Question about Whirlpool Washing Machines
The base of the agitator in my Whirlpool 5000 series 5 cycle is wearing. Where can I get a replacement agitator?
  • 413 Answers
Try here...http://www.searspartsdirect.com
Reasonable prices, usually gets parts within 3 to 5 days
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 08, 2008
AGITATOR SEEM TO BE SLIPPING, NOT ENGAGING COMPLETELY THROUGHOUT THE ENTIRE WASH CYCLE.
The agitator has under the cap what are called agitator dogs. They wear out causing agitator to slip. They sell a kit at appliancepartspros.com cost $10. Easy to replace comes with instructions.
Aug 18, 2010 | Whirlpool LSN1000LW Top Load Washer
The agitator does not completely rotate unless you press down on it.
If this is a Whirlpool manufactured top loader with a split agitator design, this is commonly caused by worn agitator dogs. The upper portion of the agitator (called the auger) has a cam assembly with small agitator dogs that act as a clutching mechanism to drive the auger during the wash cycle. They wear out over time and need to periodically be replaced. The following link explains what they are and how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link I provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit which includes the dogs, cam, seals and washers.
If you have any questions, please let me know. If this is not a Whirlpool manufactured washer (which includes Kenmore, Roper, Estate, Frigidaire, Kelvinator) please let me know. If you are in doubt, please provide a model number and I can confirm for you. I hope this helps you.
Oct 04, 2009 | Washing Machines
Whirlpool Quiet Wash II center pole doesn't spin.
No. This is commonly caused by worn agitator dogs. The upper portion of the agitator (called the auger) has a cam assembly with small agitator dogs that act as a clutching mechanism to drive the auger during the wash cycle. They wear out over time and need to periodically be replaced. The following link explains what they are and how to replace them:
If you have any questions, please let me know. I hope this helps you.
I have a whirlpool washer and the upper agitator (the one that is supposed to move the clothes down) is not working. What shall I do?
You need to replace the agitator dogs. Yes, there is such a thing. This is a very simple repair that should take 30 minutes or less. The following link explains:
The dogs are located under the Auger (thats the top portion of the agitator). They are plastic teeth that act as a clutching mechanism for driving the auger during the wash cycle. Over time they simply wear out. The part number is included in the link I provided. You can purchase replacements at appliancepartspros.com for about $5.
If you have any questions about this repair, or need additional assistance, please let me know. I hope you find this information helpful.
Sep 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Agitator top not moving, but bottom is
The problem you are experiencing comes from worn agitator dogs located in the agitator cam assembly. The following link explains how to disassemble the agitator to access the cam components:
In most cases, the small cam "teeth", called "dogs" wear out due to normal wear and tear and require replacement. I have included the part number in the link provided. Replacements can be purchased at appliancepartspros.com for about $5. If you need an illustration to assist you, searspartsdirect.com has some excellent exploded view diagrams that you can use for reference.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Aug 28, 2009 | Whirlpool LXR6432JQ Top Load Washer
I have a Kenmore washer 70 series. It runs
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 17, 2009 | Kenmore 20722
Crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
May 07, 2009 | Frigidaire FWSB5700DS Top Load Washer
Kenmore 90 series squeakes only during agitator cycle all other cycles ok
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
Mar 15, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series washer continues to agitate on spin cycle making noise while spinning
Mar 08, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 series washer making humming sound and won't agitate
Mar 04, 2009 | Kenmore Washing Machines
Washing Machines Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal De
