Hello, i have a car radio clarion 2419M PN and connectors available in the store do not fit. Can you give me the correct way to connect to the Parrot CK 3100?
Your radio is made by CLARION and the only CLARION codeavailable for free (using a serial number ) from anywhere on the Internet is ifyour radio also has a BARCODE SERIALNUMBER beginning with
C 7000000 + + ++ on a label somewhere on the metalcasing.
If not then it will only be available from your Main Dealer or a Decoding Service oryour local Car Radio / Audio Store who will connect a laptop to read/recode thememory chip (EEPROM) inside your radio
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
your radio alsohas a BARCODE SERIAL
NUMBER beginning with C 7000000 + + +
+on a label somewhere on the metal
casing.
If not then it will only be available fromyour Main Dealer or a Decoding Service or
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Normal
0
false
false
false
font-size:10.0pt;
Your
radio is made by CLARION and the only CLARION code available for free (using a
C7000000 + + + +on a label somewhere on
the metal casing.
memory chip (EEPROM
The
BARCODE SERIAL NUMBER beginning with C7000000 + + + +on a label somewhere on the metal casing.
POST A BRAND NEW QUESTION
if you have this barcode number
memory chip (EEPROM
POST A BRAND NEW QUESTION if you have this barcode number
Your
the metal casing.
(There
are usually two barcodes on one label. The one required is the lower one )
Unfortunately the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing. (There are usually two barcodes on one label. The one required is the lower one )
If you have the factory fitted nav then this is an integrated system and you will need to get the clarion repaired. If you give me a call I can advise you how to arrange to have the unit repaired 0161 428 2020
