Question about Water Heaters
We recently purchased a home with a heil furnace and I need to know what size filter it requires. It is a gas heil model # NUG1075DF01. Please help !
    Genius:
  • 1,015 Answers
That is hard to answer but I would say that for a furnace of that size you are probably looking at somewhere around 16x20x1. On older heil furnaces they often had the filter mounted inside the blower compartment so if the case you can just remove the cover and measure it. If not it should be located on the return air duct close to the furnace. Hope this helps you some. Thank you.
Posted on Dec 30, 2010
  • Tommy Duke Mar 21, 2015
    go to this web page and search nughttp://goheil.com/go/index.asp?t=86&s=477&p=95&ps=522
Pilot light lit but not igniting to heat water
pilot lit on gas furnace, but the burners won't light (Home ...
answers.angieslist.com > Home > HVAC
Oct 26, 2013 - i have a gas furnace with a lit pilot, but the burners won't light. ... if the thermocouple does not sense the heat of the pilot it prevents the gas controller fromturning on the burners. ... clamped onto the outgoing hot water pipe, if huydronic system) that is telling the furnace it is too hot, whether or not that is true.
Nov 18, 2015 | Water Water Heaters
Recently installed a Noritz NRCP 112 water heater, but very frequently it keeps shutting off and on the display it says error 60, after looking at the manual there is no explanation of what error 60 is....
Shut downs with new heater might be defective PC board.
Other issues could be associated with improper installation.
Low gas pressure caused by undersized gas meter or water in the gas line, undersized gas line to unit (requires 1" gas line to within 10 feet and then 3/4"), wrong type of gas line (cannot use flexible gas line), improper vent (for example too long horizontal run or undersized vent pipe or shared vent with furnace or other gas appliance), not enough incoming fresh air supply, nearby exhaust fans or vent fans stopping proper draft on tankless, temperature set too high for cold incoming water supply (install tempering tank to help preheat water),..
http://waterheatertimer.org/Tempering-tank.html
Other causes can be clogged water filter located where cold water enters tankless, or clogged water line, or crossover caused by bad single-handled faucet or bad crossover valve on recirculation system, improperly sized recirculation system. These problems can mean less water flow through tankless, so burner shuts down, and unit throws error code because sensor indicates water flow is still moving but inadequate to trigger burner
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Water-heater-recirculation-system.html
Gene
Water Heater Timers Save Money
Nov 27, 2014 | Water Heaters
Oil furnace only produces cool water intermittedly and only when heat is actively on
For clarity, a Furnace produces HOT AIR for heat while a boiler produces HOT WATER for heat. Just remember...boil = water. You said your "furnace" does not produce hot water for a shower and because furnaces do not product hot water unless they have some model that do???? Usually people with a furnace have a seperate hot water heater. People with boilers though can produce hot water for use as both their sinks/showers hot water and their heat (by heating water that goes through baseboards) in their house. I don't believe any furnaces produce hot water most of the time a furnace just produces hot air for heating. So figure out what you first have.
Having said that, I'll assume you have a boiler like I do and my Weil McClean(sp?) stopped working a while back and wasn't turning on to "boil" any water. I took apart the burner and there is a light sensing photo resistor as part of the controls. If this phto resistor goes bad, the boiler will not start. The resister is cheap, I think it was $8 but you have to know what you're doing to change it. So you may be better to call someone who can work on such equipment.
Boiler's themselves are not overly complex. Home heating oil is the same diesel fuel that you can buy in a gas station only the government has "oil" companies put a RED die in home heating fuel which is usually cheaper then Diesel fuel because diesel fuel is taxed to death. The reason they do that is so that if you try putting RED tinted home heating fuel in your truck and you get pulled over (because you're a trucker with and 18 wheeler and they typically do inspections of these trucks) you will be a huge fine if they see you're running home heating fuel and NOT paying your taxed by purchasing Diesel fuel. A little bit of background so you know the fuel you are dealing with here. So it's dieslel fuel without the tax you run in your boiler. Gasoline on the other hand is VERY explosive as you know, but diesel fuel (if you're ever tried to light it) takes some coaxing to get lit. When it's cold out, diesel fuel is very hard to light and that's why trucks use glow plugs. You don't need those in your home though.
But because diesel fuel/home heating oil is hard to light, it's sprayed as a msit into your boiler, so that it can light more easily.
But because it is a fuel, you should know what you're doing when messing with it. FInd out what you have, and then have someone work on the issue if you haven't already. I'm guessing you have had it fixed by now?
Mar 21, 2014 | Water Heaters
My reliance sta-kleen 502 is leaking. The water is dripping on top of the pilot light, extinguishing the flame . Please advise me with step by step instructions to diagnose and attempt fix this myself....
If you have a leaking water heater there is a serious problem.
http://waterheatertimer.org/Water-heater-leaking.html
Page shows how to limp along on a leaking water heater if your water heater needs replacement.
One of three things is causing the water:
1) Loose water connection on top of tank that is dripping down inside tank >> check pipes on top of tank.
2) The vent is clogged or not working correctly causing condensation inside flue pipe.
Condensation water is dripping back down inside tank.
Problem means possible CO poisoning if gas is not venting.
Look at vent pipe to see if joints are corroded.
Use long fireplace match > light match and put into draft hood at top of tank and see if smoke goes up.
Put hand at draft hood opening when water heater turns on to see if vent gas enters home.
Do same test when furnace turns on to see if furnace vent is pushing back into water heater.
Does water heater vent inside same pipe as furnace? You may need to set up separate vent for water heater if furnace gasses are pushing back into home.
Check furnace vent for obstructions.
Look at vent stack top of home to see if hood is in place.
Check if bird nest is built inside warm vent pipe.
Improper flue is top priority for getting fixed so vent gasses properly escape home.
You may have to call a plumber.
Professional plumbing forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Your water heater is rusted out.
A rusted tank has to be replaced.
It cannot be repaired.
However, before replacing tank, you do not want a tank failure where tank ruptures and water runs inside home until water is shut off.
This will cause major damage.
Protect yourself first.
Turn off water valve above tank.
Move gas knob to 'pilot' so burner is not heating water.
Open tub spout on hot side to relieve pressure on tank so it will not rupture.
Now you're protected.
Link above shows how to limp along on failed tank until you can replace heater.
You need a new gas water heater from Lowes or Home Depot
Look at label on side of you tank for gallons and btu's of your water heater.
Measure height to flue pipe so you get same height water heater, so pipes don't have to be changed.
You need a pipe wrench and teflon tape which will be wrapped on each pipe thread when pipes are reassembled.
Step1) Drain water heater using valve at bottom of tank.
http://waterheatertimer.org/Water-heater-will-not-drain.html
2) Turn off gas valve going into heater.
When gas valve is perpendicular to gas line, then gas is off.
Dissemble gas line to water heater.
3) Disconnect flue pipe and support flue pipe with wire so it doesn't not fall down. Flue pipe joints should be held together at each joint with 3 screws.
4) Turn off water. Shut off valve is on COLD side.
Disconnect water pipes.
5) Move old water heater out of way.
6) Set new water heater in place. Put water heater in drip pan.
7) Connect water pipes >> cold goes to side marked cold.
Hot to hot.
Buy new flexible water connector pipes at home center for easy installation of water pipes.
8) Connect gas line exactly as it was connected before.
Home center sells flexible gas line connector for easy installation of gas line.
To test for gas leak after installation, mix liquid soap with water and put around gas line joints to see if there are bubbles.
Natural gas has less pressure than water lines, so gas pipes are easy to seal with ordinary wrench.
9) install TP pipe that runs to floor. Use old one off old heater.
10) Fill tank completely with water until water is coming out of tub spout.
11) Turn on gas, and light pilot as shown in manual.
New gas heater sometimes have small water leak when first fired up, so ignore a bit of water.
12) Save water heater manual like it is gold, and read everything in manual.
Dec 18, 2010 | Water Heaters
How do i restart my boiler after running out of oil
If you have a filter in your line - this would be a good time to replace it. If it has been replaced recently you will just need to "prime" it by filling up the filter and screwing it back on (prime a new one as well). Or in the case of an element type filter - put the filter in the case and fill with fuel - attach to base. Then you will need to find the bleeder nipple on your furnace pump (attached to the motor) that is like that used on brake systems of a vehicle. Be sure and have a collection system in place (old bucket and a rag or two). Turn on the furnace and open the nipple slowly until air starts to bubble out. When the air is reduced to a flow of fuel - close the nipple - you should be good to go. Let me know if this is the solution. Thanks
I have a Rheem Criterion II Gas furnace. It is not igniting.  When I switch the thermostat to "heat" - the furnace doesn't not start.  There are 2 green lights - one is one and the other is blinking.  The...
Roscoe007 shouldnt speak unless he knows what he is talking about, as a heater installer i am telling you the ignitor needs to be replaced, the very fact that the ignitor does light for about 30 sec than goes out rules out any issue with the themostat, replace the ignitor!
Dec 13, 2008 | Water Heaters
Heil heater starts/stops before reaching temp
is installed in a vertical up flow or horizontal position , if in horz position you could have a bad or miss positioned roll out switch this is a thermal switch positioned toward the burner edge that if the flame rolls out of burner area trips and then resets as it cools allowing the furnace to re-start until it reaches temperature , something to check .
Dec 08, 2008 | Water Heaters
Where do install a Heil furnace filter?
MAYBE IT DOES NEED IF THE FILTER IN THE COLD AIR RETURN GRILL MAKE SURE THEIR IS NO FILTER IN THIS FIRST , AS 2 FILTERS ARE NOT BETTER THAN ONE WHEN COME TO ELECTRIC FURN AND H/P ALSO IS THIS A UP-FLOW ,DOWN FLOW OR HORZ MEANING AIR #1 RTN IN BOTTOM DISCHARGE COMING OUT OF TOP OR#2 COLD AIR COMING IN TOP AND DISCHARGE OUT OF BOTTOM OR #3FURNACE LAYING SIDE-WAYS AIR COMING IN ONE END AND OUT OTHER THESE WOULD DETERMINE FILTER LOCATIONS
Nov 19, 2008 | Water Heaters
Water Heaters Logo
395 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
