Question about GE GSS25LGM Side by Side Refrigerator
We have a GE Profile, sise by side refridgerator . we need to change the water filter, but can not find the filter on the machine. where is it please?
  • 10,865 Answers
Hello js... go to searspartsdirect.com
Enter the model number and you will see a full set of schematic parts diagrams for your fridge. This way you will see exactly what you have and can even order a new part if you need to. Joe
Thanks for choosing Fixya!
Posted on Dec 30, 2010
The house we moved into has a GE select side by side refridgerator with a water dispenser. I was wondering if it had a water filtration system and if not, is there a way to add one?
Most refridgerator filters on older machines are located externally. Without Model # it hard to say but I would look behind the machine for a cylinder about 10"-12" long and 3" in diameter. It would have a small either copper or plastic tube attached at both ends.
Jan 06, 2011 | GE Refrigerators
Replaced my GE double wide refrigerator SMARTWATER FILTER #GWF With a which is supposed to be better. Yet, the water stream has cut down to half. Do I need the adapter collar for this newer model? ...
I have exactly the same problem. Replaced my GWF filter with the "new improved" MWF filter and the same thing happened. Tried replacing the filter not once, but twice - same low water flow. If you install the bypass plug the water flow is normal, so don't bother checking for water restrictions, bad hoses, tanks etc.. My refridgerator is a GE Profile 26 cubic foot purchased in 2004. I'm afraid these MWF filters don't work well in older models.
Oct 07, 2010 | GE Replacement SmartWater Filter for GE...
Low water flow after changing the water filter in a gf profile re
Just a suggestion, you could try installing a filter on the water supply line to the fridge. A nice one should dramatically lessen the frequency of replacing the one in the fridge. As for your the pressure being low, look for a kink or pinch in the water supply line.
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a ge profile side by side refrigerator.
First thing...Take a good look at all the door seals. If they let air and a lot of moisture in, that can condense and freeze causing your problem.
Second...Manualy defrost your freezer and see if the problem re-occurs. It may be that someone left the door open once and caused the icing.
Jul 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
No water, no ice, but new water filter cartridge
If it was running before the filter change you need to purge the filter cartridge of the air in the lines. Also check voltage on the back on the water control valves . While someone presses dispenser you should get 120volts AC on the plug receptacle side for the dispenser . Let me know what you find, Sea Breeze
May 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
May 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a side by side GE profile Artica refridgerator. The Ice maker is producing, but I cannot get water to come out. When I push the water dispenser, I can hear something happening, but nothing comes...
One of two things. Water solonoid in back defective or water line insideof freezer door is froozen. I just posted a write up about this. Check other response. UJ63
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25LGM Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
