Question about Kodak EasyShare CD93 Digital Camera
Kodak C93 EasyShare. When using the USB method to transfer photos, only some of them will transfer. Then I have to go back in and try to figure out which ones didn't make it and transfer them in separately. For example, this morning, I tried to transfer 80 pictures to my computer. Only 29 went through. All messages said that they had been transferred, but when I went into that folder... only 29 of them were there. It does this every single time. I'm an eBay seller, and I don't have the time to re-transfer photos, much less go through each one and try and figure out which didn't transfer. If I just do a complete transfer again, then I end up with duplicates, which is also time consuming when I go in to edit them for my listings. I've had the camera for a couple of years now, and I can't remember just when this started, but it's been going on for several months. It's not so bad when it's only off by 10 pictures or so.. . but today, it's off by over 50. And that's a lot of my time. Thank you!
  • Anonymous Apr 13, 2011
    Actually, that's what I started doing about two months ago, and it does the same thing. The first couple of times, it worked perfect, then it started limping through and picking out only one or two to transfer when I selected ten, or only ten when I selected sixty or similar. My tower has a card reader built into it, so I can't blame a USB or other connection anymore. I suppose it may just be the card at this point...
    Thanks for your answer!
    I'm using Kodak's EasyShare, and I had never had a problem with it before with my previous EasyShare camera. And this camera worked all right with it at first as well.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Apr 13, 2011
  • kakima Apr 13, 2011
    What program(s) are you using for the transfer?
I have a problem putting pictures on my laptop (I have a Kodak Easyshare C195). It used to work fine. I would plug in the camera to laptop, photos would be on the laptop. Now I just get this message: For...
Hi there
There are basically three methods of looking at & copying photos from your camera to your PC.
1. Often, and Kodak certainly do, the camera manufacturer will bundle software with the camera, to ease the transfer of photos. Kodak Easyshare is certainly one of those. I would suggest that you use the CD that came with the camera to re-install the software exactly as you did when you first got the camera. If this does not give you back the transfer yo want you could try these methods.
2. Removing the memory card from your camera and inserting it into the card reader slot on your laptop (most modern laptops have a card reader). It does assume that the card you use in the camera is compatible with your card reader.
3. Connect your camera to the laptop via a USB port with the lead which will have been supplied with the camera.
In both cases the camera/card will show up in "My Computer" as a removable drive. Which letter it uses will depend upon the configuration of the computer.
Double click on this drive and navigate to the folder holding the photos (probably named "DCIM") which will be files in numerical order with the ".jpg" on the end of the file name.
These files can then be cut/paste or copy/paste to an appropriate folder on the computer. Most recent versions of Windows will preview these files when they are double-clicked, or in some cases create a slide show of all of them for you.
. I have found this
EasyShare Software Help
which may have information in it relevant to yourself, I didn't go all through it
I also eventually found this Extended User Guide for the C195 here:
http://resources.kodak.com/support/pdf/en/manuals/urg01134/C195_xUG_GLB_en.pdf
which may be of even more use, especially as this can be saved to your computer for future reference.
Hope this helps
Dec 19, 2014 | Kodak Easyshare C195 14 Mega Pixels...
Kodak z710 I cannot transfer photos onto my computer.
It may be time to buy a card reader for your computer. You can get one at a department or electronics store for not much more than a cup of coffee.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Dec 11, 2013 | Kodak EasyShare Z710 Digital Camera
I have a Kodak Easyshare c913. My computer does not have a place for memory card. When I try transfering with it plugged in, not all the pictures transfer. Why?.
Hi there! What method are you using to transfer photos when you connect your camera to the computer? Does a Kodak program open up automatically and start doing it for you? If this is the case, it is possible there is a setting in it that only transfers the most recent photos--ones that have not been transferred before.
I would recommend using the Windows tool. It should automatically pop up when you connect your camera, and ask what you want to do. Choose "Open folder," as shown below. Once the folder opens, you can highlight all of the files and copy them, then paste them into a folder on your computer (I would recommend making a new folder under My Pictures). This method is basically treating your camera's memory card as an external hard drive--you are controlling what gets transferred, rather than letting a program try and guess for you.
I hope this answers your question!
Mar 13, 2011 | Kodak EasyShare C913 Digital Camera
Problem for Kodak EasyShare One Digital Camera Kodak easyshare camera not transfering photos
check device manager to check if the camera is detected properly when connected via USB, try deleting the camera device then reconnect the camera and the drivers should re-install. hopefully you should then be able to transfer images from the camera.
if this fails try using a memory card reader instead of transferring directly from the camera.
Jun 19, 2010 | Kodak EasyShare One Digital Camera
I pushed my USB cable from my Easyshare Kodak camera, into another camera, now my camera wont load pictures onto my PC Can this be fixed by buying a new USB Cable?
That's the simplest and cheapest method of finding out. USB cables are cheap; try another. Hopefully you didn't transfer the damage from the USB cable back into your Kodak. If the USB cable looks damaged, then more than likely that is your problem.
If your memory card in the Kodak can be removed (and the pictures are on it) you can also get an inexpensive card reader (Targus, ~$12 at Walmart) to transfer your images to your PC.
Nov 28, 2009 | Kodak Easyshare M753 Digital Camera
I have a kodak camera and want to download photos to computer
Try to install the Easyshare Software included in the package when you bought the camera, after that connect your camera the the USB port at the back of the computer using the USB 2.0 cable included also in the package.from there you can access the easyshare software and click on the transfer button on the software.
Oct 30, 2009 | Cameras
Can't transfer photos from computer to digital frame
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw)
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Jan 17, 2009 | Kodak EasyShare M853 Digital Camera
Transfering pictures on from a different camera.
Try re-installing the driver software. Ensure that all the electrical contacts on the camera, cables and dock are clean and free from obstruction. If all else fails, USB card readers are cheap, and handy for other things. This is what I use.
May 14, 2008 | Kodak EasyShare C875 Digital Camera
My kodak easyshare camera will not transfer my photos to the computer. Everything is plugged in and the camera is blinking but nothing is happening. Please help. I checked the connections, they are fine.
Nov 01, 2007 | Kodak EasyShare One Digital Camera
Kodak EasyShare CD93 Digital Camera Logo
113 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
