Question about Frigidaire Affinity ATF7000E Front Load Washer
My door will not shut on our Frigidaire ATF8000FS1 front loading washer. The latch is below the locking mechanism. If I lift the door up it will latch fine. Is the door height adjustable? How do you raise the door or do I need a new hinge? I have 3 screws holding the hinge onto the washer but I cannot tell if these are the 3 to remove to raise the door. The screws are on very tight and I do not want to strip them if they are not the correct ones to adjust the height
5 Suggested Answers
  • 868 Answers
SOURCE: Door Leak
Not usually ,replace the gasket if you cant re set the old one.
Posted on Jun 03, 2008
SOURCE: Frigidaire Front Load Washer won't Spin
i fixed mine about 5 times and its always some thing diffrent.
try buyng the inexpencive parts first and leave for last the electronic control panel.
it could be that your washing a smaller amount than the recomended.
Take it to a profesional. dont do like me a DIY guy. Some times i need to take pictures when taking the monster appart and then because they are somany screws missing duct tape, rope or hangerwire becomes usefull.
All mechanics are wise guys you and me are thevictims.
Posted on Dec 02, 2009
  • 44 Answers
SOURCE: how do you adjust a door on an frigidaire front
Many of the Frigidaire FL Washer doors have issues with the hinges. They break and then sag. This eventually results in the latch going bad. I don't have a fix for that other than replacing. If anyone else has a fix, please chime in. I've seen this alot...
Western Appliance Repair Meridian Id
Posted on Dec 02, 2010
  • 618 Answers
SOURCE: I have an ATF8000FS1 front
There is next to no adjustments so if the door dropped then the hinge must be bent . You may be able to very gently pull up on the door and re-align it but most likely you will have to replace the hinge.
Posted on Feb 26, 2011
Door on Frigidaire front load washer loose
have you tried this:
The screws maybe stripping(wearing out) or the hinge bent, should be able to visual look at both. I hope this helps. Tim
Apr 24, 2017 | Washing Machines
Frigidaire washer door
Hi Ryan C - From what you have described since you have already replaced the door lock assembly, you may possibly have a communication error with the control panel not responding.
Sep 20, 2012 | Frigidaire Affinity ATF7000ES Front Load...
The door on my fridgidaire atf8000fs1 sags so it doesn't shut correctly. I've had to order a new door striker since the last one broke off. How do I adjust it so it hangs correctly?
Frigidaire washer door sagging so strike and door lock not lining up correctly. After a period of time front load washer doors tend to start to drop below normal position. The glass in the front doors are very thick, heavy and only supported by plastic inner frame. This combined with continued opening and closing will over time make your front load door start to sage. Fortunately Frigidaire makes a door shim kit for this problem.
After you have ordered and received the shim kit part #137309800. Start with removing the three screws holding the door to the machine. Lay the door face down on a soft surface as to no scratch the front of the door and glass. Remove the screws securing the outer frame and with a very small flat screw driver shim it between the inner and outer panels. Make sure to note the position of the frame and glass. Next remove the inner plastic frame, you should have access to the hinge at this point. Install the shim kit according to the instructions that come with the kit. Reinstall the hinge, inner frame and screws. Install the door back onto the washer, your door strike and lock should line up in the correct position at this time.
i got this answer at
Jun 19, 2011 | Frigidaire Affinity ATF8000FS
I have an ATF8000FS1 front loading washer. The door is hard to close and subsequently broke the door strike. If I lift up on the door it aligns the strike better with the latch. There appears to be no...
Feb 26, 2011 | Frigidaire Affinity ATF7000E Front Load...
The locking mechanism latch broke and we replaced it
helps to lift the door a lil when shutting it hinges may be worn and latch is easy to get to just take the clamp loose around the boot and 2 screws hold it
Jul 07, 2009 | Frigidaire ATF6000ES Front Load Washer
My frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
135 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
