Question about JVC Everio GZ-MG21 Camcorder
The camcorder records just fine. however, I can not get it into playback mode so i can download the video. Looks like the switch may be broked or something. Anyone know a trick to get the video downloaded? Once I get the video off I may open it up and see if i can figure out what is wrong with the swtich. Unless anyone has a answer for that also.
    Genius:
  • 1,812 Answers
The switch assembly is most likely the problem and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Posted on Dec 31, 2010
Malfunctioning One-Touch Navigation & Joystick Control
You can try first a reset from menu, then , if firmware is available you can reinstall firmware.
Sep 11, 2008 | Panasonic PV-GS300 Mini DV Digital...
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
No matter what mode I place the unit in..camera mode or playback mode...I get a yellow flashing triangle on the view screen. I can't record or do playback. Any idea what that yellow triangle represents? ...
I have the same unit and the problem your describing comes and goes from the power switch on mine. (wiggle it)
hope this helps (if it don't... get it fixed this is a cam that cant be replaced even broke they bring in 200 on ebay or did a few years ago )
Dec 14, 2010 | Sony Handycam CCD-TR517 Camcorder
How play the recorded video?
The controls for playback are on the touch screen once the camera is switched from record mode to playback mode, if the camcorder isnt playing back then you might ned to have the unit serviced, could be a bad video head assy. I hope this helps.
Sep 05, 2010 | Sony DCR-HC30E MiniDV Camcorder
Canon HV10 camcorder - can't get video mode to playback
hi, if you get blue screen,but your recording has been ok, then you must be change LCD FLAP, you sure get fix your camera,
Aug 30, 2009 | Canon HV10 HDV Digital Camcorder
Sony digital video camera mode no. DCR-HC14E not showing pictures/recording
If your Sony DCR-HC14E shows fine picture in playback of old tapes and does not give live view in camera mode to record then its CDD Imager problem that Sony will repair free of cost.
Click Sony CCD Imager Support for details.
Jun 10, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
Playback is choppy
I had this problem very recently. In fact I borrowed camcorders from my friends too and after short periods, they too started having the same problem. Essentially, it looks like there is some choppiness every second or so - like there is noise in the audio and video. After a lot of looking around, I finally found a suggestion posted that ACTUALLY WORKED on all 3 camcorders:
I placed an empty tape in the camcorder and recorded a few seconds into it. Then I removed that tape and tried to play the previous tapes that were showing the choppiness. No problems any more. Everything works fine.
What I still do not understand is why 3 camcorders (all DCR-TRV103s) all showed the same problem (with different tapes by the way). And since I still have lots of tapes to copy, I need to know why this problem is happening so I can minimize its occurrence while I complete the copying process.
People have suggested that my tapes are old and may be offering resistance to the camcorder. So I have ordered a rewinder to spin the tapes a bit before trying again. The two possibilities suggested around this was (1) some mechanical switching took place which got reset when recording; and (2) something got corrupted in the software that manages the playback buffer and that software was rebooted when it went to recording mode.
So while this will hopefully answer your question, I'm also looking for explanations for why this happened to me on 3 different camcorders.
Oct 05, 2007 | Sony Handycam DCR-TRV260 Digital Camcorder
Playback won't work
needs to be cleaned and possibly tension adjustments. most cases this will fit it but the video heads could need replacing.
Sep 14, 2007 | Sony Handycam DCR-TRV245 Digital-8 Digital...
JVC Everio GZ-MG21 Camcorder Logo
27 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
