Just bought the TV for Christmas. Can't get the TV remote to work..have inserted new batteries and made sure the sensor on the tv is clear from any objects. Any other suggestions?
    Problem Solver:
  • 6 Answers
I had this problem with my Sharp LCD, stopped working with all remotes .Read on FixYa that all I had to do was UNPLUG the TV, press the power button on the TV for 10 seconds then plug the TV back in and it worked great. Worth a try!
Posted on Dec 30, 2010
Remote handpiece for Pioneer Plasma TV?
Have you tried new batteries? Make sure there are no objects blocking sensor on TV. Paper, packaging, clear protective films from original shipping, ...
May 07, 2014 | Pioneer Televison & Video
Remote does not work
Infrared sensor inside the TV is damaged. Replace it.
May 17, 2013 | Televison & Video
T.V. remote sensor not working
Hello
If you are sure that the fault is with the remote sensor of your TV, replace it with a new one. The remote sensor can be located just behind the remote sensor window at the front panel of the TV. You nave to open the TV to access it. It is a three solder terminal component. It will look somewhat like this, having brownish black in colour. This component can be bought from most of the electronic spare part selling shopw at your town; very cheap to buy too. OK
Nov 28, 2011 | Televison & Video
My remote will not work the tv anymore
there are three possible causes for this problem;
1. Batteries may be dead inside the remote.
2. Remote might be defctive.
3. TV remote sensor/infrared might be defective.
Battries; Simply insert new batteries into the remote and try again. If changing batterises doesn't help, problem as to be from the Remote or TV's infrared.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Yours sincerely
Elect_Comp.
May 12, 2011 | Televison & Video
Remote sensor not working on TV. Tried the original and several other remotes and none are working. Used new batteries.
pls. check tv is in chaild Lock mode / LOCK mode.
so check tv panal key use . is working ? NO then tv is in chield lock mode. see user's menual and set chaild lock trun off.
chek with new remot cantrol if not work then problum is tv set
[1] see tv frant panel on IR [simbol] clear with cloth smuthly [dust free]
if not working Remot cantrol then problum is inside tv .pls check tv by nr. tech.
Oct 30, 2009 | Televison & Video
TV does not respond to remote commands,
I'm sure you've tried this, remote batteries is most common cause.
Make sure sensors on TV and remote are unobstructed(remote only works if line of sight to sensor is clear) and clean. Windex and Qtip. Damaged/dirty/defective remote, try different if possible (universal). If none of above works(99% chance), extreme longshot is TV circuitry.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Remote only registers on 1/2 of the tv screen.
the lights on the christmas tree must interfere with the remote and sensor. we just have to make sure to turn off the tree when we play - go figure...
Dec 08, 2008 | Nintendo Wii Console
Remote control not working
If the new remote is not working either, it sounds as if the problem relates to the sensor on the TV combo.
If you bought it new last Xmas you should have some warranty left. I would get it looked at asap before the warranty expires.
Dec 02, 2008 | Televison & Video
Remote Sensor on TV Doesn't Work and Can't Manually Adjust Menu
I just realized that there is no usb port on this tv. Called tech support at vizio since I'm still under warranty. They're sending a new remote. I know it's not the remote because neither the verizon nor the vizio remote works, although the vizio remote will intermittently work if I'm one foot away from the sensor on the tv and holding the remote on a downward angle. Tech support says they will send a new remote to rule that out before they send a tech over. I'll check the posts to see if you find a solution when I finally get the tech guy out here. If not, I'll let you know what he does.
Good luck.
Aug 04, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Remote sensor
Bad connects at sensor inside TV or bad sensor.......
Toshiba part # 23009490............T.
Sep 21, 2007 | Toshiba 36A60 36" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
