Question about Irons
Steam pours out constantly from my imetec steam iron k123
geox29
  • 65 Answers
SOURCE: tefal steam generater pro express turbo
Most of the time the electro mechanism release the steam still open and not able to returning in closing position.Try to cclick quite few time to excite the mechanism and some times work.Also can be the micro switch defective.
Good Luck
Posted on Jun 21, 2008
t0pc4t
  • 132 Answers
SOURCE: Hi, My Tefal Express Steam
Do you use any additive to the water when you iron?
Do you empty the water out after use ?
Brown steam / water suggests foul water, or rust due to dirty water pipes on Iron.
With regards to 'not working' - do you have any lights on, or is it dead.
(I had one of these, the mains lead within the flex holder had broken - design flaw) - managed to repair.
Posted on Aug 16, 2008
SOURCE: My Tefal express steam iron no longer steams and
If there is water pouring from the bottom, chances are the element or sole plate are not heating the water to turn it into steam.
Posted on Aug 11, 2009
bozcro
  • 867 Answers
SOURCE: My Rowena Steam iron is leaking steam around the
if you can un-screw this part, yes you can replace the o ring for it, get it at hardwaare store.
Posted on Sep 02, 2009
heatman101
  • 43501 Answers
SOURCE: Water pouring out of my iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
Tefal iron steam generator
Steam irons can become clogged with mineral deposits. Use distilled water in the iron to minimize these deposits.
To clean the iron , use 1/2 white vinegar and 1/2 water. pour in iron and place iron on steam. The iron may require a few cleanings.
May 11, 2014 | Tefal Irons
Gravity feed steam iron
If you have been using tap water in your iron, and your water has lime or calcium in it, then the iron is probably clogged up. You might try using a product like "Lime Away". Read the warnings on the bottle first. Don't get it on your skin or in your eyes. Don't breathe the mist or steam. The bottle I looked at also had warnings about how it would mess up some counter tops or sinks.But if the iron doesn't work anyway, carefully pour some into your iron maybe about one fourth full, then carefully shake the iron to get the stuff all over the insides of the iron holding the iron like you would if you were ironing. Let the iron sit for a bit, then shake it again, maybe a couple more times like that. pour it out into an old bowl that it wont ruin, and see if there are a lot of minerals in the liquid. If there are, that may have cleaned it enough to start working again. Pour enough water in the iron until it is half full, plug it in and turn the temperature up to where it will produce steam, but don't iron any clothes yet because there is still cleaner in the iron. turn the iron so it is like you are ironing, but don't let it touch anything. Hold it over something like some old rags. If steam comes out, don't breathe it, but let it come out for a little while. Pour out that water and refill with fresh water and let it steam over the rags again. Pour that water out and all the chemicals should be flushed out of the iron. Carefully wipe the hot plate off to get any chemicals off the plate. Good Luck
Nov 02, 2013 | Irons
Brown steam
Brown steam is normally associated with internal rust in the iron. descaling may help clean it up. To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the limescale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any risidual vinegar etc. Turn off and unplug the iron and pour out the remaining water.
Oct 26, 2013 | Morphy Richards Jet Stream 42271 Iron
As the steam builds up it constantly comes out of the the blow off pressure valve under the iron. steam will come out of the sole plate when the button is pressed
see this causes and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Oct 02, 2012 | Irons
Steam not working on iron then lots of water pouring out of holes
fill water chamber with vinegar and let it sit for 24 hours.
empty vinegar - fill with distilled water - turn on and press the steam button to clean the holes in the plate of mineral deposits which accumulate from using tap water. after a few shots of steam all should be clear - empty and refill with distilled water and it should be good to go.
May 08, 2012 | Tefal Pro Express GV 8120 Iron
How long should we wait before the iron is ready for use and producing steam
As soon as you lay your iron down to start ironing. It give off steam every little bit, it's not constant. If you want constant steam, fill a spray bottle with water and spray it lightly before ironing. Hope that helps.
Oct 18, 2011 | Irons
My steam iron will not steam. How do I clean it?
Mix (1 to 5 parts) white vinegar in distilled water and pour into the reservoir. Let sit for an hour or so, then pour out through a coffee filter into a container, then pour back into the iron for another hour. At this point, heat the iron and try the steamer function. The vinegar solution will clean deposits from the steam jets, so don't try to iron anything yet. Keep running solution through until sputtering stops. Wash out the reservoir with distilled water, then refill and steam wash the ports several times to remove the vinegar. If you can get it clean, continue to use only distilled water in the iron.
Sep 07, 2009 | Irons
heatman101
Aug 26, 2008 | Rowenta Powerglide DM273 Iron
Irons Logo
44 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
