!
Mar 01, 2011 | 2004 Suzuki Forenza
The pipe leading to the shower head is larger than the new shower head I planned to install. Is there a type of connection that I can buy and what is it called and where can I buy it. I thought it might...
You need your old shower head and the new one, go to the hardware store and tell them you need a pipe adapter with a female side that fits the old one and a male side that fits the new one. They'll be able to pick it out for you.
What you're looking for is commonly called a pipe adapter or "nipple".
Aug 09, 2010 | Water Pik Shower Head
Replay heads not playing back properly ,no sound ,like looking through venetian blinds ,used head cleaner but no better ,do i need new heads.
Have you used the same tapes over and over again? If so then reclean your heads and see if things work with a brand new tape. If this IS the case then I don't think what's on the original tapes will be salvagable.
Jan 23, 2010 | Canon MV700i Mini DV Digital Camcorder
Need new head gaskets they are blown how much to repair?
head gaskets can easily run you $1000. Depends WHY you need new gaskets too: if the heads are warped, deck is cracked, whatever, you're looking at major grief. I would consider shopping around for a crate motor or a junkyard donor, in case you run into something serious like that.
Jul 03, 2009 | 1994 Cadillac Eldorado
Is it difficult to instal a new shower head?
It requires a piper wrench or chanel lock pliers. If you are able to unscrew the old one,you wil have no problem screwing on the new one. Use teflon tape on the male threads when installing the new one. You can even screw it on by hand only needs to be tight enough that it does not leak . It unscrews counterclockwise looking at the end of the spray head.
Apr 23, 2009 | Plumb Pak Economy Shower Head Water Saver
Replacement Heads for Arcitec Shaver
Hi!
You're looking for the RQ10 heads, which should be found easily via Internet search.
Apr 20, 2009 | Philips Health & Beauty
Philips Philishave Micro Action HQ 4806 Electric Shaver Logo
77 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
