Question about Video Game Consoles & Games
Can't run in forward direction on any game - Video Game Consoles & Games
  • 62 Answers
Have you tried using a different controller?
Posted on Jul 08, 2008
1983 Johnson outboard . Model J25TECTE. Runs Forward/Reverse. Shift rod connection OK. Shift in neutral it runs in reverse. Do I need to change something in the gear case section?
you have removed the leg to replace the water pump impeller
the leg has the selector rod for the forward and reverse action
as the direction selection is a simple dog that moves forward or back to connect the spur gears and it was working before you pulled the leg off , then I am thinking that when the leg was reassembled that the selector was in a wrong position and now you are only moving it in one direction neutral or reverse instead of the 3 positions forward neutral reverse
nothing else can change except where the rod connects in the leg
Jul 07, 2016 | Boating
My left anolog stick won't let me move forward on games
The analog stick may have worn out. They are replaceable, but you might have an easier time picking up a used one cheap.
Nov 10, 2013 | Sony Wireless Controller for PS3
My brand new Sante Fe "O" guage quit running in the forward direction after about 15 minutes on Christmas Eve. I took it to the dealer and was treated rudely by the repair person. I was accused...
If sounds like something is wrong with circuit board that controls direction. If it is new it should still under warranty. Find a decent repair shop from Lionel and bring it in.
Feb 01, 2011 | Lionel Santa Fe Diesel Locomotive Engine...
Is it impossible to run Act of war Direction Action on Windows 7?
It is not impossible.
*install patch V1.06
*close all other programs running on the backround
*run the game with with administrator account or with administrator rights
*run the game exe with Windows XP compatibility mode (if you are running Vista/Win7)
*There are a lot of reports that this game will not like more than 3GB of RAM
limit RAM size to 2GB by editing Win XP (boot.ini) or Vista/Win7 (bcdedit) or by removing some memory sticks
May 19, 2010 | Atari Act of War: Direct Action for...
I need to change my NAT type to open but i dont know
If this is for gaming.... this should work.....
You can't exactly disable NAT so In your case you have two options.
Option 1: Designate your PC as the DMZ. This will send all unsolicited data directly to your PC as if you didn't even have a router. If you do choose this option then just be sure to have a software firewall running on your PC. DMZ'ing your PC isnt a big NO NO and it's not dangerous, it is the same as if your cable modem is plugged directly to your computer plus your router will work with the rest of your network. You can only set one PC as the DMZ also. Don't be afraid to try this option first, I mean would you be afraid to hook your modem directly to your PC like 50 percent of all the other broadband users on this earth do?
Option 2: Read the help files on all of your games and figure out which ports they all use. Then go back in to your router configuration and go to Port Forwarding or Application Forwarding (it's all the same). Then specify your PC's local IP and then set the ports accordingly. It's a pain in the **** if you have a lot of games, but it generally works. You can also use port triggering if you plan on gaming the same games on more than one PC
Apr 01, 2010 | Netopia 2200 Series (2246N-VGX) Router...
My xbox is having trouble singing into live... It sai that a problem have occored whle singing in. What's wrong?
If you are connected through a router, you will need to setup the port forwarding, you can find a manual to access these settings on your router at your routers manufacturers website, and you can find the ports you need forwarded at xbox360.com on there technical page. if this is already done, and you run through a router also, you may need to do a firmware update to your router, again you can find the updates at your routers manufacturers home page.
Although, if you are not connected to a router, and directly through your modem, it can be that your modem is going bad, your service provider is doing maintance, your network made a hickup, or you simply have a bad connection wither it be from the cables that run under your house, or inside your xbox.
Mar 09, 2010 | Video Game Consoles & Games
How to land in 1080 the snowboarding game in nintendo wii or nintendo 64
your board basically has to be angled up slightly and not leaning too far in either direction. too far back, you fall. too far forward, you fall. too far leaned to the left or right...fall.
Oct 01, 2009 | Nintendo 1080 Snowboarding for 64
I instant a Hampton bay fan with a remote, the fan will not go in the forward cycle only reverse
the connection to the motor has been reversed which makes the fan to run in reverse direction interchange the terminal then it will run in the forward direction
Jul 22, 2008 | Hampton Bay 24002 Ceiling Fan
Processor
go to intel.com, they will provide you the widest range of processors.
Jan 27, 2008 | Computers & Internet
Video Game Consoles & Games Logo
16 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
