Question about RTO Blower Motor,1.5HP,110V,Radial
Front blower not working on my 2001 Dodge grand caravan. Changed fuse,relay,resistor and still not working. So I guess the blower motor is next but how do I do it. .
  • 375 Answers
  • Disconnect the negative battery cable.
  • Disconnect the blower motor lead connector from the wiring harness connector.
  • Remove the blower motor cooling tube from the blower motor.
  • Remove the four retaining screws.
  • Turn the motor and the wheel assembly slightly to the right so that the bottom edge of the mounting plate follows the contour of the wheel well splash panel.
  • Lift up on the blower and remove it from the blower housing.
  • Installation the new blower motor by reversing the removal steps.
  • Connect the negative battery cable.
  • Posted on Jan 11, 2011
    My front heater won't blow. we have checked the resistor, changed the blower motor, thermostat and relay. Any ideas as to what it could be/ I do daycare and need the front heat.
    In the diagram, check fuse 10--40 amp, not only check the fuse, check the fuse circuit for voltage with hvac on. Use a test light to check for voltage. See the wires going to front blower motor, that is voltage and ground, check them both. Also, the front blower module could be causing a problem? The diagram is for automatic hvac.
    Dec 03, 2015 | 2001 Dodge Grand Caravan
    The front a/c blower does not work, all fuses are good. please help
    J, I am sending you some info to read but it appears that the most likely cause is the blower motor relay. Give the following notes a read and if you need some more help give me a buzz... Best of Luck..
    1996 Chrysler Town & Country 3.3L, Vin R 1996 Dodge Grand Caravan ES 3.8L, Vin L 1996 Chrysler Town & Country LX 3.3L, Vin R 1996 Dodge Grand Caravan LE 3.8L, Vin L 1996 Dodge Caravan LE 3.8L, Vin L 1996 Dodge Grand Caravan SE 3.3L, GAS, Vin R, Eng Cfg V6 1996 Dodge Caravan Sport 3.3L 1996 Plymouth Grand Voyager SE 3.3L, GAS, Vin R, Eng Cfg V6 1996 Dodge Grand Caravan ES 3.3L, Vin R 1996 Plymouth Voyager Rallye 3.3L Customer Concern: Front blower does not work; no power to it. Fuse is OK. Tests/Procedures: 1. At the blower motor, there is a Dark Blue wire. This wire should have battery voltage whenever the key is in the "on" position. Power for the blower motor comes from the blower relay.
    2. Access the front blower relay, it is located on the driver's side under the dash, near the junction block. There will be four wires going to it. The Dark Green wire should have battery voltage all the time. The Dark Blue wire is going to the motor. The Black/Orange wire should have battery voltage with the key in the "on" position. The Black wire should be grounded at all times. On this circuit, the relay is energized whenever the key is in the "on" position. Potential Causes: Front Blower Relay
    Front Blower Relay Wiring
    Heater Ventilation Air Conditioner (HVAC) Control Head
    Tech Tips: The front blower relay is located under the dash, on the driver's side. It may be necessary to remove the junction block (fuse and relay box) in order to see it. Diagnostic Codes: None
    Aug 28, 2011 | 1996 Chrysler Town & Country
    I have a 96 dodge grand caravan with front and rear heat and air . i am looking for all the fuse and relay locations for the front blower motor ? the rear heat and air work but the front blower motor wont...
    #26 40 amp orange fuse ---it is under the hood of vehicle in fuse box. Relay labeled "F" in passenger comp on juction block behind left side of dash is for rear blower motor, front blower motor relay is behind juction box.
    Jun 17, 2010 | 1996 Dodge Grand Caravan
    Blower motor resistor overheats and fried connector to blower motor on 2001 Grand Caravan. Replaced resistor once new one fried connection. Saw review online that the resistor diode may be the culprit....
    You should be replacing the blower motor with the resistors. If your buying the parts from the dealer an experienced parts person will insist you replace both at the same time. The blower motor is usually what burns out the resistors.
    Jun 05, 2010 | 2001 Dodge Grand Caravan
    The front heater/air conditioner blower stopped
    First check the voltage at the front blower moter. If it has voltage then it may just need a new motor.
    May 17, 2010 | 2001 Dodge Grand Caravan
    My 02' Grand Caravan front A/C is not blowing in the front
    Could be the fuse for the front blower motor, or worse the motor itself.
    Choice A is easy and not expensive. Choice B could be somewhat pricey, or really pricey if the dash has to come out for blower removal/replacement.
    Don
    Apr 13, 2010 | 2002 Dodge Grand Caravan
    Have 2001 grand caravan sport 3.3L and the fan switch will only work in the high position,what may be the reason for this? THANKS
    sounds like it is the blower fan resistor, there is a wire for every speed of the blower motor. so if a wire burns out, you will loose that speed. the resistor is located behind glove box.
    Feb 25, 2010 | 2001 Dodge Grand Caravan
    2005 Dodge CaravFront defroster fan wont blow (rear is ok), fuses
    check the switch most used part usualy wears out if you know there is no power at the fan motor wires yes the twisted wires, then i would look at switch next.
    Jan 16, 2010 | 2005 Dodge Grand Caravan
    Front blower dead! its not the fuses. what should i try next?
    Try a blower motor resistor, however a resistor will usually cause the motor to work only on one speed. I would seriously consider the blower motor itself, a little premature to fail on a 2005 but I've seen stranger things happen
    Dec 12, 2009 | 2005 Dodge Grand Caravan
    RTO Blower Motor,1.5HP,110V,Radial Logo
    192 people viewed this question
    Top RTO Garden Experts
    John Trevino
    Joseph Mueller
    Joseph Mueller
    Andy
    Are you a RTO Garden Expert? Answer questions, earn points and help others
