Question about Mitsubishi Televison & Video
Brand new 73838 series DLP 3d Mistsubishi TV when turned off always has to have the tv rest for inputs to display a picture. OK as long as you keep it on....if turned off, you have to reset tv with on button in frontb of TV.....This just aint right
  • 876 Answers
This is a brand new television. Any problems should be reported immediately to the manufacturer or to the store where you purchased it. You should register the warranty immediately online if you have not done so. Please read through the troubleshooting section of your manual to look for an explanation for your problem. Please also check all connections comparing them to the diagram in the manual. Any variation can cause problems. If you did not keep the manual, an online copy is available at
http://www.mitsubishi-tv.com/pdf/738-838_BIB_v3.pdf. You can print it out or save it to your desktop for easy reference. It is in pdf format, so you may need to update your adobe reader at http://adobe.com. Look under downloads and you will find the free adobe reader.
Good luck to you and thank you for using FixYa.
Posted on Dec 30, 2010
I need info on a particular TV
Resolution is 1080P (1920x1080). It is 3D ready, and has very good reviews from owners regarding picture quality and overall value. One limitation you will encounter, is that it is more difficult to see the screen from the side, than it is with LCD or plasma. Also, due to lamp warmup times, it takes longer for the TV to turn on. However, you will save a lot of money by purchasing a DLP versus LCD/LED/plasma.
Nov 29, 2013 | Mitsubishi WD-60C9 60" DLP HDTV
The status light on a wd-73838 and a wd-65838 keeps flashing
the problem on this tv is the dm pcb , not the dmd , or may i say main signal board , also u can open the tv and chack for bad capacitors but if there is not bad capacitor you would need to replace the main pcb
Feb 12, 2012 | Mitsubishi WD-73838 73" HDTV-Ready DLP TV
Visio LCD LED 3D tv how do you watch tv in 3D?
For the M3D420 Vizio TV, you need a 3D source connected to the TV with an HDMI cable that supports 3D. Some older HDMI cables will not carry all of the data of a 3D source. Turn off the set top box (for example a 3D Blu-ray player). Set your TV to the correct input (press the Input button on your remote). Then turn on the set top box and (for the Blu-ray player) insert your 3D content disc. Start playing the movie. When you see the prompt "3D content detected", highlight Yes to switch to 3D display and press OK to start the 3D playback.
After selecting Yes and pressing OK, then put on your 3D glasses. Make sure that you are sitting with your eyes level with the TV screen eye-line and looking straight at the screen. (If you are off-line, you will not get the 3D experience.)
These directions probably apply to all 3D Vizio TVs. I hope this helps.
Dec 28, 2011 | Televison & Video
Mishibishi tv 73838 diamoind series humming noise in the back
Your problem is most likely a defective color wheel. This part is an internal component of the optical engine. The V43 chassis has had an excessive amount of issues with the color wheel failure. Part number is 938P179010
Bill W.
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-73838 73" HDTV-Ready DLP TV
Will not power up and the lamp light is flashing. I have replaced the lamp and have the same problem.
Recheck the projection lamp installment again,make sure all the connections inputs are tightly and correctly connected.When u closing the proctive tv projection lamp door,make sure u don't hit the blue reset switch button and close the door properly and make sure screws it in to fit correctly and tightly.Follow these steps,should get ur tv back up and running again.
Nov 20, 2010 | Mitsubishi WD-73838 73" HDTV-Ready DLP TV
I have a HD50LPW175 tv with sound but no picture can anyone help
Do you see any display on tv screen like Menu etc?
Does tv give no picture in all inputs like tv/ cable, dvd input?
How old is this tv and when did you replaced its lamp last time?
Thanks.
Aug 26, 2010 | RCA HD50LPW175 50" HDTV
Toshiba DLP 60" TV not showing TV programs, sound ok
Have the tuner signal board replaced. HDMI does not use the regular tuner bands, it is bypassed when using hd inputs.
Aug 25, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
Televison & Video Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
