Question about SkyScan 86742 Digital Atomic Wall Clock
What causes the temp reading of LL.L? - SkyScan 86742 Digital Atomic Wall Clock
  • 7 Answers
The SkyScan temperatures only register a certain range, typically -4F to 158F. If it is below this range, it will read LL.L and above it will read HH.H. However, I have been having trouble with mine reading the correct temp, so I often get very whacky numbers, and LL.L is becoming more frequent. Hope that helps!
Posted on Nov 19, 2014
Instant dig read thermometer shows LL and I can't get a reading
LL means that the sensor is below the rated temp It could be a bad sensor.
Apr 11, 2017 | Home
I have a 2006 expedition 5.4 the temp gauge stays on cold whats wrong?
check your coolant. the temp is the water temp. Your radiator is out of water? you`ll burn out your water pump. Also check to see if your radiator fans are running constantly.
Apr 23, 2014 | 2006 Ford F-150
It says LL under current temp. What does that mean
That means that sensor believes the temp to be LOWER than it can read. Could be a bad sensor. If there is a reset button on the sensor use that to reset the device.
Sep 23, 2013 | Taylor 1479-21 Digital Thermometer
Springfield precise temp # 91455 reads LL.L on the outside temp gauge.
"L" is probly for low... try replacing the sensor component
Sep 19, 2013 | Computers & Internet
1994 Pontiac Grand Am - floods and will not start
Two things I would be curious about. One is what the coolant temp sensor is reading. You will need a scan tool capable of diplaying data in order to check this. If the coolant temp sensor is bad and the PCM is defaulting to -35 degrees Fahrenheit it will cause the engine to flood. The other thing I would like to check is compression. If there is low compression it can cause this symptom. Let me know what you find with those. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Feb 15, 2012 | Pontiac Grand Am Cars & Trucks
1991 Chevrolet cavalier 2.2 auto Changed radiator, temperature switch, coolant sensor, thermostat, thermostat outlet housing adapter, gaskets. Gauge still shows running hot.. Max at 260-redline, But no...
The first hing I would do is confirm the engine temp with a scan tool. If the scan tool is reading a normal temp, 200 to 220 degrees with the fan coming on at around 220 degreese, and the gauge us reading much higher than the gauge is most likely bad. If the fans are not coming on than you need to look into that. Fuses, relays, wiring, fan motors would be the basic things to check. If you need more help with figuring out the fans let me know. If the fans are coming on, the temp gauge is reading the same as the scan tool data that there are a couple of possibilities. Either the system has air in it from nepot being properly bled or the headgket is bad forcing air into the system. Air will cause the cooling system to lock up. If you are try ing seeing the temp gauge spike to 260 degreese the head gasket is likely to have or will fail soon. Like I said if you have any further questions let me know and I'll be happy to help.
Sep 30, 2011 | 1991 Chevrolet Cavalier
V6 96 camry sluggish performance when cold,as soon as engine up to temp performance good.
clean the throttle body . that will cause sluggish starts,, you may want to get the codes read to make sure its not a o2 sensor, check around there are many places that will do the OBD code check for free,, once you get the codes post them on here and people will assist you with what they mean, if you reply to this feed I'll help you ,
Sep 11, 2011 | Toyota Camry Cars & Trucks
This unit has temp reading capability Where do you connect the temp probe leads
this should help you,, I'm not sure if you mean to the meter itself or to what your testing, this link helps with temp readings Hope this helps, if not,, reply back to me and let me know, and I'll find your answer http://www.ladyada.net/learn/sensors/tmp36.html
Jul 09, 2011 | Gardner Bender #GDT-200A 7 Func Digital...
SkyScan 86742 Digital Atomic Wall Clock Logo
466 people viewed this question
Top SkyScan Home Experts
nejones57
nejones57
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a SkyScan Home Expert? Answer questions, earn points and help others
