Question about Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer
Doesnt heat thermostat was replaced and fuse replaced still doesnt heat
  • Barrett Palumbo
    Barrett Palumbo Dec 30, 2010
    how did you check to see that the fuse was defective, and how did you check to see that the thermostat was defective.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the model number of the dryer? I did not see where you checked the "heating element" on the dryer. Check the element for continuity.
Posted on Dec 30, 2010
My whirlpool dryer LER4634PQ0Runs but doesnt heat up?
It could be a number of things, but i would start with these first:
THERMAL FUSE.
The thermal fuse is designed to prevent the dryer from overheating. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
There are also a couple of 'thermostats' that could be the problem:
The 'high limit thermostat' is a safety device mounted on the heating chamber and is designed to prevent the dryer from overheating when the exhaust vent is restricted. A restricted vent will cause the high limit thermostat to trip or activate, interrupting the circuit to the heating element or gas valve. The high limit thermostat is not designed to activate repeatedly like a cycling thermostat and will eventually fail causing a no heat symptom. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter. If there is no continuity then it will need to be replaced and the restricted vent system corrected as well.
OR:
Cycling thermostats control the temperature inside the dryer drum. They are designed to "cycle" the heating element on and off to maintain the correct amount of heat. Cycling thermostats are normally located on the blower housing or elsewhere in the internal airflow ducting. Over time, the cycling thermostat can become defective. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter.
I hope this helps you fix the problem.
Dec 02, 2013 | Whirlpool LER4634PQ Electric Dryer
My Maytag Performa dryer is not heating at all .What should i do? Everything else works it just doesnt heat.
Hi
Replace the thermal fuse, and if possible test the heating group (thermostats and element or gas heater). You can replace the fuse straight away, or you can first test it using a multimeter set on OHMS. If the multimeter reads Ohms infinity when you touch the fuse contacts with its probes, then the fuse is gone.
If the fuse is OK, then you can have a defective thermostat or heating element (electric models), with gas models you test coils, thermostats and ignitor (flame sensor rarely fails).
After fixing the problem clean lint from air ducts, if the thermal fuse or thermostat has blown it means that there had been overheating.
May 09, 2011 | Maytag Dryers
My gas dryer heats but doesnt heat correctly, takes along time to dry the clothes
Hello
When the dryer wont dry clothes or won't heat at all it means that the issue is with the Thermostat/Thermal fuse that needs replacement as it has gone bad. Please check the thermostat for continuity as no continuity between its two pins states bad fuse. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Dryers
My dryer runs and turns but doesnt heat up or dry clothes
It sounds like you may need a GE element part number WE11M23. this is a common problem and can be replaced by taking out the drum and exposing the large circular heating element. the thermostats on the heater housing can usually be re-used. secondly check you house fuses as this can save you alot of grief. it is possible that simply a wire has been burned or your cycling thermostat is gone. I would need a model number in order to give you a part number for this. hope this helps.
Thanks
Oct 12, 2009 | GE Dryers
Dryer doesnt heat up
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Jul 07, 2009 | Roper Dryers
Kenmore dryer doesnt heat
You may also need to change your thermal fuse and the thermostat. On some models the thermal fuse operates the heating element only and others the whole dryer
Mar 19, 2009 | Dryers
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Coolant pouring out surge tank
if one radiator hose gets hot and the other doesnt, the the thermostat is shot, but you said you replaced it, it is possible the thermostat has been put in backwards
Nov 21, 2008 | 1999 Pontiac Grand Am GT
Fridgedaire Gallery Gas Dryer no heat
replace ignitor if 120 volts to it and it doesnt glow red. ohm all thermal fuses & thermostats. if ok replace sensor.
Apr 25, 2008 | Frigidaire FGQ332ES Gas Dryer
IT RUNS BUT DOESNT HEAT
It's either a heating element or thermostat gone bad. This link will help you locate what to look for. http://www.partadvantage.com/store/categories/wp/LGR6620PQ0
Mar 20, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
