Question about Watches
How do I change day and number? seiko 5 7009-3120 A1
Is there a way to get seiko to repair my 7N43-8A38 "A1" Watch?
If it has a battery op movement you could have a non original batt op movt installed for 15 bucks and it will work like new but if it is a mechanical movement then you will have to replace necessary damaged parts
Feb 01, 2015 | Seiko Watches
The date on my Seiko SWZ054 watch has the correct date but wrong day. How do I fix?
Welcome to Fixya. Can you please provide the caliber number of your Seiko SWZ054 Wrist Watch for me to be able to check the manual and give you the information on how you can update the day on it?
Thank you for using Fixya,
seancarlisle
May 13, 2011 | Seiko SWZ054 Wrist Watch
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
How to set a month on seiko ska401
mcdevito75 here, The month you mean the date (number of the day in the month) your Seiko should show the day / date Here"s how.--- To change the day (Monday, Tues. etc) simply pull out the stem and turn the hands around until you reach the day, now push the stem in all the way, and gently slip your fingernail under the stem and gently lift the stem to it"s first notch or position, Seiko watches have a 2 position stem to make changeing the date, (number) easy so you don"t have to keep turning the hands around and around, with the stem out to it"s first notch or position simply turn the stem either toward you or away to change the date, (number) when done push the stem back in and your done.
Jun 23, 2010 | Watches
I just purchased a vintage Seiko automatic DX and I can't figure out how to change the date and day that appears on the watch.
mcdevfito75 here"s how to change the day and date on your vintage Seiko watch, Pull the stem out to the set position and simply turn the stem (winder) every second time around to the 1--2 3 O"oClock position the day will chage, once you get the day push in the stem in all the way, NOW with your fingernail just under the stem (winder) gently lift the stem up to it"s first notch or position, with the stem at this first notch or position, you can turn the stem and the hands won"t move but the date(number) will change, simply go to the correct number / date and your done, push the stem back in a your ready to go.
Jun 22, 2010 | Bulova Watch
How do I adjust the day of the week on my Seiko
Hello Bob, Mike D75 here, The day of the week can be changed by pulling out the stem to set, every second time to 12"Oclock--2 O'Clock will cause the day to change.
May 28, 2010 | Watches
Previously accurate Seiko dive watch suddenly gaining 1-2 hrs/day
if your watch caliber is 7s26b(look at the case back plate)is a usual problem of those calibers!the hair spring stuck somehow and the watch runs!a seiko authorized sevice center can help you!dont let anybody else magician to ruin your watch!is a routine repair for someone with knowledge and support from seiko!
Dec 11, 2009 | Seiko Divers SKXA35 Wrist Watch
Watch setting instructions SEIKO 7N43 8A39 "A1"
If you are still wondering about this, pull the knob out to the first click. turn one way to set day, turn the other way to set date. Pull out further to set time.
Aug 05, 2009 | Seiko SGF204 Wrist Watch
Setting Date. Seiko SGF204 (w/ 7N43 Band) French & English Days.
If you pull out the stem 1/2 way, you set the date one direction, and the day the other. If you pull it out all the way, it moves the hands and sets the time.
Dec 01, 2008 | Seiko SGF204 Wrist Watch
Watches Logo
248 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
