Question about Zebra Eltron LP 2684 Thermal Label Printer
I am using a Zebra (Elton) 2684 Printer. I just upgraded my computer and it doesn't have a serial or parallel connection. Will a Parallel to USB cable work under Vista with this printer?
  • 124 Answers
Xerox printer
Depending on what port do you have on the back (or side) of the printer (USB, parallel, serial). Use the correct cable (USB, parallel, or serial cable) to connect the printer to the correct port on the computer (USB, parallel, or serial). You need to install the software driver on the computer before it will work. Google the name and model of the printer to download the driver to your computer.
Nov 09, 2013 | Office Equipment & Supplies
I can't get my computer running windows 7 to recognize the printer
Z6M+ printer doesn't have USB port, how do you connect this printer to Win 7 PC? if you are using parallel / serial converter to USB then good luck. Ideally to get zebra external printserver and connect the printer through the network.
Sep 25, 2013 | Zebra Z6M Plus Thermal Label Printer
I just bought a new computer and the connections don't match up. what do i do? I have the Eltron LP 2443PSA Thanks, Mike
I beleive your printer only has a Parallel interface and your new pc does not. You will need a USB to Parallel cable.
Parallel Connection:
USB to Parallel Cable:
http://www.buy.com/prod/cables-to-go-usb-to-db25-ieee-1284-parallel-printer-adapter-cable-db/q/sellerid/11408470/loc/101/205484702.html
Apr 17, 2011 | Zebra Eltron Orion LP2443 Thermal Printer
I need to add network to 2844 printer currently USB/Serial
You need to buy the zebranet PS2 print server
P/N G46692 External PrintServer II. It will plug into the parallel port. they just stoped making them but they are still for sale at zebra resellers. here is one at random from google
resize?sq=80&uid=1127727233 ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II
more at ZDTronic.com
ZDTronic.com $160.50
  • product
ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II $160.50 at ZDTronic.com
May 12, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Lp 2844 will not work with my new laptop
You need a piece of software to create a Virtual com port, make sure you have the comms set correctly 9600, n, 8, 1 and print to that port, you will find it clearly marked in Device Manager. You can get a parallel to USB cable then you can use your driver set to LPT1
Nov 05, 2009 | Zebra LP 2844 Thermal Printer
Zebra TLC2844 wont print at all
Try to make the self-test first:
Power OFF
Press "FEED" and keep it pressed and turn the power ON again.
Did it print?! if Yes... There must be a cable problem or port.
Is it USB? Serial? Parallel ?
Let's say it's Parallel, go to the command line and type:
"dir >lpt1"
without the quotes and assuming it's connected to 1st parallel port
did it print?!
on serial would be "dir >com1"
or, if it shows up in "Printers", pre-define it and just type: "dir >prn"
Still doesn't work!?
Try with a different cable, or other computer.
You can use it even without installing the drivers...
Sep 14, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Printer doesn't work when use usb parallel converter.
Forget about using parallel converter. Just use the USB cable it works best anyway.
Easiest way is this.
1: Turn printer on. (Green light. ready to print)
2: DISCONNECT the usb cable from the PC.
3 DELETE the Zebra LP2844 & Zdesigner drivers from the printers & Faxes folder. Just highlight them and hit the delet key. Don't worry Iknow what I'm doing.
4: Plug in your USB cable back into PC.
Just sit back and wait, your PC will automatically detect your printer and re-load your driver software.
Send me the cheque now!!
May 12, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 parallel communication problem
The printer is installed on the PC using a specific port. If it's installed on the USB port, it won't work on the parallel port. Do you have this printer installed 3 different times? Need more details such as how was it installed the first time? And if it's working on the other 2 ports, why does it have to work on the parallel?
Apr 15, 2008 | Zebra LP 2844 Thermal Printer
No response from 105Se
if the data light comes on and nothing prints chances are that the serial settings are set improperly. all of my printers are 25 pin serial, not parallel. i don't have one in front of me but i believe the settings are 19200, 8, 1, none. hope this helps.
Mar 19, 2008 | Zebra 105Se Thermal Printer
How to configure the Zebra S500 using a USB to Parallel adapter?
The Zebra Stripe S500 has a RS-232 SERIAL interface using a DB-25 connector . You'll need a USB to SERIAL converter, not parallel. Be sure that the baud rate and data/stop bits are set the same on the printer and interface converter. Generally speaking, use the fastest setting possible (19200 baud) unless you encounter problems.
Oct 30, 2007 | Zebra Stripe S500 Thermal Label Printer
Zebra Eltron LP 2684 Thermal Label Printer Logo
110 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
