Neptune front load washer Model# MAH3000AWW is leaking from front door and of course it is intermittent. Has anyone found a fix for this problem?
  • benderdome Dec 31, 2010
    We'll check it out. Thanks
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Look at the "door boot drain" to see if it is clogged or torn. Here is a link to the replacement part if you should need it.
Posted on Dec 30, 2010
Model MAH3000AWW won't spin
As giving info it seems it needs new control board and door lock .as I could see this is very old model and parts are very expensive
May 06, 2014 | Maytag Neptune Washer Door Mah3000aww
Maytag washer wiring diagram
machine start when you push the start button but stops 3 or 4 seconds after the button is released help me dennis montgomery maytag neptune model #mah3000aww
Aug 27, 2010 | Maytag MAH8700AWM Neptune Front Load...
Need to change tub bearing on frontload neptune model mah300wwa 2nd.year productoin
That bearing is part of the outer tub and is a big job.
you can get a diagram here . The bearing is not shown because it is part of the outer tub.
I would verify that if you decide to do this. but I remeber doing just one and it was a $600.00 Job, Of course that was with labor. the tub itself is over $425.00
the model # I used was mah3000aww
Jan 13, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Hi just got a set neptune model mah3000aww the
your main control board and the actual lock,
open the three screws on the top of the control board..
you will see the machine control
without disconnnecting the wires , inspect the board as closely as uou can your looking for physical burn on the board,,,, this usually takes place on the lower left area of the board
there you will see a burnt resistor, r-11
you will need to replace that control http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46137&diagram_id=692382#d692382
the board is 138.00
you will also need to replace the wax motor lock above the door
but is sounds like you just bought them
do you have a wrrenty of sdome kind
if you wish to make the repai let me know i will walk you through it it prety easy but can be tricky
Oct 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Neptune washer model # MAH3000AWW has developed an excessively loud noise during spin cycle--what is wrong and how much to fix??
It sounds like the bearings in the rear outer tub have gone out. This is caused from using powder soap. ( It also happens with liquid sometimes) This is a common problem with front load washers. This is a also a very costly fix. You have to replace the whole outer tub assembly. To get an exact cost just call your local service tech and tell them what your problem is and they can give an idea how much it will be.
Jun 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kent
take the four screws out of the dispenser on top of the machine. take the door and front panel off the machine on both sides there is a 5/16 bolt that holds the lid down take them out lift the lid now you can see the lock mach
Dec 20, 2008 | Maytag Neptune MAH5500B Front Load Washer
Door won't lock
There is a very small chance the door latch is bad.My opinion with this model is your control board may be out.If your door does click in when you close it then the lock will will activate by the control board.If it wont click shut at all then of course it wont be able to lock.In this case you do have to change the "Door Latch Assembly". Please rate this !!!
Sep 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune m/n MAH3000AWW burnt R11 resistor
STOP
There is a short in the door lock (very, very common problem )
Go to ebay and search neptune washers and im sure youll find a site i was selling a kit to repair this. If you cant find it let me know ill look .
Jan 18, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
Top Washing Machines Experts
