Question about GE Spectra JGBP35 Gas Kitchen Range
Need to find a replacement part for spectra range model # 317B6034. the part fits over the burner and allows the burner to light. part #183D5612 and has 24 in the lower right.
SOURCE: Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Posted on Sep 05, 2009
jsrock516
  • 5911 Answers
SOURCE: Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Posted on Jul 18, 2007
freetek
  • 5568 Answers
SOURCE: Oven and broiler will not light.
You've probably done this by now since your message is May (makes us a May-December couple??) but wanted to write that the transformer that produces the park for ignition has failed.  I don't know how accessible it is in your unit, if you check on Sears website under Parts with your model # in hand, they could well have an illustrated breakdown of your range which would give you an idea of how difficult the replacement might be.
Posted on Dec 28, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Burners on a GE Spectra JGBP30 Gas range don't ignite
Try this link and download PDF has numbers and answers
http://lib.store.yahoo.net/lib/usappliance/JGBP35manual.pdf
Posted on Jan 31, 2009
MNTECH
  • 1543 Answers
SOURCE: natural gas orifice burners
Before you get too involved, check to see if the natural gas orifices are still with the range. Usually, when the conversion is done, the person who converts the range puts the original natural gas orifices into the holder which contained the LP ones, then replaces it. Look for an inch and a half long metal strip holding the four brass orifices held on by one screw very near the range gas regulator. (the regulator is the part the gas line connects to on the range) Also, look for the conversion instructions in the original installation and set up instructions, or attached to a sheet of paper on the back of the range. You will need to change the plunger in the regulator (Unscrew the cap, flip the plunger around, and replace) and turn the orifice spud on the bake and broiler burners three full turns counter-clockwise also. (using a 1/2 inch open end wrench, counting twelve 1/4 turns) Orifices will require a 7mm or 9/32 inch nut driver or socket to change. The orifices are different for the simmer, regular, and high output burners. (have a "I", "II" and "III" marked on them to help identify them, respectively.) The left two burners are both "regular output" burners, and use the same orifices.
Posted on Apr 20, 2009
The gas stove model 317b6034 keeps clicking like when you turn on the burners what might be the problem
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 25, 2011 | Microwave Ovens
Bought used ge spectra range had to change the power cord to 3 prong to fit outlet--now nothing works except light when turning burners on and clock
Did you hear a "pop" or smell like something was burning? Sounds like old oven could have been 3 phase, and you new oven single phase, Check the power requirements for oven and see what kind of power you are supplying it with.
Mar 30, 2010 | GE Spectra JBP78 Electric Kitchen Range
It sparks but doesn't light Spectra XL44
Do you actually see the sparking or just hear it ? If you see it, then you have a gas problem or the burner caps are not correctly seated, or the burners are covered with baked debri and will not allow the spark to start the gas. If you only hear the spark but do not see it, then there is either too much dirt/grease that is blocking or bleeding away the spark so it never gets to the burner or thee is a faulty connection under the range top or a bad spark module that is weak and needs replcement. Goodluck, Macgivor
Jan 25, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove top burners won't light.
Susan, there is no pilot flame on the Spectra models of ranges. However, the possibility that the electronic ignitors have gotten soaked and are shorting out is quite likely.
You should disconnect the power to the oven and remove the burner grates, burner caps, and the burner assembly cores to expose the ignitor posts. Check to see if there is any remaining water there and clean off and dry the ignitors and burners completely, as they might have something on them causing them to short out against the stove top, rather than spark properly, as they should.
Once you've cleaned and replaced the stove top parts, restore power and try to light each burner, one at a time. If none of them spark or light, then you need to check to make sure you haven't tripped a breaker for the stove or a GFCI outlet that the outlet that the stove might be plugged into, somewhere in the Kitchen.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Range will not light
Hello trackphitrac ,
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, you have gas is present but all burners will not light !
What is the model number and age of the gas range.
Does it have electronic ignition?
If so did you check the breaker, that it is still on and that it has power?
If you have power to the clock or any thing else and the range has an electronic ignition,
that will not light, perhaps there is a fuse in the rang?
I need the model number!
Huuum
Sep 22, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Electric starter for Electric stove
I think you mean you have a gas range with electric ignition. When you turn a burner to light, all burners should spark. The most common problem is boil overs have happened on those two burners. Take the burner head off for sealed burner ranges and clean them out. For non sealed burners, the little holes toward the center side of the burners need to be cleaned. You don't have a model listed, so I can't be real specific.
Aug 15, 2008 | GE Spectra JBP78 Electric Kitchen Range
GE Spectra JBP30B0B4WH surface unit light stays on
If it's the light that indicated the element is on, replace the switch. If it's the light that indicated the element is hot, replace the element.
Jun 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
Burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
Oct 08, 2007 | GE Spectra JBP78 Electric Kitchen Range
GE Spectra JGBP35 Gas Kitchen Range Logo
147 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
