Question about Activa by Invicta Midsize Digital Red Watch for Men
The watch came with no readable instructions. The paper was cut at an angle so most of the instructions for setting were unreadable. How do you set Date Day time
Resetting timex ironman triathlon 30 lap FLIX after changing battery
this is the most important and confusing part in my opinion. On the white sticker the directions read: "after battery insertion, short pads to reset". this should look something like an oval with a line cutting it in half (vertically). It is not on the battery but next to it. You will need the paper clip here to hold down the right most side (at somewhat of an angle). this should do it! you'll know if your digital faces flashes numbers at you and may even light up. Make sure you hold down long enough.
6. Once you have the numbers flashing, you are good to go. Put the back of your watch back on, taking note of which screw goes where. Then, set your watch accordingly and you have just changed your watch! Ta-da!
Follow these steps and you should be good. Good luck to all!
Feb 25, 2017 | Timex Watches
Skmei # 1058 Pedometer watch - I didn't receive an instruction manual with my watch. I need some instruction to help set the watch...
Hi Keith
The guy in this video finds a paper manual in his package.
You can probably freeze frame it and take a screen snapshot of th manual. Cmd Shift 4 on a Mac places the screenshot photo on the Desktop
Good Luck SKMEI 1058 Waterproof Pedometer Heart Rate Wrist Watch
pedometer how to use YouTube
Mar 14, 2016 | Watches
I can't set my watch to 12 hr.mode. All I can get is military time. My watch is an ironman. W-230 is on the instruction paper
press and hold the upper left button of your watch, when the digit blinks, press the "mode" button/the lower left button until it reaches the "24" then press the middle button once, and the watch will show "12" then press the "set" button/upperleft button. i hope i had been helped you.
Aug 10, 2011 | Timex Watches
No instuctions for blue angle watch.
For all those who lost their Citizen watch instructions. Follow this link, fill in the details and download manual. http://www.citizenwatch.com/COA/English/settings.asp Interactive setting instructions on this site is very helpful as well.
Apr 30, 2011 | Citizen Blue Angels Skyhawk Watch
Lost the instruction paper that came with the watch and now don't know how to set it. It's a U.S. Polo sports watch.
mcdevito75 here, check directly with the watch maker on line, type in Timex, Casio etc.what ever the name of the watch is for the instruction paper.
Jun 15, 2010 | Watches
Trying to set my timex Rss 210 Heart Monitor Watch
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
May 27, 2010 | Timex Ironman 30 Lap 53952 Wrist Watch
I inherited a Timex chronograph from my Dad. It is not running, but I wouldn't know how to set it if it was. Can I get a manual? It is a WR 50 M
I have still not been able to find the model but if you go to the Timex web site "timex.com", it opens up as a page that says "software" and "instructions".
select "instructions" and a list of the types of watch available appears.
Choose "chronographs" and a set of instructions appears. I would expect all watches of the same general type to have every similar operating instructions, so this should be all that you need.
Note that the instructions appear unreadably small but the size of the font can increased to any size you need by altering magnification.
Jan 07, 2010 | Watches
Citizen Blue Angles Watch
Here is where to get instruction manual in pdf format Worked for me. Cheers
http://www.citizenwatch.co.jp/support/pdf/c650/e.pdf
Dec 12, 2008 | Citizen Blue Angels Skyhawk Watch
TCM Digital Watch
v:* {behavior:url(#default#VML);}o:* {behavior:url(#default#VML);}w:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Cmpass (COM)
The integrated compass tells you the direction (e.g.SSW for south­southwest) as well as the number of degrees. To determine a direc­tion,hold the watch horizontally with the 12 o'clock position poin­ting in thedirection you want to know.
General information about the compass
The compass always points to the magnetic north pole.Maps are always drawn in alignment with the geographic north pole (verticallyupwards at 90 ). The declination angle denotes the deviation between themagnetic north pole and the geographic north pole. This deviation depends onwhere you are located. To obtain exact results, the declination angle must beentered into the compass.Remember to change the angle when travelling abroad.Within the UKthere is no need to change the angle because deviati­ons are only slight.Overleaf you will find a table showing the declination angles for a number ofcities around the world.A fault has occurred if the display shows"ERR" while taking a direction or calibrating the compass. Thecompass must be re-calibrated (refer to section after next) .
Table of declination angles
Amsterdam 01 W Little Rock 03 E San Francisco 15E Atlanta 04 W Livingston, MT 14 E Seattle 19E Bombay 01 W Munich01 E Shanghai 05W Boston 16 W NewYork City 14 W Toronto 11W Calgary 18 W Orlando 05 W Vancouver 20W Chicago 03 W Oslo 02 W Warsaw 04E Denver 10 E Paris 02 W Washington DC 10W Jerusalem 03 E Prague 02 E London 03 W Rio de Janeiro 21 W
Mar 05, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Old style citizen wr100 blue angles watch how do you set it
I need an instruction manual for a Citizen Blue Angels Navihawk WR100 watch. Can you provide a free manual?
Nov 15, 2007 | Citizen Blue Angels Skyhawk Watch
Activa by Invicta Midsize Digital Red Watch for Men Logo
102 people viewed this question
Top Activa Watches Experts
Ansel Alberto
Ansel Alberto
ray gallant
Are you an Activa Watch Expert? Answer questions, earn points and help others
