Question about Black & Decker Bread Machine
The bread machine was finished and upon opening and trying to get bread out of the machine I found that the top of the bread was sticky and wet. why??? i was carefull the yeast, flour & OTHER INGREDIENTS WERE EXACT. No idea why the top was wet.
    Genius:
  • Black & Decker Master
  • 1,280 Answers
Hi, a common mistake that people make using bread machines is to use the wrong kind of flour. If you are using all purpose flour it will not perform well. You need to use flour marked "bread flour" on the bag. Also the yeast and water have to be at the right temperature. I could probably help you better with a chat on fixya, but perhaps what I have already suggested will help. If you want to chat I suggest 7:00 pm eastern time tomorrow. email me back if you want to try that.
daryl441@msn.com
Posted on Dec 30, 2010
When I use the dough cycle on my bread maker, the dough doesn't seem to rise enough and is sticky and wet.
Looks like you have the same bread man machine I have. My metod is too unplug the machine for a half hour then put it through a second round of mixing. At the end of secound mixing I place the dough in a bowl greased and large enough for the dough to rise one last time oil top of dough cover with a towel on top of stove turned on set to the desired temperature. Keep dough away from any drafts. Once dough has doubled in size usually about one hour, take dough from bowl and divide it into buns or loafs of bread. Let dough rise again covered. Place in oven bake for about 15 minutes or longer until desired color, bread is done when you tap the top of it and it has a hollow sound, remove from oven let cool in pan for about 5 minutes, then take bread out of pan and place on a rack that allowes air to flow all around it. The reason for the rack is that baked bread that is allowd to cool on a fly surface will cause the bread to sweat on the bottom. Make sure yeast is good not expired or left out in the open
Dec 08, 2014 | Kitchen Appliances - Others
Tip
Sticky Bread Machine Paddles.
When the paddle was removed from the bread it tore out a large chunk of the bread. What is needed is a hard slippery coating. I did the following to two of my older machines: Buy a spray can of Hi-Temp engine enamel, gloss finish. Thouroughly clean paddle with a strong solvent, I used lacquer thinner and steel wool. Spray on two coats and bake in oven at 450 degrees for an hour. No more sticking!
on Mar 23, 2010 | Black & Decker B2000 Bread Maker
Bread sunk
I have used a breadmaker.
You have "crater bread" ?
I suspect your final mixture is too wet. Reduce the amount of liquid in your recipe. The bread should stay firm and risen.
Mar 09, 2014 | Breadman Kitchen Appliances - Others
When my machine goes into the next to the last rise I have a loaf about 5' but then when it goes into the last rise before it bakes it never rises high again. The finished loaf is about 3 1/2" high....
Not fully understanding this but it sounds like you are opening the lid too much and spoiling the rise. Only open the lid when at the dough stage if necessary.
Bread will not keep warm, it will steam and go wet and soft in the pan. Open the lid when the cycle has finished and remove the loaf.
Try re-setting your machine by holding down the start button till the display goes out.
Jan 28, 2011 | West Bend 41048 Bread & Dough Maker
Whe breadmaker is finished, bread rises right up to the top of breadmaker and is wet on top.why
it is wet on top of the bread because of condensation that is collecting on the inside of the lid.
c...
Jan 04, 2011 | Kitchen Appliances - Others
Bread pan does not release loaf after baking.
The Teflon coating on the inside of the pan has worn. You will need a new pan and probably also a paddle. In the meantime you could try spraying the inside of the pan with cooking oil prior to each use.
Sep 21, 2009 | Kitchen Appliances - Others
My Black and Decker All in One Automatic breadmaker seemed to be working fine. It was making the right sounds but when it finished the bread was not mixed. The yeast was still on top with the flour and the...
Empty the bread pan and clean it out. Put the pan and paddle back in the machine but do not add ingredients. Start the bread cycle and look in the window (or lift the lid) during the mixing cycle. You should see the paddle spinning around.. If not you probably need a new belt.
Hank
Jul 27, 2009 | Kitchen Appliances - Others
Machine frozen
Read this on how I fixed a Regal Kitchen Pro 6725 with an Oster belt. Regal no longer makes or sells parts. My bread machine made all of the right noises, but the mixing blade did not move.....upon investigation, I learned that the drive belt had completely disintegrated. I measured for the length of the belt, found that an Oster belt would be the same size and length, and installed it. It works. I hope this helps you.
Hi, I have the same machine and the belt was in tiny rotten pieces...I wound a piece of yarn around the wheel and drive shaft (lie the machine on a kitchen counter, lid open and hanging down off of the counter, bottoms up, and remove the screws from the teardrop shaped brass colored safety cover, remove the cover and expose the wheel and drive shaft) pull the yarn tight and knot it. Then cut the yarn about an inch from the knot. Measure the yarn when pulled on a little. Mine measured 23.5"....I then googled bread machine belt 23.5" and up came one for an Oster Bread Machine (The one I was repairing was a Regal Kitchen Pro 6725) from totalvac.com located at 2 De Bush Ave Unit A8 Middleton, MA 01949
It was $7.95 for the belt, $6.95 S & H to a VA address, total cost $14.90 so I decided to give it a shot. When it got here, I removed the safety cover, held the machine up and shook as much of the old rotten rubber belt pieces out as I could, and replaced the belt by placing it over the sticky string on the drive shaft and teasing it over the wheel. It is an exact fit. Be sure the ribbed side of the belt is down against the wheel. Screw the cover back on and run it through a dough cycle so that the belt will get coated with the sticky stuff from the sticky string on the drive shaft. Until the belt is coated, it will turn the mixing blade, but it will slip. Hope this helps. Patti
image_icon_name.gifPatti Wilson
image_icon_date.gifSeptember 2009
Jul 02, 2009 | Kitchen Appliances - Others
Need the operting Manual for PerfectBaker PB571
Here's some info;
http://www.creativehomemaking.com/download/TR888_1183_Recipe_Book.pdf
Here is some operating instructions one baker used for this machine;
But here's how to actually use it:
Put wet ingredients in loaf pan. Heap dry ingredients on top. Make a well in dry ingredients and add yeast, ensuring it doesn't touch liquid if you want to use the timer. Put pan in breadmaker, clicking into place.
Plug in breadmaker but DO NOT touch the on/off button till the very last.
Using the "menu" button, choose what type of bread you're making (the top two rows -- normal, fruity etc).
Using the "crust control" select how dark you want your crust.
Using the "timer" select how long till you get the finished product. The minimum is 3 hours for quick bread/medium crust, which I often use, the maximum 14 hrs 30mins. It goes up in 30 minute increments with each push of the up arrow. Remember, what the timer shows is when the finished bread will be ready.
Once you're satisfied with your settings, press on/off
If you choose "fruity bread" the timer will beep into the kneading process to tell you it's time to add the fruit. It goes in at a later stage.
When the bread is finished, it will keep on a warm cycle for a while until you switch it off.
I use high grade flour and add 1 tsp gluten flour to each cup of flour. The bread rises more.
Apr 25, 2009 | Breadman TR888 Corner Bakery Bread Maker
Need to make gluten-free bread
bobs redmill gluten free mix for bread machines. we just use the standard bake setting but select B for doneness level. found it gets a little too dark on A.
Mar 20, 2009 | Toastmaster 1183N Bread Maker
Black & Decker Bread Machine Logo
43 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
