Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My washer is making an awful sound on the spin cycle. It's only about 3 years old... any ideas?
Lumpy816
  • 246 Answers
SOURCE: Kenmore Elite Oasis 110.2706 Top Loader Grinding Noise
If you remove the back panel, there are two pumps towards ethier side at the botom of the tub. If you remove the back hoses (have some towels ready) You may find something in one of the two pumps.
Posted on Jun 13, 2008
TheMobilian
  • 8220 Answers
SOURCE: GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
It could be anything from a bad belt to a bad clutch to a bad tranny. In my opinion this washer is not worth repairing.
Posted on Jan 09, 2009
scottowa
  • 87 Answers
SOURCE: grinding sound during spin cycle
Is this a front loading machine? Also whats the model number when you open the door? If this is a front loading machine and you haven't been using HE soap, it's almost certain it's the brearing.
Posted on May 25, 2009
co7196
  • 3433 Answers
SOURCE: making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Posted on Jun 15, 2009
  • 72 Answers
SOURCE: NOISE DURING SPIN CYCLE
You have to take the tub out, take off the rotor from the bottom of the washer, remove 4 bolts and take off the stator, take off the bearing retaining nut, then drive the 2 bearings out with a drift. I bought the bearings online for 20 bucks from a supplier (VBX). They are standard metric bearings number 6005 and 6006. I put some silicone grease on the shaft seal and drove the new bearings into place. Then reassembled, and the washer is whisper quiet.
Posted on Feb 04, 2011
Problem during wash cycle
Possibly a foreign item like small change or a piece of metal from an article of clothing, pocket?
Mar 19, 2014 | Haier RWT360BW 3.0 Cu. Ft. Capacity...
Hotpoint Aquarius dishwasher making awful rumble/crackle noise
Have you cleaned the traps and run some vinegar through? They build up dirt from kitchen debris over time which causes the pump and spray rails to pick up sludge. You need to clean them at least every 6 months. Check farther on line for cleaning solutions to clean and maintain dishwashers. I have been hearing clr can be used but can't confirm this.
Oct 23, 2017 | Dishwashers
I have a whirlpool ultimate care 2 super capacity plus washing machine. We had it for about 7 years, just yesterday it stated to make an unusual noise when it was in spin cycle. As of today the washing...
My LSQ9549L is 7 yrs. old as well with an awful sound when spinning in high speed.
I've changed the agitator assy. as well as removed the drum and cleaned the soap build up on it.
Still makes a terrible sound in high speed spin. All other functions work.
Could it be the springs or coupling? I'm leaning towards it being the counter balance springs with it being rather weak. Could I be correct?
Your help is much appreciated.
Mar 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud noise in slow down spin mode.
when it is in high spin then you stop the washer it makes a thumping noise until the basket stops sort of like a flat tire sounds to me like you need a drive block
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Jet engine??!!
Friend,
ngafm at your service!
How old is the washer?
It sounds like the tire out of balance syndrome!
Like a car tire that sings or vibrates when it's out of balance!
It may be a worm part thats spinning and you should call service and not take any chances, with this matter!
How long has it been sounding like this?
Bless You
ngafm
Please give me a rating here at this site before you sign off!
Bless you
Please give me a good rating before you sign off !
Sep 05, 2008 | Frigidaire GLWS1439F Top Load Washer
Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
Jan 17, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Spin cycle noise
pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal De
